Reload this Page >
Aviation Design Diamond Assembly!
Old 12-13-2020, 06:30 AM
  #76
Canadian Man
Canadian Man's Avatar
Skunkwrks (12-13-2020)
Old 12-13-2020, 05:37 PM
  #77
sysiek
My Feedback: (176)
sysiek's Avatar
Will you please calculate all the materials and equipment used to build the jet with prices this will help someone when building diamond jet , to maybe cut on some stuff to stay below $20000 , I build 3 of them and never got so expensive and I used good stuff, I’m going to post building forum for nr 4 same color orange
Old 12-13-2020, 06:54 PM
  #78
Canadian Man
Keep in mind that i'm located in Canada. So when I buy an airframe as an example that's listed at $3000.00 USD it actually costs me $4000.00 CAD. Approximate of course. So sure my build may have cost $14,000 USD.
Old 12-14-2020, 07:45 AM
  #79
Dansy
My Feedback: (53)
Dansy's Avatar
Very hard to impossible to build a 210+ size under 20k the exchange rate and taxes pretty high....plus now broker fees extra cost in shipping....ect...
Canadian Man (12-14-2020)
Old 12-14-2020, 08:41 AM
  #80
Canadian Man
Unhappy
Yea totally! Shipping and duty alone was $1,622.00
Old 12-16-2020, 11:20 AM
  #81
Canadian Man
Smoke tank from CMJETS.com!
Preping smoke tank with tabs. Would work fine to sit on the bottom of the fuse but the skin is flexible so I would rather have the former work supporting the weight.
opened up the opening about 1/4" on 3 sides for tank to fit.
Custom Skycandy Lighting setup. Missing nose gear light in picture. Wait till you see these things.
Old 12-16-2020, 11:22 AM
  #82
Canadian Man
Decided to take molds of all the tips.
Remaining silicone in the cup works great for epoxy mixing trays. Next day, peel it off and reuse.
Old 12-16-2020, 11:25 AM
  #83
Canadian Man
The Mess before organizing and crimping wire ends on.
The finished product.
finished equipment tray except smoke fill and supply lines.
Skunkwrks (12-16-2020)
Old 12-16-2020, 11:27 AM
  #84
Canadian Man
Silicone added to tanks to keep in place. If removal is required later feed fishing line or safety wire under and it will slice through.
bit more oranizing.
Old 12-16-2020, 11:29 AM
  #85
Canadian Man
Nose weight a non issue and needed to get batteries as far forward in tray as possible. Glued some spare carbon tubes on the underside of the nose.
Final Battery placement. Space at front of tray for stick on Lead weights.
Nose cone mounted. Decided to keep it simple and use 5 servo screws.
Old 12-16-2020, 11:32 AM
  #86
Canadian Man
Weight prior to nose weight added. UAT Full. 1" of fuel in tanks.
C of G at 312mm back from leading edge/root of wing.
Final weight with nose weight added.
  #87
Skunkwrks
Skunkwrks's Avatar
Great work Jonathan can't wait to her fly and see that Kingtech opened up, it will be great
Old 12-16-2020, 11:34 AM
  #88
Canadian Man
Engine Run! and some other small items.
Old 12-19-2020, 04:01 PM
  #89
Canadian Man
Old 12-19-2020, 06:27 PM
  #90
camss69
My Feedback: (46)
camss69's Avatar
Nice! I can't wait to see the video of it on final with those lights.. I just put lights on my newest build and I'm wondering how distracting they will be lol.
Old 12-19-2020, 07:46 PM
  #91
sysiek
My Feedback: (176)
sysiek's Avatar
The light looking so good, I have two sets on the radio flyer and they look good but yours are much better looking, so test and make the clear stuff flat finish this will make the best light effect just like the milky car led light.
Canadian Man (01-26-2021)
Old 12-20-2020, 06:44 AM
  #92
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Your Radio Flyer looks nice - it looks scale.
Old 12-20-2020, 06:53 AM
  #93
sysiek
My Feedback: (176)
sysiek's Avatar
I’m not sure but I think that actually aviation design is working on a full scale diamond but this is just not confirmed news, this will be actually very attractive jet much nicer than viper and probably faster and with using smaller turbine with longer range maybe two tandem seats,
Old 12-21-2020, 08:22 AM
  #94
Canadian Man
Very cool light layout! I think I was watching one of your videos on your channel with this flying last night! I do like that layout as well!
Old 12-21-2020, 08:24 AM
  #95
Canadian Man
What a hoot that would be to see one of these (full size) taking off at an airport!
Old 12-21-2020, 08:46 AM
  #96
Canadian Man
used plaster of paris to make plugs
Plugs complete
First pulls I was struggling with webbing.
My Genius Daughter came up with the solution which was to add risers or "Bucks" under the points!
Old 12-21-2020, 08:53 AM
  #97
Canadian Man
Cutting off a perfectly good tip!
Test fitting the lenses.
Front landing light wire and electronics installed.
Front landing light glued to front strut with Hysol
Belly Strobe installed! This thing is Bonkers!
Inside shot of the belly strobe.
Old 12-21-2020, 08:58 AM
  #98
Canadian Man
Marker lights installed and glued.
Front tip light installed.
Finished marker light. Glued in place with "Goop" so if ever needed it is removable with some manipulation
Old 12-21-2020, 09:02 AM
  #99
Canadian Man
glued the CC voltage regulator about 3" inside the opening and left the extension loose. Connector is easy to get at if ever needed.
to mark line on lens. Held sharpie on lens and spun the tip.
Old 12-21-2020, 09:05 AM
  #100
Canadian Man
lens installed with tape and paint line installed
Painted the glue area with color matched paint. Same paint installed on the servo coveres
Lens glued in place with E6000 glue. Very similar to Goop but a bit more runny.
Finished product. Was deciding if I should paint the white line but I will do that.
