Tomahawk-Design Bae Hawk 1: 3.5
#954
Working on the lights. In the enclosed picture are the black and red wires for a charge jack or for direct hook-up to the battery?
Is the top of the optotronix pro-control for the positive wires or the negative wires?
I assume when you plug this unit into your receiver that when receiver on -- then lights are on and when receiver off then lights are off/
You could try http://www.vogelsang-aeroscale.com/ but I would doubt you will find one in stock anywhere... made to order.
#957
FL
J.C.
#964
That flat rounded rectangle is the 'Collins' antenna that is mounted to the underside of the front section. A few ref pics below. Maybe the fin like pice is the fin in the same shot. Mines in the trash.
#970
Rgds,
Mark
