Ripmax Xcalibur Sports jet
#2476
I returned to the shop and checked one more time by pinching the tail booms at 160mm, still with the fuel in it. Perfect. I’m happy. Just can’t hold the dang thing suspended very long. 😂
#2477
My Feedback: (7)
I've been redoing the install on mine for the last 4 hrs, all done, feels good this way, this means, that is it for the install, moved the pump forward a bit and the gear valve sideways, it looks clean now.
Next is to assemble it for the CG.
#2478
Carlos, nice pics. Thanks for posting. Small jets apparently are challenging to install the radio and support systems. Seems to be an advantage of larger jets but also comes larger price tag.
#2481
Carlos
Just push in through the boom into the fuse on assembly. They are really just for the wing as the screws support the boom, but we did that so the tubes could be pulled out of the boom to make transport cleaner, obviously they take load off the screws too.
#2484
#2492
My Feedback: (7)
Ok Dave
You have done it this time, the Xcalibur balanced perfectly with the batts on the pictures, 2 X 1700 LIFE and a 2200 LIPO and 1/4 of fuel in the tank, that was so simple, I CG it twice to make sure it was true what I was seen
Thank you.
Thank you.
#2494
My Feedback: (7)
Since the jeti DS12 is too new to me, I decided to set up the Xcalibur in my 10CAP Futaba, I took it to the field today with the intentions to fly it, but it didn't cooperated, at the field the Jetronics valve just didn't want to work as it should ( crap ) and the engine didn't want to start, last time it was run was like a year or nearly two years ago, I finally got it going after two or 3 fail starts with flames ( lots ) it starts now but it needs some adjustments to eradicate the all the flames during the start up sequence.
My friend Raffy gave me a hand with the engine.
#2496
#2497
My Feedback: (7)
I wanted to do all that also but, first the jetronics gear valve didn't work, it did at home but not at the field then the engine's fuel valve was stuck, I finally got it unstuck, when the engine started after 4 failed attempts I had about 2 feet of flames then it it stoped, on the following start, it did the same, it had accumulated all this fuel inside and finally it cleared and now it is starting and running normal but I will have to adjust the start up fuel to completely eliminate all the flames.
Done for this week.
Done for this week.
#2499
Done for this week.
Done for this week.
