Reload this Page >
Elite Aerosport Rebel Pro Build
Old 11-17-2015, 10:02 AM
  #101
FenderBean
FenderBean's Avatar
I am using the BVM high flow clunk its the same size nice and heavy as well.
Old 11-17-2015, 11:42 AM
  #102
mr_matt
My Feedback: (10)
mr_matt's Avatar
I don't know where I saw it but are you going to use those little BVM hatch latches? That hatch looks to be about 3 1/2 feet long and 18 inches wide?
I would be worried that aero forces will yank that canopy right off if it is only held on by the 1.8 inch long bit of wire coming out of those hatch latches.
Old 11-17-2015, 02:42 PM
  #103
FenderBean
FenderBean's Avatar
Matt the stock is two rods that do the same thing, no reports of this not holding.
Old 11-17-2015, 05:31 PM
  #104
FenderBean
FenderBean's Avatar
Back at it on the equipment install, I got the power system mounted and also put in the vents in prep for tank install. I did end up adding a brass tube to my clunk line, no reason to have a doubt.
I also took the tail off and added the pipe mount supports, once this is cured I will start on the rudder alignment pin and the pipe mounting. I think I may redo my latch system its just to hard to get on and off. It works great but the bvm latches have real small arms to pull back and Its hard to work, I might buy something that has a taller arm that will stick out further so I can get a grip on. Or I may just make one.
Another note I found matching paint! its in the video and it matches perfect so I bought a can of spray paint in it as well. I painted the nose door area and it looks like its part of the skin , I will also remove the carbon decal on the wing hatches and paint them to match. (MOD ALERT) Tank is much stronger now with the carbon wrap
ID:	2131124   Click image for larger version
ID:	2131125   Click image for larger version
ID:	2131126   Click image for larger version
ID:	2131127   Click image for larger version
ID:	2131128   Click image for larger version
ID:	2131129   Click image for larger version
ID:	2131130   Click image for larger version
ID:	2131132   Click image for larger version
ID:	2131133   Click image for larger version
ID:	2131134   Click image for larger version
ID:	2131135   Click image for larger version
ID:	2131136   Click image for larger version
ID:	2131137   Click image for larger version
ID:	2131138   Click image for larger version
Old 11-18-2015, 03:15 AM
  #105
Quandry
Very nice, all of the hard work you are putting in really shows.
Old 11-18-2015, 05:48 AM
  #106
FenderBean
FenderBean's Avatar
Thanks, after all my other builds this one has been a pleasure. Nice to see someone posting from the homeland!
Old 11-18-2015, 05:10 PM
  #107
FenderBean
FenderBean's Avatar
Back at it today, im a little slow going these days due to being tired from work. I tell you its really hard to live in todays military, not the same Army I joined over 16 years ago. I tell my minions on regular basis "I don't wake up this angry, you guys make me this way!" Or should I say this unit does. Anyway started on all the alignment stuff, the rudder has more steps so I started there. I installed a blind nut for the back 4mm bolt and marked/drilled the hole for the alignment pin in the front. I also cut a small hole for the rudder servo wire, next I will get the stabs. They will be faster since it doesnt require any hysol, the stabs are held in place by four screw in the tube itself. Last night I did a few internal things, I installed the tank and clunk lines followed by the bulkhead festo fittings. Nice and clean! (MOD ALERT) I did open some area on the side of fuse, this area had no ply and is a direct opening to the wheel bays so this will greatly improve air flow to the turbine.
Video is up loading as well
ID:	2131314   Click image for larger version
ID:	2131315   Click image for larger version
ID:	2131316   Click image for larger version
ID:	2131317   Click image for larger version
ID:	2131318   Click image for larger version
ID:	2131319   Click image for larger version
ID:	2131320   Click image for larger version
ID:	2131322   Click image for larger version
ID:	2131323   Click image for larger version
ID:	2131324   Click image for larger version
Old 11-18-2015, 11:26 PM
  #108
number27
number27's Avatar
Keith, could you till me the length on the nose oleo strut please. I am going a different way than your gear. Mains and wheels the same (ebrakes). Retracts Electron ER50 and Electron nose strut and wheel to match (it is a flat tyre) want a flat nosewheel to match the speed wheels from Airtech. Nose wheel size as well please.
