Reload this Page >
Kingtech presents the all new T1 sports jet
Old 11-29-2016, 06:04 PM
  #1026
smiller
A couple more.
Scott
ID:	2191709   Click image for larger version
Old 11-30-2016, 02:11 AM
  #1027
Dave Wilshere
Originally Posted by smiller
A couple more.
Scott
Scott
On the UP3 valve its so important to have the linkage in line with the shuttle, the offset puts a side load on it and there is more chance of a leak, or wear on the O rings. You look like it was set up for 2 x clevis.
Just an observation
Dave
Old 11-30-2016, 10:20 AM
  #1028
TonyBuilder
TonyBuilder's Avatar
Originally Posted by dave wilshere
scott
on the up3 valve its so important to have the linkage in line with the shuttle, the offset puts a side load on it and there is more chance of a leak, or wear on the o rings. You look like it was set up for 2 x clevis.
Just an observation
dave
+1
tb
Old 11-30-2016, 11:11 AM
  #1029
smiller
Originally Posted by Dave Wilshere
Scott
Just an observation
Dave
Yes, looks a little off in the picture but there is no binding. Valve was from my used stock and the hole is slightly enlarged. Thanks for the input though. I love UP valves, I never have problems with them, knock on wood !!
Scott
Old 11-30-2016, 12:17 PM
  #1030
Johnny9390
My Feedback: (34)
Let us know if the air cylinder is enough to keep that large door closed when you fly her
Old 11-30-2016, 12:37 PM
  #1031
smiller
yes, it is a BVM cylinder, have 18 flights now, no issues as long as you get the geometry right. Simple installation using the two hinges supplied with T-one. Hard to see in the picture but the door is also stiffened with a 1/32 ply laminate.
Scott
Old 12-04-2016, 09:47 AM
  #1032
TonyBuilder
So back to my gear issues. Does anyone know who makes the gear? Currently parts are not available short of getting a whole complet set (witch I may have to do!). My issue as of late is the springs on the mains have lost there "spring", at rest the gear will no longer hold the plane up, the gear is compressed all the way and if you lift the wings they will rebound but once you start to roll they collapse and bottom out and won't rebound.
I took the the right side apart as it is the worst. The spring is .310 O.D. and 2.77" long.
The amount that the strut moves inside the main post is about 1/2" so the spring does not compress much until the strut bottoms out. I added a 3/8" extension spring to pre load the spring for now but that is just a temp fix.
I am working with Century Spring Co. out of California to get a custome replacment sring with a bit more holding strength.
TB
ID:	2192206   Click image for larger version
ID:	2192207   Click image for larger version
Old 12-04-2016, 07:38 PM
  #1033
Wclays
My Feedback: (85)
Mcmaster Carr
https://www.mcmaster.com/#compression-springs/=15bw6q4
They have everything
Old 12-04-2016, 07:52 PM
  #1034
Desertlakesflying
My Feedback: (28)
Originally Posted by Wclays
Except a 3" X .310 O.D.
Old 12-04-2016, 07:54 PM
  #1035
Desertlakesflying
My Feedback: (28)
TB
if you get some let me know I'd like to order a set too.
Old 12-05-2016, 05:53 AM
  #1036
sirrom
Please let me know as well...I have a T-One on order and if this solves your problem I will order a set as well for mine.
patrick
Old 12-05-2016, 06:07 AM
  #1037
TonyBuilder
Once I get the correct size that works I will post it here, and I should have a few sets extra for other T-1 owners.
TB
Old 12-09-2016, 10:38 AM
  #1038
JimBrown
JimBrown's Avatar
Would anyone know where I could order some 90 degree elbow barb fittings to replace these ones?
...jim
Old 12-09-2016, 11:01 AM
  #1039
TonyBuilder
...jim
That's the nipple that points strait down into the rib and pinches. You will have to grind that rib down with a dermal. Or find a 90 to replace it, let us know if you find one!
