Jeti DS-24 >
Jeti DS-24
Jeti DS-24
Old 01-06-2016 | 06:23 AM
  #76
Same thing for me, the quality, released products, available products, updates and overall support for the Jeti sold me. And I have absolutely NO regrets.
I have dealt with Ultimate Jets several times and they do a great job, THANKS WOODY, but I don't think they get much help from Weatronics. Which is too bad. The ergonomic of the Weatronics is clunky too. my own opinion...... of coarse.
Good luck
Doug
Old 01-06-2016 | 07:33 AM
  #77
olnico's Avatar
So, the marketting strategy of the Jeti boys is based on bashing other's product?
What a fantastic prospect.
Congratulations guys for this great 2016 start.
Old 01-06-2016 | 08:54 AM
  #78
I took couple of pictures of the Jeti DC-24 screen, the fully customizable color screen is excellent.
Zb/Jeti USA
Old 01-06-2016 | 09:00 AM
  #79
Bob_B's Avatar
Very Nice ZB. Maybe Santa will give me one of the DS-24 next Christmas.
Old 01-06-2016 | 09:18 AM
  #80
wfield0455's Avatar
My Feedback: (7)
Pot, meet Kettle
Old 01-06-2016 | 09:13 PM
  #81
Springbok Flyer's Avatar
Originally Posted by wfield0455
Pot, meet Kettle
+1
Old 01-09-2016 | 08:56 PM
  #82
I've asked this question on the DS-16 thread but no answer......
Can somebody enlighten me on the new multi-mode gimbals. Can these be configured to give a super smooth feel on the throttle stick (no ratchet)?
I fly heli's in addition to Jets and I want a super smooth stick on the collective. From what I read the sticks on the existing (non- colored) DS-16 are still a little 'sticky' due to a small amount of ratchet input on the throttle / collective even when the ratchet is removed.
Can someone please give me a view?
Old 01-10-2016 | 09:01 PM
  #83
I do not think so there is enough of those gimbals out there. Only few radios in US have them.
Zb/Jeti USA
Old 01-10-2016 | 09:02 PM
  #84
Old 01-10-2016 | 11:52 PM
  #85
Hi,
I have a Multimode... it allows for a fast mode change by just unscrewing and rotating a plate on either stick to set the preferred mode.
You can adjust the ratchet using a screw on the mechanism and I believe you can back it off to remove the ratchet all together.
Cheers
Jeff
Old 01-11-2016 | 04:42 PM
  #86
ravill's Avatar
Some of us want the DS-24!!!! Hurry up!!
Old 01-12-2016 | 03:30 AM
  #87
Yes please do. the sooner the better.
Old 01-12-2016 | 06:32 AM
  #88
You can start with DS-16 (it has 24 channels) and later transfer all you models to the 24. The DS-24 is still months away. Do not know single person who lost money on Jeti stuff. There is almost none used out there. Jeti is keeping they record flawless with backwards compatibility.
Zb/Jeti USA
Old 01-12-2016 | 07:45 AM
  #89
We all loose money when selling used stuff. Why would someone want to pay 1700. Used when they can get it new? So I figure I would loose 300-400 if I were to buy now then upgrade in 6mo then try to sell older model when everyone wants the new one. Jeti is for the most part an exclusive few. I have seen 2 in the last 5 years. So that narrows the resale crowed. I'm excited to get my first jeti so I'll wait and get the ds24
Old 01-12-2016 | 11:43 AM
  #90
My Feedback: (57)
I held thee DS-16 AGAIN the other day trying to see if there was any way...
I concluded if I quit using both sliders (which I do now), it would be just about perfect.
I really wish it would work for me.
Old 01-12-2016 | 11:49 AM
  #91
Bob_B's Avatar
George as a current Futaba user you would adapt to the Jeti programming, quickly. I use the left slider for my volume control, that way when get my fuel low alarm i can lower or turn off the nagging gal and peacefully land my jet.
Old 01-12-2016 | 12:07 PM
  #92
My Feedback: (57)
Bob,
Not too concerned about the programming, I sort of enjoy learning that and seeing what can be done with some "creative" programming. My apprehension is the slider lay-out/location. I use both sliders (left - flaps, right - brakes), so inherently they are integral to my set-ups and flying.
Believe me, I have tried to like it because I have access to one and could use whenever I wanted.
Old 01-12-2016 | 12:37 PM
  #93
wfield0455's Avatar
My Feedback: (7)
Originally Posted by George
Bob,
I use the right slider for brakes as well on my DS16 but then I have rather large hands so what works fine for me may not for everyone. Just curios what it is that doesn't work about the slider for you ? Is it the placement of the sliders, the length of the lever? Would an extended lever that is longer and raised above the recess such as this help ? http://www.hacker-motor-shop.com/e-vendo.php?shop=hacker_e&a=article&ProdNr=80001555& t=880&c=6135&p=6135
Old 01-12-2016 | 12:42 PM
  #94
Good call Wayne.
These larger side sliders are available here in the states too:
http://www.espritmodel.com/jeti-tran...vers-ds-2.aspx
Doug
Old 01-12-2016 | 12:47 PM
  #95
Bob_B's Avatar
Bob,
Well we'll just have to change that! No really I understand. I use the inner switch above the throttle for my Flaps (Flight Conditions) also my Gyro gains are controlled by this switch too. I use the right slider for brakes typically. We just need to get you on the box while flying so you can get a true feel for the system.
Old 01-12-2016 | 01:00 PM
  #96
afterburner's Avatar
My Feedback: (18)
Bob,
I know what you mean George. That is the only thing that bothers me about the ergonomics of the radio. For me it's the angle where the slider starts compared to the Futaba and the physical travel as well. Not sure if it's possible but if they made the slider with say an offset that might work.
Old 01-12-2016 | 01:06 PM
  #97
Bob_B's Avatar
Marty do you decide to not buy a car you really like because the turn signal has a funny angle to it
Old 01-12-2016 | 02:32 PM
  #98
That was the only thing that bugged me to was the sliders, I replaced them with the longer one's problem solved been using it now for just over 12 months and luv it.
Old 01-12-2016 | 02:46 PM
  #99
My Feedback: (18)
No but if the brake is by the climate controls, I might have an issue
Old 01-12-2016 | 05:28 PM
  #100
My Feedback: (57)
Wayne,
As just mentioned, it's the physical location. If the lever extended to rear of the box and allowed to be used from that position (maybe an offset as suggested by Marty), it would probably solve that issue.
