Reload this Page >
Comp ARF BAE Hawk build thread
Old 08-14-2014, 03:07 AM
  #1901
fireblade5437
fireblade5437's Avatar
Bob
You should have told us how you did the covers! Especially whilst I was re-painting the Hawk
Got any pics of what you did?
Alan
Old 08-14-2014, 03:51 AM
  #1902
izzy
Bob
i was thinking of cutting the covers flat so that i can glue them flush with the elevator edges ( with hysol)
wouls that not be the same as what you did without cutting into the elevators
mine is all white so i will paint it all at once
would grey paint work instead of the aliminium tape ? or does the tape stay on ?
Alan
how did you do your APU ?
Old 08-14-2014, 04:20 AM
  #1903
fireblade5437
Izzy
I used a water waste pipe fitting which was 90degree right bend, now this particular right hand elbow/bend which I use was also perfect as it was a low profile one so the bottom of the bend was flat.
The diameter of the fitting is 1 1/4" or 32mm (31.75mm) I brought the fitting from B&Q (Home Depot in US) same type of store
I would try and get one for you but cannot get out at the moment :-(
I will sketch you a pic and post how I glued in with Hysol, don't forget water pipe fittings are PVC and Hysol will not attach to PVC even if you rough it up. So I created a fillet around the fitting and glued directly to body of aircraft, came out perfect and looks exactly like 1:1 scale
The holsol fillet 'locks' the fitting to the fibreglass body.
Alan
Old 08-14-2014, 04:43 AM
  #1904
rcjetsaok
My Feedback: (7)
rcjetsaok's Avatar
I don't own one of these I have finished out a couple... Smitty's and Joseph's. I have had the pleasure of dealing with the stab covers and have a few ideas that might help you guys that are frustrated. First of all, the covers that come with the kit are good covers, but because of the stab to fuse tolerance it is indeed tight. I have had to thin the covers to at least half thickness to start with. from there I installed(glue) them one at a time starting with the bottom. Install one, put it back on the airplane and check the fit, take off the stab assmy and sand,put on, fit, take off, sand, put on fit,take off, sand til happy.... you get the idea... Do them one at a time. After a few hours your good to go. As you will figure out, they get closer and tighter with full stab deflection. As Fireblade said, If they would have made the stabs a little wider at the fuse, this wouldn't be such a delimma. Here are a few pics, hard to really tell much from them but you can see the gap difference from the nuetral to full up position. Hope this helps a bit.
Danno
ID:	2022340   Click image for larger version
ID:	2022341   Click image for larger version
ID:	2022342   Click image for larger version
Old 08-24-2014, 05:45 PM
  #1905
mjunior
Here is the first flight.... The jet was not fully ready but enough to fly. Fantastic. Ease, predictable beautyfull. The Merlin 140 did a great job.
Crazy for the next flight
couple of pictures
http://s1076.photobucket.com/user/mv...?sort=2&page=1
Old 08-24-2014, 11:22 PM
  #1906
fireblade5437
Well done with your first flight! This hawk is really predictable in flight and after your first flight you will get more confident with it.
Where abouts have you got your G of G out of interest?
Great pics by the way, spotted the pylon up on the hill on the right !!
Alan
couple of pictures
Old 08-25-2014, 03:53 AM
  #1907
mjunior
Alan,
For the first flight I set the CG at 190mm (only UAT full). All control surface movements were set as per the manual with 30% expo. It took off easily but require a good amount of elevator trim up to keep straight flight at half throttle. After land the elevator trealing edge was around 5mm offset (up) from the initial set up. For the second flight I removed 160gr (around 5,5 ouces??) from the nose. Became better but I didn't measure the right CG position.
Mucio
Old 09-25-2014, 04:40 AM
  #1908
Wclays
My Feedback: (85)
Looking for help.
I have aquired a rebuildable air frame. The wings have the gear out of them, but have found from another RCU user that has provided me, templates for the gear plates.
I am hoping that someone has templates for the nose gear section, that needs reconstruction.
Clay
ID:	2034930   Click image for larger version
Old 09-25-2014, 01:16 PM
  #1909
Dave Wilshere
http://www.highalpha.org/forum/viewt...p?f=31&t=16458
Also CARF can supply them for you. Contact Andy K
Dave
Old 09-25-2014, 04:17 PM
  #1910
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Clay,
It looks like you have enough of the good parts to make new templates, the parts are symmetrical, so you should be able to disassemble and trace them out.
