Reload this Page >
Bavarian Demon Cortex PRO is here!!
Old 06-27-2023, 10:46 AM
  #1001
mongo
My Feedback: (15)
mongo's Avatar
hope that the 1 lb is the density of the material, and not the weight of the hush box...
Old 10-14-2023, 08:46 AM
  #1002
natxo
Hello
I'm looking to install a cortex pro on a rebel hot, i read the pdf from bavarian and some info on the net, please excuse me if i'm going to ask something that has previously replied.
I fly with Jeti and i have on the plane (11 slots):
+ elevator channel (2 servos)
+ rudder channel
+ aileron channel (2 servos)
+ flap channel (2 servos)
+ retract channel
+ brake channel
+ nose gear channel
+ turbine throttle
+ AG63 pro brake steering gyro.
If i understand cortex correctly i can have using serial ports:
+ one receiver on port B and 7 stabilized channels
+ add a redundant receiver on port A and have 6 stabilized channels
As i want to stabilize elevator (2 servos), ailerons (2 servos), rudder (1 servo) i will use 5 slots on the cortex and i will need 6 slots on jeti receiver (so min i need a REX6 and if i want a redundant receiver i can use a rsat?).
Is this correct? I wanted to use the minimal amount of devices, anyway i can reduce the amount of elements? How can i deal with the cortex and AG63pro?
Regards,
Jose
Old 10-14-2023, 11:03 AM
  #1003
Bob_B
Bob_B's Avatar
Loose the AG63, just run the nose gear steering servo through the cortex.
limit your brake power using the function curve in your Tx.
tp777fo (10-15-2023)
Old 10-14-2023, 11:37 AM
  #1004
natxo
Thank you Bob, with the AG63 plane brakes straight as an arrow...i would like to preserve that function
Old 10-14-2023, 01:11 PM
  #1005
Bob_B
Bob_B's Avatar
Then just use the cortex for flight functions, simple.
Old 10-14-2023, 04:07 PM
  #1006
Dansy
My Feedback: (53)
Dansy's Avatar
Originally Posted by natxo
Hello
+ rudder channel
+ retract channel
+ brake channel
+ nose gear channel
+ turbine throttle
Regards,
Jose
‘Actually the cortex pro will stabilize the 16 first channels of the ExBus signal from the receiver…..that the gain has to be in the first 16 as well….
Skunkwrks (10-17-2023)
Old 10-18-2023, 02:11 AM
  #1007
natxo
Thank you, i think i got it, cortex is on order and will be installed soon
Regards,
Jose
Old 11-17-2023, 07:44 AM
  #1008
roydefiant
When settling up cortex pro I have 3 different flight modes. In the landing mode I’m planning on programming in some crow on ailerons.
Does anything special need to be done so the demon cortex pro will function properly in landing flight mode when crow is active?
Old 11-17-2023, 07:57 AM
  #1009
jvaliensi
Hi - I do the same. I teach the cortex pro in cruise mode. I have different gains associated with each flight mode. I find 30% for Cruise, 40% for take-off and 60% for landing is a good starting point.
Old 11-17-2023, 08:32 AM
  #1010
roydefiant
That makes sense as I know from previous experience experience with my Jeti the trim settings are independent in each flight mode. Just wasn’t sure when using butterfly/crow in the programming if it would make a difference. Easy to figure out
Old 11-17-2023, 05:18 PM
  #1011
Dansy
My Feedback: (53)
Dansy's Avatar
I used crow on land flap nothing special to do, doesn’t change the basic of the CP
Old 11-21-2023, 11:22 PM
  #1012
FlyJ
EDIT WITH SOLUTION: Turns out I needed to reteach the signal type with both receivers plugged in. Simple fix. I must have taught the gyro with only one receiver was plugged in the first time. Works great now.
I’m running a cortex pro in combination with a pioneer and having some issues. I’ve got two receivers connected ports A & B, and two outputs from ports 5 & 6 connected to the pioneer RX 1 & RX 2. All controls work and the gyro has been taught.
