Composite ARF Tucano Build
#551
Dear all
Happy Christmas - stay healthy!
I started working on my TUC.
Unfortunately the holes of the elevators which should match with the carbon fiber stab are not in line! Have you made same experiences? I already contacted CARF waiting for a reply.
gbarnes (12-27-2020)
#555
#556
#557
yes: it is a brass tube. There is a hole in the SPT exhaust. The brass tube is solded on a rectangular brass plate in order to get the tube fixed.
hope this helps?
#559
mautro (12-28-2020)
#562
#563
This is how I did mine.....a few years ago. Still working great!
Here are a few photo's of how the smoke tubes are done on my CARF Tucano with JetCat SPT5 Turboprop. The coils inside the exhaust stacks really work well as the smoke oils is heated up before it is sprayed into the exhaust which helps greatly to vapourise the oils easily. You will also notice that the spray nozzle is flattened and bent back towards the exit of the exhaust. This was done deliberately to make sure the turbine will not get flooded with oil whilst on idle during a diving manoeuvre.
Cheers,
JanR
gbarnes (01-01-2021)
#565
My assumption would be that your geometry won't work out because you are not using the stock plastic arm JRPA 215, and most of those if not all those servos are not available anymore. In the manual, Dave has measured out from the second hole out from the center of the servo of this particular arm. If you want to keep what you have you will most likely need to shorten it and drill for a new hole. Unless you can get the above arm and as well it fits the spline count on your servo. I think you will have to user a shorter arm of that brand of servo you got or modify what you have.
Good luck.
Good luck.
mautro (01-06-2021)
#566
I don’t think that it is a problem caused by the Servo arm. The clevise doesn’t reach the Flap’s arm/Phenolic horn.
This is my problem. It’s not in line. And there is also the tube of the wing which makes it impossible to drill another hole.
And it’s impossible to connect the clevise to the phenolic horn unless I’m totally incapable to do this job
#567
It looks like the horn has been installed too low in the flap at the factory. The horn/hole should be as high up as possible. It’s a pain, but I have seen this before on a Viper, I used a small long drill to work either side of the horn which is bonded into a block. It’s possible to break it out, raise the slot and Hysol back in.
The kit will have serial numbers on each component, make a list of the issues and email your Rep or CARF so they can check when and who assembled this kit.
Dave
Dave
mautro (01-05-2021)
#568
Dave
Dave
#569
Dear all
could somebody post some pics of the linkage connection of the flap and also the position of the Servo? I tried the whole day to find a solution without success.
the red line is the way that the servo rod takes. Vertically up. How to get the flap up to 80mm?
mautro (01-06-2021)