Old 09-25-2014, 05:07 PM
  #1911
Wclays
My Feedback: (85)
I have been trying to get it apart, but it keeps crumbling.
I was looking for short cut, to save some time. If I get it apart I have a guy who can make a drawing for everyone to use. Or I might just post the tracings when I get it done.
Thanks everyone.
Clay
Old 09-28-2014, 06:34 PM
  #1912
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Well we can add another flying hawk to the list, my rebuild Hawk was test flow By Jim Hiller yesterday, he gave it a clean bill of health!
C.G. and throws were according to the manual, I also added crow with flap deployment.
The before photos are on post #733 in this thread.
Old 09-28-2014, 07:34 PM
  #1913
rhklenke
My Feedback: (24)
rhklenke's Avatar
Congrats Rich! Another successful resurrection!
Crow seems to make a big difference in how the model lands - much easier to get it in the "groove" for a soft touchdown with no bouncing...
Bob
Old 09-28-2014, 10:56 PM
  #1914
fireblade5437
Rich
Looks great, all that hard work and hours you did has certainly paid off!
How much crow did you dial in?
Alan
Old 09-29-2014, 12:34 AM
  #1915
Dave Wilshere
One of many models I collected at JP12 was this 2012 scheme Hawk. No had time to unpack it till now, but I'm mighty impressed with the scheme and paint work on this one.
P-140Rxi and probably new JR 28x going in this one
ID:	2035779   Click image for larger version
ID:	2035780   Click image for larger version
ID:	2035781   Click image for larger version
ID:	2035782   Click image for larger version
ID:	2035783   Click image for larger version
ID:	2035784   Click image for larger version
ID:	2035785   Click image for larger version
ID:	2035787   Click image for larger version
Old 09-29-2014, 12:45 AM
  #1916
fireblade5437
Dave
Looks good! How about fitting a cockpit this time?
Alan
Old 09-29-2014, 01:41 AM
  #1917
Dave Wilshere
Its not for me! Its a customers and I'm sure he will fit one...
Old 09-29-2014, 02:17 AM
  #1918
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Originally Posted by fireblade5437
Rich
Alan
Hello Alan,
The crow is between 4 to 5 mm, I also added the wing fences based on what I read on this thread (I made them out of clear polycarbonate) , Jim said it didn't exhibit any bad stall tenancies so I guessed they worked.
I did not put on the lower ventral fins yet as a T-45 did not have those, it seems that the lack of their presence didn't make much difference.
Not sure when i will get to fly again, our weather is getting ready to turn to the bad side!
Old 09-29-2014, 02:47 AM
  #1919
Paul0088
yea Dave will be cockpit, and pilot, looking forward to the build and maybe the new JR 28X,
it's on the bench ready to start..
Old 09-29-2014, 05:59 AM
  #1920
afterburner
My Feedback: (18)
afterburner's Avatar
Congrats Rich. Looks great. Does that have the Rhino?
Old 09-29-2014, 07:45 AM
  #1921
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Thanks Marty,
No the Rhino went into my FB Jets Dolphin prototype that I had at KY Jets.
I had a Jet Central Super Eagle out of another Jet that I sold, so I put that in the Hawk.
It pushes it along just fine!
Old 09-29-2014, 10:52 AM
  #1922
rhklenke
My Feedback: (24)
rhklenke's Avatar
Damn, I should have figured that after we paid them extra to do that scheme that they'd start selling it!
Oh well, at least that one is over in the UK...
Bob
Old 09-30-2014, 03:48 PM
  #1923
Paul0088
Canopy nearly done
ID:	2036374   Click image for larger version
Old 10-01-2014, 04:15 AM
  #1924
Dave Wilshere
I've cut you out one of these....
Old 10-03-2014, 02:22 AM
  #1925
Paul0088
More pics of the new scheme, dry assembly in garden, wing and tail parts all perfect fit.
ID:	2036888   Click image for larger version
ID:	2036889   Click image for larger version
ID:	2036890   Click image for larger version
ID:	2036891   Click image for larger version
ID:	2036892   Click image for larger version
ID:	2036893   Click image for larger version
ID:	2036894   Click image for larger version
