Reload this Page >
Sebart Mini Avanti w/ K45 build thread
Old 12-08-2017, 01:36 PM
  #626
jet-lover
Originally Posted by RemoteJets
If you ordered at Tamjets a K45 version then it should be the right one, only a little smaller then the Grumania version.
The outside diameter of the Grumania pipe for the K45 powered Mini Avanti S is 70mm (inner about 65mm).
Whit this pipe installed the carbon rod of the stabilizer just press on the pipe and keep it in place.
Grt,
Berto.
My internal diameter is only 50mm so not looking good. Also I am not sure how far the mouth of the pipe should be from the back of the turbine.
In in the Kingtech manual it shows 20-30mm for most of the other turbines but not the k45?
Old 12-08-2017, 03:07 PM
  #627
emart
Mine is a Tams pipe same 50mm inner pipe diam. I have no issues so far .. I set mine about 25mm from bell mouth . probably have about 15 to 20 flights on mine so far
Tom ling (12-24-2021)
Old 12-08-2017, 03:43 PM
  #628
jet-lover
Thanks Emart. That is good news. Would there be any chance you post 2 photos of your pipe install I.e front and rear.
I wiuld be sooooooo grateful.
Old 12-08-2017, 04:01 PM
  #629
emart
here you go the tail end on mini avanti is a little hard to see i have weights glued in i have included a pic of my Avanti XS and you can see how I made the rear ring to support the pipe
ID:	2247249   Click image for larger version
ID:	2247250   Click image for larger version
ID:	2247251   Click image for larger version
Old 12-10-2017, 12:33 PM
  #630
jet-lover
Thats fantastic! Thank you so much.
I was just about to order the Grumania Pipe. You saved me several hundred dollars.
Thanks so much!
Old 12-10-2017, 12:46 PM
  #631
tuxian007
My Mini Avanti with K70G is ready for the maiden.
Waiting for better weather condition in frozen Austria.
I moved the tank backwards as far as possible to avoid that it is too nose-heavy with full tank.
The weight is almost the same as with the previous Mini Avanti with electric 8s setup and lies with full hopper tank and empty main tank at about 4370g.
Old 12-25-2017, 02:02 PM
  #632
tuxian007
Today the maiden flight with the K70G took place.
I am glad to have installed the K70G because the performance when starting or going around is by no means a disadvantage.
It was a bit noise heavy with a full tank but that was to be expected.
The performance is great even if I was a little more cautious on the first flight.
Takeoff:
Overflight:
Low Pass:
Landing:
Markus
Old 12-25-2017, 02:25 PM
  #633
lorenb
Default K45
Hi guys can you share your run parameters for the k45. I just need to compare with mine. Running diesel..
thank you
Old 12-27-2017, 01:50 AM
  #634
tuxian007
Originally Posted by Dave Wilshere
J125.1037 made by Jet-1a. They are doing sets for the Mini Avanti
email them at [email protected]
Did you also replace the noise struts and is it possible to use bigger wheels?
Old 01-01-2018, 01:12 PM
  #635
jet-lover
Could I ask where you purchased the fuel tank from please?
Old 01-01-2018, 01:22 PM
  #636
ltc
Carlos at CMJets
Cmjets on Facebook (can't seem to post direct link)
https://cmjets.com/
http://www.rcuniverse.com/forum/rc-j...ets-tanks.html
Old 01-01-2018, 01:24 PM
  #637
tuxian007
Yes I bought it from CMJets:
https://cmjets.com/sebart/39-mini-avantis-13l.html
Old 01-01-2018, 03:02 PM
  #638
cmjets
cmjets's Avatar
Hello Friends, yes, I make the mini AvantiS 1.3L tanks.
you can write me direct to my personal email, I’m changing the website and the new not is full operative still.
[email protected]
thanks
Carlos
www.cmjets.com
Old 01-01-2018, 06:06 PM
  #639
Doug Cronkhite
My Feedback: (34)
What should the distance be between the tailpipe and turbine? Using Tam's pipe..