Great thread as well. Keep up the great post.
Old 11-19-2015, 08:32 PM
  #109
FenderBean
FenderBean's Avatar
The long part is 6 1/2 inches down to the pivot point, from the pivot point to the bottom of the wheel its 4 1/4 inches.
Old 11-19-2015, 08:40 PM
  #110
FenderBean
FenderBean's Avatar
Feels like I didnt get anything done tonight but I did get the wing pin holes cut and the retaining screw install so the main wings are done and so is the rudder. I did glue the stab alignment tubes in but did not cut the holes yet, I will do this tomorrow. I started working on a small equipment board for the gear valve and the up6 brake valve. Tomorrow I will finish up the stabs and then its the home stretch. Turbine/pipe install followed by the rest of the electronics and its done! I should be done by Sunday!!! yeah!!! anyway small video is uploading
The problem is I seem to take forever deciding the layout of equipment
ID:	2131538   Click image for larger version
ID:	2131539   Click image for larger version
ID:	2131540   Click image for larger version
ID:	2131541   Click image for larger version
ID:	2131542   Click image for larger version
ID:	2131543   Click image for larger version
Old 11-20-2015, 05:11 AM
  #111
rc4flying
My Feedback: (21)
rc4flying's Avatar
I now have the tail section with a Thrust Vectoring pipe all set up and ready to go. This is a build that I am doing for a friend.
Name:	2015-11-20 07.24.59.jpg
ID:	2131575   Click image for larger version
Name:	2015-11-20 07.04.51.jpg
ID:	2131576   Click image for larger version
Name:	2015-11-20 07.24.41.jpg
Old 11-20-2015, 11:34 AM
  #112
number27
number27's Avatar
nice work. what servo's for thrust vector please?
Old 11-20-2015, 12:48 PM
  #113
rc4flying
My Feedback: (21)
rc4flying's Avatar
The owner has picked Futaba 9157.
Old 11-20-2015, 12:57 PM
  #114
rc4flying
My Feedback: (21)
rc4flying's Avatar
FenderBean,
Sorry about posting the above in your build thread. There was a Rebel thread about the use of thrust vector usage in a Rebel Pro and when I did a search for that thread, I now see that I picked the wrong thread. Didn't mean to post this in your building thread. I am sorry.
Old 11-20-2015, 05:23 PM
  #115
FenderBean
FenderBean's Avatar
No problem this thread is for informational things on this jet, nice to see the tv stuff.
Old 11-20-2015, 06:58 PM
  #116
Jethead
Originally Posted by FenderBean
Also I would like to say this is my 6th jet and has completely been a different story on ordering and customer service. Every model I have bought prior to this has not been an easy one, always something that has made me wish I would have never gotten into jets.
Id be interested in hearing exactly what made you feel this way and what brands you were dealing with. I ask because I'm just getting back into it and want a heads up as to what to avoid.
This is build looks good and seems to be going well so hopefully your experience is changing.
Old 11-21-2015, 10:36 AM
  #117
David Jackson
My Feedback: (15)
Part of the problem many of us have run into is the long wait time to receive our models. The last model I ordered before getting the Rebel Pro took nearly 6 months to ship out to me. Order the Rebel Pro from Elite Aerosport and was told the model would ship in 6 to eight weeks, got it in seven. Pablo and the Elite team provided great communication.
Old 11-21-2015, 11:45 AM
  #118
Jethead
Thanks for that. Difficult to predict when shipments from China will enter the US and clear customs... Really don't think I'd get my feathers ruffled over a 6 month wait as I'd probably be expecting that.
