Reload this Page >
The Fouga Magister Is On the Market
Old 09-05-2015, 09:55 AM
  #101
CraigG
My Feedback: (40)
CraigG's Avatar
Finally, this is the engine bay. I put a small component platform on top of the inlets for the fuel valve shutoff, ECU, air fill up fittings, on/off switch and data logger. The turbine is mounted as far forward as you can get it for cg purposes and to get better spacing with the tailpipe. I found the supplied bypass too large to fit the available space without major re-work elected not to use it.
Old 09-05-2015, 10:03 AM
  #102
CraigG
My Feedback: (40)
CraigG's Avatar
The cockpit install was a bit of a challenge. The supplied cockpit "tubs" are too large and cumbersome to fit through the canopy openings as a single unit, plus I wanted to have reasonable accesses to the component trays underneath. My solution was to disassembled the cockpit into individually removable components as shown:
ID:	2118191   Click image for larger version
ID:	2118192   Click image for larger version
ID:	2118193   Click image for larger version
Old 09-05-2015, 10:07 AM
  #103
CraigG
My Feedback: (40)
CraigG's Avatar
The instrument panel, side panels and cockpit floor are held in place with 2 or 3 small socket head screws. Note the balsa/ply standoffs on the fuselage sides and floor as attachment points. The glare shields are gently wedged in place and the pilot/seat are centered with dowels and held with magnets. Here is the sequence for the forward cockpit:
This pic is the aft cockpit:
ID:	2118194   Click image for larger version
ID:	2118195   Click image for larger version
ID:	2118196   Click image for larger version
ID:	2118200   Click image for larger version
ID:	2118201   Click image for larger version
Old 09-05-2015, 10:12 AM
  #104
f106jax
My Feedback: (16)
f106jax's Avatar
Looks good Craig. Looking forward to seeing your new ride in a couple of weeks.
Old 09-05-2015, 10:18 AM
  #105
CraigG
My Feedback: (40)
CraigG's Avatar
The aft cockpit is similar. I can access refueling by just removing the seat from the aft cockpit and access the rx, matchbox etc. by removing the floor. This is the finished look:
ID:	2118203   Click image for larger version
ID:	2118204   Click image for larger version
ID:	2118205   Click image for larger version
ID:	2118206   Click image for larger version
ID:	2118207   Click image for larger version
Old 09-05-2015, 01:17 PM
  #106
roydefiant
Craig thanks for posting. Very helpful and timely for me. I see you are also using A123 batteries from electrodynamics which is what I use also. Where did you get your pilot?
I will be using a jet munts 100 which I believe is almost a 1/2 lb less in weight than the kingtech.
Looking forward to rigging mine.
Thanks, Roy
Old 09-05-2015, 02:45 PM
  #107
CraigG
My Feedback: (40)
CraigG's Avatar
Thanks, Roy
Roy,
It's a "Korean War" pilot figure. I bought mine from BVM but I think this is the same one from DreamWorks. The size is about right and I figured the era was close.
http://www.dreamworksrc.com/catalog/...t-Pilot-Figure
Good luck on your Fouga.
Craig
Old 09-06-2015, 08:41 AM
  #108
CraigG
My Feedback: (40)
CraigG's Avatar
Originally Posted by igoren
need to see placement of the air tanks
Isaac
I forgot to show photos of my air tanks. They go in the aft section. The two smaller tanks go on either side, as far forward as possible to clear the tailpipe. I placed the larger air tank on the bottom, far enough back that it is aft of the split in the tailpipe. It probably isn't necessary but I taped a layer of BVM heat shield blanket over the forward portion of the large tank.
ID:	2118304   Click image for larger version
Old 09-06-2015, 09:29 AM
  #109
lavi rider
Isac ,
U could've asked me ....
Old 09-06-2015, 02:01 PM
  #110
ambaron
Default Other options for installation - General
Craig , Wonderful job
Here are some more pictures of Mr. Gaby Keidar installation
ID:	2118335   Click image for larger version
ID:	2118336   Click image for larger version
ID:	2118337   Click image for larger version
ID:	2118338   Click image for larger version
ID:	2118339   Click image for larger version
ID:	2118340   Click image for larger version
ID:	2118341   Click image for larger version
ID:	2118343   Click image for larger version
ID:	2118344   Click image for larger version
Old 09-06-2015, 02:04 PM
  #111
ambaron
Default The Cockpit
This is the General look of the Cockpit
ID:	2118346   Click image for larger version
Old 09-06-2015, 02:12 PM
  #112
ambaron
Default The Front Cockpit
Electronics is seating comfortably under the Cockpit seats with Easy Accesses
ID:	2118348   Click image for larger version
ID:	2118349   Click image for larger version
ID:	2118350   Click image for larger version
ID:	2118351   Click image for larger version
ID:	2118352   Click image for larger version
ID:	2118353   Click image for larger version
ID:	2118354   Click image for larger version
ID:	2118356   Click image for larger version
ID:	2118357   Click image for larger version
ID:	2118358   Click image for larger version
Old 09-06-2015, 02:19 PM
  #113
ambaron
Default Rear Cockpit
Plenty of room on the rear part
Gaby used the same method as in the front : the Cockpit dash sides are fixed to the Fuselage while center part is open-able ( No glue or bolts )
ID:	2118360   Click image for larger version
ID:	2118361   Click image for larger version
ID:	2118362   Click image for larger version
ID:	2118363   Click image for larger version
ID:	2118364   Click image for larger version
ID:	2118365   Click image for larger version
ID:	2118366   Click image for larger version
ID:	2118369   Click image for larger version
ID:	2118370   Click image for larger version
ID:	2118372   Click image for larger version
ID:	2118373   Click image for larger version
ID:	2118374   Click image for larger version
Old 09-06-2015, 04:02 PM
  #114
igoren
My Feedback: (23)
finally we see some fuga installation !!! it is about time. great footage from Craig and Gaby install .keep them uploading.
