VELOX.. Build thread with Photo's..
#452
RE: VELOX.. Build thread with Photo's..
ORIGINAL: RCISFUN
Any reports?
ORIGINAL: jephry
I am about to maiden mine this week! Changing out the Aileron servos from Hitec 5125 to 645MG
Ailerons: 2x JR DS3421MG
Ruders: 2x JR DS3421MG
Steering: 1x JR DS3421MG
Flaps: 2x JR DS8711 + 1x Match Box
Elevator: JR DS8711
Retract Valve: JR DS285MG
2x Flight Power EON 2S1P - 2100mAh + FT8AVR Regulator 8A FlightTech - Servos
1x Flight Power Evo 2S1P - 3700mAh - Turbine
Jet-tronic Low Loss Brake Valve
Turbine - JetCat P-80SE
Radio: JR 12X
Receiver: JR R1222 12 Channel DSM2 Powersafe Receiver
That is it!! If I forgot something tell me!!
Cheers..
Ciro Moreira
#453
ORIGINAL: RCISFUN
Any reports?
ORIGINAL: jephry
Did not manage to do a maiden. My engine will be sent back for inspection.
When try to throttle up the RPM drops and started to throw fire & also noticed a high pitch whining sound
#454
My Feedback: (44)
ORIGINAL: jephry
Hey,
ORIGINAL: RCISFUN
Any reports?
ORIGINAL: jephry
I know what that is..happened on my RAM 500...compressor clearances are shot!!!!
This causes a rich fuel mixture (too much fuel not enough air) = FLAMES out the tail pipe [][]
Most likely it will start and idle fine, then when you advance the power all heck breaks loose....
Did you inspect your compressor wheel, by chance are there any blades missing?
#455
ORIGINAL: RCISFUN
You are spot on!! I am suspecting the wheel might be out of balance as there is some vibration during start up. Anyway have spoken to factory, Am told to sent it back..
Argh.. so now back to repairing my F15 & also start work on my formost!!
#456
Hi
I tested mine this weekend and flew really great - CG is on the pins - I did get a bit of a cobra type stalll on the 2nd landing resulting in a hard landing - this seemed to of happened very easily which is quiet worrying - can anyone tell if moving the CG further forward will reduce the chances of this happening again, even if it means flying with a bit of elevator trim ?
Jack
Jack
#459
ORIGINAL: frizlot
Hi Rich
I cant seem to see anything on your attachment ?
Regards
Jack
Hi Rich
Regards
Jack
For me the attachment is OK!
Try to download the latest version from Adobe!
Ciro Moreira
#460
My Feedback: (44)
ORIGINAL: ciromoreira
Hey Jack!
Ciro Moreira
ORIGINAL: frizlot
Hi Rich
Regards
Jack
Hi Rich
Regards
Jack
Ciro Moreira
#462
Hi All
Can anyone tell me if the "cobra thing" also happens with a flaps up landing and if so is it more or less violent.
Regards
Jack
Regards
Jack
#463
QC, CANADA
By my understanding, cobra is cause by a wing stall from the tip on a delta wing, wich mean a stall by behind… So the main cause is if you put the plane in a nose up position, it is worst at low-speed as any stall is. Also, the design of the Velox look like to have the elevator hidden by the main wing (or body) or whatever, so sometime the elevator is losing is efficiency, wich doesn’t give you enough “control†to get it back or just old it stable… I did add some wingfence on mine + a mix on the aileron (elevon mix), but I didn’t have the time to test it… I should do it very soon (lets say a the beginning of may)… Then I will give you a full report…
BUT to answer to question, I think if you use flap up, you will increase (by a lot) your landing speed so it may help not doing a Cobra, but it will be more hard to land it… But if you try it, let me know, I may try it too…
Here is a picture of my modifications (you could see the wingfences (black) on the wings)….
#464
I will be very interested to hear how the wing fence works - I was thinking that as the plane slows down (with flaps deployed and a up elevator correction programmed) the need for the up elevator correction is reduced sharply due to reduced airflow over the flaps and because the correction programed in it will throw the nose up and increase the chance of a cobra - hope that makes sense.
I would like to try a landing with flaps, but no programmed correction instead manually apply it. This might give a better feel.
What do you think ?
What do you think ?
#465
Hi Robin
One other thing. Do you have a drawing of the fences you fitted and maybe some dimensions so I can get some laser cut ?
Regards
Regards
#466
QC, CANADA
The main idea of the wingfences is to keep the air flow under and over the wing a hi AOA (instead of flowing on the border of attack to the wing tip and then “escaping the wingâ€), this is suppose to “reduce†the stall point, in fact it’s not really doing it because of numerous aerodynamic reasons, but it does provide a more stable control on hi AOA and it’s suppose to increase the AOA before stall…
AND YES I do have a Solid Edge plan (2d) of it, I will post it here after the RE-Maiden at the beginning of may. Because the velox did flew a couple of time, but it never did it with the fences... So I prefer test it before giving the design to any one... ;-)...