Old 01-02-2018, 06:51 AM
  #640
ltc
You could start with the Grumania installation guidelines, page 3 of 8 on this pdf
Name:	2018-01-02 09_50_42-Englisch614.png
Old 01-02-2018, 07:09 AM
  #641
Bob_B
Bob_B's Avatar
I set the exhaust nozzle 15 mm from the face of the pipe, NOT the bellmouth on the Tam pipe. I have a K45 installed.
Old 01-02-2018, 11:55 AM
  #642
a25afm
Default Fuel tank
JET LOVER, I sent you a PM.
Old 01-04-2018, 02:38 PM
  #643
Doug Cronkhite
My Feedback: (34)
Any chance someone has a drawing for the rear pipe support?
Old 01-04-2018, 02:43 PM
  #644
cmjets
cmjets's Avatar
Jet-Lover, write me !!!!
[email protected]
Regards from Spain
Carlos
www.cmjets.com
Old 04-05-2018, 04:35 AM
  #645
extra 300
Hi Guys,
I have now started the build on my Mini Avanti which will have the K45 fitted. Need some advice on the following:
A) Tail pipe: I have a spare HSD Super Viper tail pipe available, i trial fitted it and it looks just perfect as the rear former holds the pipe exactly in position. except for a couple of issues: pipe seem a little long and protrudes outside fuselage by 5 to 6 cm would this be a problem? on the other hand the outside pipe is pulling against the CF Stab rod, Would this be a problem?
B) Still not sure about which Fuel tank to use as i would have to remove (cut out) the the inlet liners as no decent fuel tank would fit in this narrow space and moving fuel tank forward is out of the question for sure.
Any help/feedback on the above would be much appreciated.
Regards,
Old 04-05-2018, 04:42 AM
  #646
BarracudaHockey
BarracudaHockey's Avatar
There's a CM Jets tank that fits well, I have the bigger one and it needed some mod to the inlets but that posed no problem in flight. But they have one thats tapered for the Avanti
Old 04-05-2018, 06:41 AM
  #647
cmjets
cmjets's Avatar
Default Mini AvantiS 1.3L Kevlar Tank.
Hello, here you can find the solution for the Mini AvantiS
Regards tromba Spain
Carlos
www.cmjets.com
Old 04-05-2018, 01:28 PM
  #648
Springbok Flyer
Springbok Flyer's Avatar
Hi guys,
I am sure it is mentioned amongst all the preceeding posts, but I wish to check the best cg for this jet. So if you guys don't mind repeating the information I will appreciate the input. Perhaps your various control throws could also be mentioned.
Thank you,
JanR
Old 04-07-2018, 10:22 PM
  #649
extra 300
Originally Posted by extra 300
Hi Guys,
Regards,
Any feedback on whether ok to use the HSD Super Viper tail pipe on the mini Avanti and K-45?
Thanks in advance
Old 04-07-2018, 10:50 PM
  #650
Midas D.
Talking
If it fits, i could not see why not, just trail and error i suppose ....
Made another 6 flights with the Mini.
I completely lost count but my K45 tell's already more then 10hrs on the clock and it went in this bird from new out he box.
So still going strong, and still lots of fun to fly!!
Must say, cause she took some beating in all sorts, she doesn't look that "sharp" any more......
I have an brand new one laying on he shelf, completely build up, as a spare, only no turbine
I'm considering putting a K70 in there but i wonder, will the airframe handle the load/push of an K70????
Although mine had a really hard time, multiple from way up there full nose down full throttle dive's etc. she's still hanging in there but she starts to show wear, tear and slop on almost every thing......
It would be the next step in fun with a K70 in there but, if the whole airframe at an certain point just explodes up there cause i took it just a step to far.....
What's you guy's thought's on this?
Cheers,
Ed