here are mine coming up,
cheres all of you, and happy landings
Isaac
Old 09-06-2015, 04:10 PM
  #115
igoren
My Feedback: (23)
ID:	2118379   Click image for larger version
ID:	2118380   Click image for larger version
ID:	2118381   Click image for larger version
ID:	2118382   Click image for larger version
ID:	2118383   Click image for larger version
ID:	2118384   Click image for larger version
ID:	2118385   Click image for larger version
ID:	2118387   Click image for larger version
Old 09-06-2015, 04:12 PM
  #116
igoren
My Feedback: (23)
ID:	2118389   Click image for larger version
ID:	2118390   Click image for larger version
ID:	2118391   Click image for larger version
ID:	2118392   Click image for larger version
ID:	2118393   Click image for larger version
ID:	2118394   Click image for larger version
ID:	2118395   Click image for larger version
ID:	2118397   Click image for larger version
Old 09-06-2015, 04:14 PM
  #117
igoren
My Feedback: (23)
ID:	2118399   Click image for larger version
ID:	2118400   Click image for larger version
ID:	2118401   Click image for larger version
ID:	2118402   Click image for larger version
ID:	2118403   Click image for larger version
ID:	2118404   Click image for larger version
ID:	2118405   Click image for larger version
ID:	2118407   Click image for larger version
Old 09-06-2015, 04:16 PM
  #118
igoren
My Feedback: (23)
ID:	2118409   Click image for larger version
ID:	2118410   Click image for larger version
ID:	2118411   Click image for larger version
ID:	2118412   Click image for larger version
ID:	2118413   Click image for larger version
ID:	2118414   Click image for larger version
ID:	2118415   Click image for larger version
ID:	2118417   Click image for larger version
Old 09-06-2015, 04:21 PM
  #119
igoren
My Feedback: (23)
ID:	2118419   Click image for larger version
ID:	2118420   Click image for larger version
ID:	2118421   Click image for larger version
ID:	2118422   Click image for larger version
ID:	2118423   Click image for larger version
ID:	2118424   Click image for larger version
ID:	2118425   Click image for larger version
ID:	2118427   Click image for larger version
ID:	2118428   Click image for larger version
ID:	2118429   Click image for larger version
ID:	2118430   Click image for larger version
ID:	2118431   Click image for larger version
ID:	2118432   Click image for larger version
ID:	2118433   Click image for larger version
ID:	2118435   Click image for larger version
ID:	2118436   Click image for larger version
ID:	2118437   Click image for larger version
Old 09-06-2015, 04:26 PM
  #120
igoren
My Feedback: (23)
ID:	2118439   Click image for larger version
ID:	2118440   Click image for larger version
ID:	2118441   Click image for larger version
ID:	2118442   Click image for larger version
ID:	2118443   Click image for larger version
ID:	2118444   Click image for larger version
ID:	2118445   Click image for larger version
ID:	2118447   Click image for larger version
ID:	2118448   Click image for larger version
ID:	2118449   Click image for larger version
ID:	2118450   Click image for larger version
ID:	2118451   Click image for larger version
ID:	2118452   Click image for larger version
ID:	2118453   Click image for larger version
ID:	2118455   Click image for larger version
ID:	2118456   Click image for larger version
ID:	2118457   Click image for larger version
ID:	2118458   Click image for larger version
ID:	2118459   Click image for larger version
ID:	2118460   Click image for larger version
ID:	2118461   Click image for larger version
ID:	2118463   Click image for larger version
ID:	2118464   Click image for larger version
ID:	2118465   Click image for larger version
ID:	2118466   Click image for larger version
ID:	2118467   Click image for larger version
Old 09-06-2015, 04:35 PM
  #121
igoren
My Feedback: (23)
ID:	2118469   Click image for larger version
ID:	2118470   Click image for larger version
ID:	2118471   Click image for larger version
ID:	2118472   Click image for larger version
ID:	2118473   Click image for larger version
ID:	2118474   Click image for larger version
ID:	2118475   Click image for larger version
ID:	2118477   Click image for larger version
ID:	2118478   Click image for larger version
ID:	2118479   Click image for larger version
ID:	2118480   Click image for larger version
ID:	2118481   Click image for larger version
ID:	2118482   Click image for larger version
ID:	2118483   Click image for larger version
ID:	2118486   Click image for larger version
ID:	2118487   Click image for larger version
ID:	2118488   Click image for larger version
ID:	2118490   Click image for larger version
ID:	2118491   Click image for larger version
ID:	2118493   Click image for larger version
