Powerbox Core radio and set up thread.
#1776
![](/forum/images/badges/premium_member.png)
Hi
I have 2 PBR-26D connected to the Mercury SR2 .
I could update the 2 PBR-26D via the ATOM.
What about the Mercury SR2 . I don't think it can be done via the ATOM as well .
If not ,what should be the procedure ?
regards
Alain
regards
Alain
#1780
Thank you
what about Operating system, transceiver and Stickcontroller Update on the Settings/System/Software on the Atom transmitter? When I touch the boxes ,it is all about recovery ,not update to a new version.
BTW,what is a Transceiver ?
#1782
Thank you
I tried to update the Mercury via the Jeti USB adapter but no way to select the 'Update' item from the small screen menu to take control from my PC.
Page 10 of the Mercury SR2 instruction manual , I can read Reset/update as an option but the screen does not show the Update option inside the Reset sub menu...
#1783
I've just started experimenting with Attitude Assist on my AF MB-339, when I enable it on ailerons, the jet seems to roll slower at the same stick position as it would in Range A. Do others find this, and therefore reduce expo on Range B to compensate?
Racer686 (08-04-2023)
#1785
My Feedback: (7)
Thank you
#1787
Hello All, can I please ask when using this PB radio, how it's best to view/diagnose flight telemetry data after you have completed numerous flights for the day, etc? Reference to a post# would be easiest, BRG, Frank
Springbok Flyer (08-21-2023)
#1788
![](/forum/images/badges/premium_vendor.png)
Best to review after a flight, when you turn everything off it resets the values unless you want to start pulling logs and looking at it on a laptop.
The cumulative stuff like capacity used don't reset until you reset them but LQ and that that to look at signal performance reset with each power cycle
#1790
Hello Gents, thanks for your replies.
skunkwurk - perfect, just what I need. I'm assuming that PB Terminal is the only way that RSSI/LQ data from previous flights can be viewed and this cannot be done with the Core Transmitter screen?
When using PB Terminal is it simply a case of connecting a USB cable?
BRG, Frank
BRG, Frank
#1791
My Feedback: (18)
BRG, Frank
BRG, Frank
Springbok Flyer (08-22-2023)
Springbok Flyer (08-23-2023)
#1793
Hello All, just a quick update here, and a brief account.
I had flown on the weekend and noticed a glitch on the last flight of the day when using my PB radio. Having used numerous brand 2.4 GHz radios for close to 15 years, with a perfect record, I was curious as to why I had an "event" with this particular radio...
I could clearly see that after downloading and viewing the log file with PB Terminal, the RSSI of the receiver had briefly gone through the floor on the last flight...at the exact same epoc for the same flight, the telemetry for the RX battery voltage had briefly dropped to a very low level (caused, I'm guessing, by the very fast set of rolls I had just performed - high load on servos)
It's great to be in a position where you can rule out any theories, and immediately uncover the root cause of an issue - no doubt I will investigate further, I'm guessing a faulty battery...
The lesson here is that basic post-flight checks can only glean so much information, viewing detailed log files usually tells the remainder of the story.
BRG, Frank
BRG, Frank
The following 2 users liked this post by frankie:
AEROSHELDON (08-23-2023),
#1794
BRG, Frank
BRG, Frank
Go one better and utilise your telemetry and set RX batt warnings on your TX , no point waiting till after the event to find the sometimes fatal cause.
The following 2 users liked this post by raydar:
jcterrettaz (08-24-2023),
Skunkwrks (09-03-2023)
#1795
Good point my friend, problem is that I already had...
I'm guessing that I had set the voltage too low/wrong
anywhere in the manual recommending voltage thresholds for different battery cell counts/capacities/chemistry types?
Cheers
Cheers
#1796
![](/forum/images/badges/trading_plus_member.png)
Delighted to see that Core is now a world masters winner!
Adrian Senn used Core in his de H Vampire T11 to win the 15 kg class.
Some of you guys may have seen the Lighter side of rc video comparing radios, in which he slams Core. He clearly does not understand RF propagation using patch antennae
#1797
Don't let factual engineering principles get in the way of more Youtube hits....
I gather he was trying to do the right thing, but just very poorly executed due to lack of knowledge in that area.
No different to when he unfortunately lost a jet recently by mounting a switch-mode lighting controller right up against a VSpeak module... Not something someone would do if you knew that all switch-mode devices produce electrical/RF noise (interference) when not well filtered.
#1799
If he was getting poor range results, ( despite the PB, justifiable, claims of extreme range) then the reasonable course of action would have been to discuss the issue with PB. That was not done.
He did not seem to notice that the Core uses patch antennae which have a very different radiation patterns to monopoles as used on other radios. Holding the Tx high above head was exactly NOT the right thing to do, it would point the radiation away from the rx. worsening the situation.
I discussed at length the use of patch antennae with Weatronics engineers who also advised me that even greater range could be obtained using patches as rx aerials. I trialled this using one patch and one whip on a Weatronics gizmo receiver. They were right, and I now use patches on three Hawks and aMig 29. which each together give a spherical reception pattern and perfect operation at any range and attitude. That was about 10 years ago and the newer PB receivers are such that patches are not required , or give any real benefit, so are not neccesary.
Talking to a RF professional it seems I have been using patches for years without knowing it, they are a key component on low range radalts ( in 4 Ghz band) a key component in autoland equipment which I have used on many occasions on various Boeings, 73, 75 and 76, in Cat 2 and 3 conditions !
There is a great deal of learned info on patch antennae on the internet, particularly on radiation patterns, PB use them on the Core and Atom for very good reasons !