The issue I’m having is that I’m only getting data out from port 6. I can unplug either receiver, and everything still functions. If I were to unplug the line from port 6, it goes into failsafe. How do I set the cortex to run with 2 data outputs?
Old 11-22-2023, 05:19 PM
  #1013
Dansy
My Feedback: (53)
Dansy's Avatar
‘I’m pretty sure it’s a PowerBox thing, works fine with the CB’s
Old 11-23-2023, 02:41 PM
  #1014
F900
Hoping one day Jonathan from the LSRC has a tutorial from Spektrum users as he did for Jeti. I want to get away from the AS3000 since its getting dated and who knows when to new gyros get released.
I know its fairly simple it's just a lot easier to me to watch and learn.
Canadian Man (02-27-2024)
Old 11-23-2023, 05:40 PM
  #1015
Dansy
My Feedback: (53)
Dansy's Avatar
‘Actually I saw an announcement about there new gyro AS6000 a few days ago….
Old 02-26-2024, 08:12 AM
  #1016
Afterburners
Afterburners's Avatar
I'm in the midst of converting a jet over to Jeti. It has a Cortex Pro going into a Powerbox Competition. I have two R3 rx's going in to the Cortex using Ex bus. Just trying to find out if anyone has successfully setup throttle failsafe using Jeti with the Cortex and Powerbox. From the Cortex manual, it seems you can't really get failsafe to operate due to the EX bus lack of sending out a "true" failsafe signal that the Cortex can see? The text below seems to imply that you can set failsafe positions in the Cortex which I can't seem to find when bringing up the software and from the second line it implies that the internal failsafe wouldn't work if you lose communication between the Rx and the Tx which doesn't really seem like a great failsafe? This is the only plane I have a Cortex in. Everything else is working fine but it's meaningless if I can't get a FS working. Thanks. From the Cortex manual....
FAILSAFE
For every single channel run through the system, no matter if stabilized or not, a failsafe value can be defined. To use this option, set all transmitter channels to the desired values, followed by a click on the software‘s button ‚Learn failsafe values‘. Done.
Note: The internal failsafe will only be activated, if there is no „proper“ signal received from the receiver (e.g. connection cut between receiver and system). Thus, if there is a failure in the link between transmitter and receiver, and the receiver‘s failsafe is activated, the system‘s failsafe will not activate.
Note: The internal failsafe is NOT available form Jeti EX.bus, as this protocol does not feature a failsafe information for following devices. This is taken care about by the CentralBox.
Old 02-26-2024, 01:01 PM
  #1017
F1 Rocket
Failsafe should be set in what ever the servo or device is physically connected to.
Old 02-27-2024, 01:09 PM
  #1018
Afterburners
Thanks Danny. Continued messing with it today and really couldn't tell if it was the Cortex or Powerbox giving me the issue and was almost ready to try a CB 210 when I decided to see if there was an update to the Competition which there was. Don't really know what the update fixed as they don't tell you but it solved the problem as I had always had the f/s set in the powerbox but it didn't work. When I had it working with the Futaba setup years ago, it only worked when setting the failsafe on the throttle in the Tx which was good enough to know it would shutdown when needed so I never pursued the issue as it was "good enough". Apparently with Jeti EX protocol, it wasn't and I needed to get the issue resolved with the PB.
Old 04-07-2024, 02:22 PM
  #1019
tuskegee
tuskegee's Avatar
Default Program Cortex Pro to (Futaba) receiver 3008SB Power hub DLPH-1
How do you do the programming to the TOne F-16 1/8th with the Futaba BUS T16IZ../R3008SB(x2) Cortex Pro../DLPH-1
this is my first jet setup.
thanks,
Old 04-08-2024, 04:36 AM
  #1020
mikes68charger
My Feedback: (34)
SBus each receiver directly to pro port 1-2 and out to expander DLPH-1. You have to change pro to SBus signal with bind plug. Read pro directions really easy
Unfortunately if you are doing telemetry you have to plug directly into one of the receivers. The cortex dose not processed SBus2 only SBus
tuskegee (04-08-2024)