TB
Old 12-09-2016, 12:53 PM
  #1040
myersflyers
My Feedback: (33)
...jim
I think the 1/6 MNPT x 5/64 barb what you "might" require, check Zoro.
https://www.zoro.com/search?category...UMADYNE+INC&q=
Rgds,
Keith
Old 12-09-2016, 02:23 PM
  #1041
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
Zoro is good, I just got 15% off my turbine oil from them by adding a small item to the order.
  #1042
smchale
My Feedback: (67)
smchale's Avatar
Just need some color on the tanks/pylons now. Been putting a detailed set of instructions together and should have them available after the holidays if anyone is interested.
ID:	2192854   Click image for larger version
ID:	2192855   Click image for larger version
Old 12-09-2016, 02:28 PM
  #1043
JimBrown
JimBrown's Avatar
It's been a while since I posted an update... So here's one!
I'm a bit slow when it comes to building (or assembling) but some progress has been made. Mainly I've been 3D printing various bits. This is a bit time consuming as I have to design the bit, print it, test fit it, modify the design, print it again, test it again, etc, etc. Printing with a $500 DIY Chinese printer is not the fastest. ;-)
Anyway, here's some pics on what's been done.
...jim
ID:	2192857   Click image for larger version
ID:	2192858   Click image for larger version
ID:	2192859   Click image for larger version
ID:	2192860   Click image for larger version
ID:	2192861   Click image for larger version
ID:	2192862   Click image for larger version
ID:	2192863   Click image for larger version
ID:	2192865   Click image for larger version
Old 12-09-2016, 03:53 PM
  #1044
rcpete347
My Feedback: (251)
rcpete347's Avatar
Looks good Jim.
A pic of my next T-1
Rcpete
ID:	2192868   Click image for larger version
Old 12-09-2016, 03:57 PM
  #1045
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
The gear door standoff looks great! Well done.
Old 12-09-2016, 04:26 PM
  #1046
paulhat
...jim
Love the printed parts Jim!!
and out of a 500 dollar printer..pretty impressive
Old 12-09-2016, 04:32 PM
  #1047
Craig B.
Sean, your workshop is disgustingly neat....you are putting us to shame!
Old 12-09-2016, 10:07 PM
  #1048
flejter1
flejter1's Avatar
I have to agree!! Sean, I need you to stop over and help me with a small project, bring cleaning supplies!!
Old 12-09-2016, 10:27 PM
  #1049
flejter1
flejter1's Avatar
So here is the latest factory news, hot off the press!!
The factory has finally completed the move and is gearing up the production line. The new factory paint booth was not up to standards and was unfortunately found out too late and a few airframes were lost because of it. I was very impressed that they did not try to salvage them and let an inferior plane leave the factory. I was just as sad, as that put us further behind once again. Barry, myself and the factory, would like to thank everyone that has paid orders for being patient and understanding all the delays we have encountered. We will pick up sending orders in the que as they were placed. The factory hired another Master Painter and they are training new employees to help increase production. I know everyone reading this, has assembled or actually scratch built a plane and knows training new people to build a plane is not an overnight feat. Our quality WILL NOT be compromised from new employees, as they are under strict supervision. Anyone that has touched, flown or saw a T-1, knows this plane is SO WORTH THE WAIT!! With that being said, our offer still stands, anyone with a paid order that does not want to wait, please let me know and I will refund your $$ within the hour. Before you all bombard me with "when is my plane going to be done" questions, let's let the factory get producing for a week or two so I can get a pulse on production and forecast a true delivery date for you.
Regards,
Dirk
[email protected]
Old 12-10-2016, 01:46 AM
  #1050
jedda747
Some progress on our T1 which i believe is the first in Australia
will have an ATJ 140 going in
ID:	2192899   Click image for larger version
ID:	2192900   Click image for larger version
ID:	2192901   Click image for larger version
ID:	2192902   Click image for larger version
ID:	2192903   Click image for larger version
ID:	2192904   Click image for larger version
ID:	2192905   Click image for larger version