ID:	2118494   Click image for larger version
ID:	2118497   Click image for larger version
ID:	2118499   Click image for larger version
ID:	2118500   Click image for larger version
ID:	2118502   Click image for larger version
ID:	2118504   Click image for larger version
ID:	2118505   Click image for larger version
ID:	2118507   Click image for larger version
ID:	2118510   Click image for larger version
ID:	2118512   Click image for larger version
ID:	2118513   Click image for larger version
ID:	2118515   Click image for larger version
ID:	2118516   Click image for larger version
ID:	2118518   Click image for larger version
ID:	2118519   Click image for larger version
Old 09-06-2015, 04:41 PM
  #122
igoren
My Feedback: (23)
ID:	2118521   Click image for larger version
ID:	2118522   Click image for larger version
ID:	2118523   Click image for larger version
ID:	2118524   Click image for larger version
ID:	2118525   Click image for larger version
ID:	2118526   Click image for larger version
ID:	2118527   Click image for larger version
ID:	2118529   Click image for larger version
ID:	2118530   Click image for larger version
ID:	2118531   Click image for larger version
ID:	2118532   Click image for larger version
ID:	2118533   Click image for larger version
ID:	2118534   Click image for larger version
ID:	2118535   Click image for larger version
ID:	2118537   Click image for larger version
ID:	2118538   Click image for larger version
ID:	2118539   Click image for larger version
ID:	2118540   Click image for larger version
ID:	2118541   Click image for larger version
ID:	2118542   Click image for larger version
ID:	2118543   Click image for larger version
ID:	2118545   Click image for larger version
ID:	2118546   Click image for larger version
ID:	2118547   Click image for larger version
ID:	2118548   Click image for larger version
ID:	2118549   Click image for larger version
ID:	2118550   Click image for larger version
ID:	2118551   Click image for larger version
ID:	2118553   Click image for larger version
ID:	2118554   Click image for larger version
ID:	2118555   Click image for larger version
ID:	2118556   Click image for larger version
ID:	2118557   Click image for larger version
ID:	2118558   Click image for larger version
Old 09-06-2015, 04:48 PM
  #123
igoren
My Feedback: (23)
ID:	2118560   Click image for larger version
ID:	2118561   Click image for larger version
ID:	2118562   Click image for larger version
ID:	2118563   Click image for larger version
ID:	2118564   Click image for larger version
ID:	2118565   Click image for larger version
ID:	2118566   Click image for larger version
ID:	2118568   Click image for larger version
ID:	2118569   Click image for larger version
ID:	2118570   Click image for larger version
ID:	2118571   Click image for larger version
ID:	2118572   Click image for larger version
ID:	2118573   Click image for larger version
ID:	2118574   Click image for larger version
ID:	2118576   Click image for larger version
ID:	2118577   Click image for larger version
ID:	2118578   Click image for larger version
ID:	2118579   Click image for larger version
ID:	2118580   Click image for larger version
ID:	2118581   Click image for larger version
ID:	2118582   Click image for larger version
ID:	2118584   Click image for larger version
ID:	2118585   Click image for larger version
ID:	2118586   Click image for larger version
ID:	2118587   Click image for larger version
ID:	2118588   Click image for larger version
ID:	2118589   Click image for larger version
ID:	2118590   Click image for larger version
ID:	2118592   Click image for larger version
ID:	2118593   Click image for larger version
ID:	2118594   Click image for larger version
ID:	2118595   Click image for larger version
ID:	2118596   Click image for larger version
ID:	2118597   Click image for larger version
ID:	2118598   Click image for larger version
Old 09-07-2015, 05:33 PM
  #124
roydefiant
Isaac, thanks for posting all this. Between Craig, Avi and you I should be able to figure out how best I want to rig mine.
A few questions
How did you rig outboard flap? Looks like you were setting up a torque tube?
Where did you buy your lights?
Where did you find the quilted material for the side?
I will be putting the same Jets-Munt turbine in mine.
Roy
Old 09-07-2015, 07:16 PM
  #125
igoren
My Feedback: (23)
Hi Roy , I set up the flaps with the torque rod , but I am going to change it to 2 - servos per side.I think it is too mutch stress on the servo to drive the speet flaps.for the lights , we have a store near by ALL ELECTRONICS ,that have all kinds of L,E.D lights and shokets , I made my own.
the quilted material for the side are actually plastic mats found it around the hose have no idea how it got hear