Having flap down (and then elevator up) should reduce the speed (air brake) and increase the lift, it’s good as long as you don’t nose up… Having flap up (and then ele down) should reduce the speed too (air brake), but will probably reduce lift, so you may need more speed to land securely, I really don’t know, it have to be try…
For me having to deal with the flap, and the elevator while landing is too much … So I did mix the elevator correction, and I added a trim/adjustment slider (14mz) so that I am able to ajust the mix while in flight so that when I’m landing the mix is nearly perfect, then all I have to do is to deal with the pre-program flap (0%, 35% and 100%) on a 3 positions switch (where the other mix deal with the elevator)…
#467
My Feedback: (44)
Robin
I will also be interested in your test, I have my Velox in deep storage at the moment, it is a back up jet just in case I need it.
My question is how will the wing fence help eliminate the Cobra? or wasn't that your intention.
As mentioned the cobra is caused by elevator blanking from high AOA
#468
QC, CANADA
As I said before, I think the codra is not only cause by hidden elevator… But your true, having the elevator hidden, remove not only is control ability from the equation, but also its lift, then that’s make the plane to drop from behind…
So the Wingfences are there to help maintaining or give a better airflow on the aileron which now acte as elevon (then will help the elevator to CONTROL the axis), but not reduce the cobra. I think it may help a little bit to move forward the CG, or at least may help making it less violent (having less weight in the back of the plane, the go down effect may be slower…). The fences may also help reduce the stalling part (from behind) of plane… But the rule number one of this airplane still remain to not make high AOA.
But why are we making HI AOA landing ? It’s to do slow landing, then having flap mixed with elevator (to keep a normal AOA), will reduce the speed by acting as airbrake, then slowing your landing… It is not an F16, so just keep it nose down, it “should†be ok…
I know it’s NOT as good as the bobcat or any other boom tail, but still in fly it’s a very good airplane with the elevon mixe…
I will make a full report after the RE-Maiden in a few weeks...
#470
Dear guys,
My first flight with jets was with my Velox, I was so nervous and all my servos are JR, only 2 servos I already have in home was Futaba 3305 and I put these on Flaps, and on the first flight (me and airplane) 1 servo (Flap) burned and I had to land without flaps, could you imagine how my legs and fingers was tremendous??? So, I came so fast to land and got a jump on the floor, after this, the airplane made a "Cobra", you can see this on Youtube, a friend did a video with a Cybershot, from my first flight, and at the end you can see the cobra on a medium speed! This is the video:
[youtube]http://www.youtube.com/watch?v=A5QN2FwTXM0[/youtube]
Now I have more videos in HD quality from inside the plane flying on 300ft runway! > http://www.youtube.com/user/ciraum07#p/u
Thank you!
Cheers
Ciro Moreira
Thank you!
Cheers
Ciro Moreira
#471
My Feedback: (44)
Ciro
All I can say is WOW!!!! [X(] [X(]
That was your very first Turbine Flight and it was with a Velox....Well Done!!!
I don't know how you could concentrate on flying with all of the children in the back ground laughing and making noise, your concentration levels must be very high...
Congratulations and may you have many more successful flights.
From what I could see in the video after your bounce on the run way you had a very high AOA...hence the dreaded Cobra, you were very lucky that you were able to get the power back on in time before striking the runway again.
#472
ORIGINAL: RCISFUN
Ciro
Ciro
Yes, it was so hard to concentrate with a lot of children and noise, but, I was so nervous and concentrated that I just listened the airplane, and the Cobra happened because I took out the fingers from elevator/aileron stick to brake key, at this time, I pushed nose down with full throttle, and tryed to get out from stall. After that, I kissed my 21lbs JetCat appreciating the quick response
Thanks!
Cheers
Ciro Moreira
#473
Well done, Ciro! Nice flight.
Despite all the hype talked about the Velox's flight characteristics, I find it a great model to fly and have just put mine into temporary retirement after 197 flights.
May yours enjoy a long life and give you plenty of fun!
Cheers,
Dick
England
Cheers,
Dick
England
#474
ORIGINAL: CJ2002
Cheers,
Dick
England
Cheers,
Dick
England
I love this plane!!! It is really fast and sweet to fly, now I´m using another config to land, Flap position 1 = 25º, Flap position 2 = 40º + Ailerons Butterfly > WOW!!!! It comes on the rails, lots of friends asked me to sell this plane for them, but I will fly a lot yet, I really love this model. I have a NIB Super Bandit, but our place it´s a little bit short, runway 300ft (120m), impossible to fly Bandit on this, but the Velox I use more or less 70m to land, it is wonderfull!!!
You can see my videos on Youtube in HD, all them camera onboard, type: Ciro Moreira on Youtube and you can see our runway!
Thanks again Dick!
Cheers
Ciro Moreira
#475
Hi Ciro
Can you please tell me how much butterfly or crow and how much elevator correction you have mixed with each flap setting, or may be all you travels and settings if possible - I am waiting for some decent oleos to arrive for mine, then I can test again.
Regards
Jack
Regards
Jack
