New Sport Jet: T-One Models Mini Fortune / Mini T1
#1451
Both of mine are around 17.5 lbs (UAT full, dry main) give or take a couple of ounces. Both with K85, no smoke, single tanks. One with PB mercury, the other with CB200 (I know this is overkill...), 2x2600 mah 2S Lipo, 1x2100 mah 3SLiFe. JP retracts with Xicoy controller. I've seen folks post dry weights under 15 lbs, mine also always seem to be on the heavier side -Tom
Afterburners (05-13-2020)
#1453
NJ
Getting ready to maiden my t-1 mini, have the flaps assigned to flight modes for now so I can trim elevator to flaps. Should I trim elevator to give level flight when flaps are down or should it have a tick or two of nose down attitude so I don't stall the wing on approach ?
#1454
My Feedback: (53)
#1455
I agree, I trim to level flight in all three flap settings. Because its difficult to gauge approach speed I try to keep a slightly low nose attitude during the entire approach but I do so consciously with a little down elevator; I feel like I'm developing better habits if I put the down elevator in manually verses a little down elevator trim but that's just me, we should each do what works best for each of us. I use throttle to control the approach angle. Good luck on the maiden, post some video if able! -Tom
#1456
Regarding flap trim, I trim the model for level flight in all three flap configurations. For half flap and for full flap, I trim it with the throttle set at about ⅓ of full throttle. With full flaps on final approach, as I reduce throttle below ⅓ the model then naturally sinks on its own.
Randy
#1457
My Feedback: (46)
Does anyone happen to have pics of the inside of their pipe with 40 or more flights on their plane? I had to pull the engine and when I went to put it back in I thought I was seeing the pipe was discolored about 3-4” from the engine exhaust cone. But now what I’m thinking it’s it’s burnt oil residue? I ran a rag down there with some alcohol on it and it does appear to be oil residue. The pipe is brown underneath it but I think that’s from the oil. Is that normal? First jet so I don’t really know. Engine was sent out for service after a flameout.
#1460
#1461
My Feedback: (46)
Same here. One question though, do you have a smoke system? If yes, do you have your smoke oil nozzle placed at the engine exhaust or at the tail pipe exhaust? Only one of my jets has smoke and I have the smoke oil nozzle at the back of the tail pipe to avoid getting smoke oil residue in the exhaust tube (even though it would probably all burn off). -Tom
#1462
My Feedback: (53)
On thing is, I used smoke fluid not diesel/oil mix.....I would never do behind the motor with the diesel stuff......
#1463
Finally got my maiden in today along with my F-16. The Mini flew great although I found the recommended throws a bit too sensitive. I also found the stock brakes with Xicoy LG-15 controller to work fine. Came to a smooth straight stop. Hopefully get a few more flights in tomorrow.
The following 2 users liked this post by Afterburners:
bodywerks (05-25-2020),
Randy Smith (05-24-2020)
#1466
Thanks. Yes, with my not so great vision I picked the red as I have a Mini Avanti EDF in red and I can see that well. If I could see better, I probably would have went with the blue or Red Bull schemes. Been flying for about twenty four years and this is my first plane with smoke. They made it easy having the two tanks in the plane and although I've only had four flights so far, it looks like I can do an easy seven minutes with enough for a few go arounds and that's plenty of time for me.
#1468
I am not currently running smoke. I use the upper smoke tank as my Taxi/run-up tank. I fill the upper tank with about ½ inch of fuel. I start up, run up, and taxi out to take off. Timer starts on throttle up to take off. I have my timer set to 7:30 and I fly between ¾ and full throttle all the time. I usually do one missed approach practice pass and land with about 20% fuel left in the main. I'm running K-85. I have 32 flights on my Mini now and I'm starting to really get confident with it. I really love the way it flies.
R
R
#1470
WINDEX works great. not generic... but real windex. The blue stuff.
#1472
My Feedback: (46)
K2r SPOTLIFTER
#1473
My Feedback: (28)
I know a lot of people have used this to pull glow fuel out of wood. (Myself included)
K2r SPOTLIFTER
K2r SPOTLIFTER