I'm more interested in hearing from the OP about the quality of the kits and the damage from the factory....What is so bad that he made the statement I quoted? And who is doing it. Call them out as I want to avoid them.
Old 11-21-2015, 12:53 PM
  #119
Andrew Bird
Andrew Bird's Avatar
I ordered a Shockwave from Elite Aerosports and got it within a week - which given I'm in the UK is quick! Packaging was fantastic and given it travelled from Thailand to the US and the US to the UK, packaging correctly is really important. I've also recently received a new Comp arf Flash. There were foot prints on the Flash box but it's package so well that despite some idiot going for a walk on it there was no damage what so ever. The quality of both kits is very good.
In contrast I have a skymaster plane here which I'm helping a friend out with. While it's ok, the quality is still clearly not on par with the other planes I have here from the likes of EA, comp arf and Tomahawk.
Old 11-21-2015, 03:38 PM
  #120
FenderBean
FenderBean's Avatar
Evening, I took Friday night off from building and got started this morning. The building is done, all the wings are on and done, the pipe and turbine are mounted so now comes the fun stuff! Still on par to finish up tomorrow, it just depends on how fast I can decide where im putting everything this could take weeks LOL I ran into a small problem getting the stab wing tubes on the last two inches since the stab guide tube was warped at the end but I them on. The super duper hi-teck turbine thrust pipe alignment tube worked great, I used it on the Avanti as well.
I have a few videos uploading as well got to forgive the vent video, cheers!
ID:	2131710   Click image for larger version
ID:	2131711   Click image for larger version
ID:	2131712   Click image for larger version
ID:	2131713   Click image for larger version
ID:	2131714   Click image for larger version
ID:	2131715   Click image for larger version
ID:	2131716   Click image for larger version
ID:	2131718   Click image for larger version
ID:	2131719   Click image for larger version
ID:	2131720   Click image for larger version
ID:	2131721   Click image for larger version
ID:	2131722   Click image for larger version
ID:	2131723   Click image for larger version
ID:	2131724   Click image for larger version
ID:	2131726   Click image for larger version
ID:	2131727   Click image for larger version
Old 11-22-2015, 12:12 PM
  #121
FenderBean
FenderBean's Avatar
Sunday fun, since I plan to keep this thing for long time I wanted to make turbine pull maintenance very easy. I have mounted everything where it can be easily inspected or removed. I mounted the UAT on top but I was pondering if having to pull the fuel from below up to the UAT might cause some increased pump voltage. I could just be over thinking it, but I have always tried to keep everything in the fuel system inline.
I also removed the canopy latches and installed the stock canopy release, I should have just done this from the get go. Simple and effective!
The fuel valves are mounted to a ply mount on the side walls and held to the ply with two screws as well as the pump its held in with two screws. Cheers!
ID:	2131858   Click image for larger version
ID:	2131859   Click image for larger version
ID:	2131860   Click image for larger version
ID:	2131861   Click image for larger version
ID:	2131862   Click image for larger version
ID:	2131863   Click image for larger version
ID:	2131864   Click image for larger version
ID:	2131866   Click image for larger version
Old 11-22-2015, 07:02 PM
  #122
FenderBean
FenderBean's Avatar
Spent the day installing air stuff and running wires as of 2100 hours this things done! I will take some pictures and get the function video done tomorrow. Im not used to such a simple air system lol
Old 11-23-2015, 02:31 AM
  #123
Quandry
I like the turbine thrust alignment tool Fender!! nice build and thanks for the comprehensive pictures to drool over
Old 11-23-2015, 04:56 AM
  #124
FenderBean
FenderBean's Avatar
It's my pleasure, I hope this will help future builders.
Old 11-23-2015, 04:06 PM
  #125
smchale
My Feedback: (67)
smchale's Avatar
Nice job Kieth, thanks for sharing. Best of luck on the next phase!
