Reload this Page >
Tomahawk-Design Bae Hawk 1: 3.5
Old 08-29-2014, 10:29 PM
  #1051
LA jetguy
LA jetguy's Avatar
Congrats on the maiden Roy... Glad you are enjoying your Jeti system...just imagine how better the hawk will perform with a Cortex gyro
Old 08-30-2014, 05:03 AM
  #1052
roydefiant
I have a cortex gyro in my shop, just trying to decide what airplane to try it in first.
Scott, the stall speed was 48 mph with the gear down, landing flaps down. Because I put the JMP air panel in the nose (weighs 1 lb) and 2 pilots in cockpit I had to add 3 lbs of lead to tail to get the correct CG but the airplane is still so light and a floater I think the only part of the airplane that knows the difference is the main landing gear. I have been in contact with tomahawk to get the upgrade kit .I am not planning to fly the plane again till I upgrade the main gear as flying off grass currently it is not a question of if you will tear off the strut doors but when. After landing and pushing the airplane back the strut doors at one point were literally digging into the ground
Roy
Old 08-30-2014, 05:16 AM
  #1053
jdrd
Roy,
Congrats on the maiden; awesome to see that black mirror finish in the sky.
She appears to fly like a gentle giant and I can't wait to see future flights.
I love that gentle female voice when gear/flaps are actuated and especally the sexy voice whispering airspeed readouts coming down final for landing. The Jeti telemetry and data log on the screen/voice is awesome.
Great job on that project,
Joe Grice
Old 08-30-2014, 05:20 AM
  #1054
roydefiant
Thanks all.
Here is a picture of me and a CT-115 (hawk) at recent air show in Duluth, MN. As you can see the mains are well sprung on this picture.
Old 08-30-2014, 05:56 AM
  #1055
LA jetguy
LA jetguy's Avatar
Roy... The Cortex gyro will enhance your flight experience ... Just make sure you have a kill switch (red light) and that the gyro mode (Amber light) when active. Your Jeti system has a gyro menu designed nicely for the Cortex gyro. Since you have an MSpeed sensor you can even dial in gyro gain based on your speed....Joe is an expert on the Jeti system and with his professional help you will have no problem setting it up...
Enjoy...
Old 08-30-2014, 07:21 AM
  #1056
jetpilot
My Feedback: (48)
jetpilot's Avatar
Originally Posted by roydefiant
Thanks all.
Yes, when powered down they squat, not when powered up. Or not always. Not really sure what the difference is. I can physically squat my down if I need to for judging.
Old 08-30-2014, 08:05 AM
  #1057
jetpilot
My Feedback: (48)
jetpilot's Avatar
ID:	2027143   Click image for larger version
Old 09-07-2014, 05:24 PM
  #1058
j.c.a.
How do you guys tie down your hawks in the trailer
J.C.
Old 09-07-2014, 05:34 PM
  #1059
j.c.a.
some pics
ID:	2030059   Click image for larger version
Old 09-07-2014, 05:35 PM
  #1060
jws_aces
My Feedback: (33)
jws_aces's Avatar
I built a pvc stand that supported the fuse in front of the intakes and behind the wing. You can see the stand in the picture below. My first road trip about 200 miles It crack the fuse on the bottom. I really didn't want to lay it on a flat surface so I came up with a support that keeps the pressure of the weight on the spar. I made sure it would just float in the stand. It works perfectly. I have put close to 3500 miles with it and no problems.
I am not sure if the Tomahawk is made of the same material. The Skygate is very easy to crack.
Here is a picture I took before I left for KY jets in July.
I used the stand to install the wingsand to test the gear.
  #1061
j.c.a.
ID:	2030061   Click image for larger version
ID:	2030062   Click image for larger version
Old 09-07-2014, 05:36 PM
  #1062
jws_aces
My Feedback: (33)
jws_aces's Avatar
Originally Posted by j.c.a.
some pics[attach=config]2030059[/attach][attach=config]2030060[/attach]
nice
Old 09-07-2014, 05:40 PM
  #1063
j.c.a.
Hi Jeff why would you not want to lay the plane on a flat surface with foam? are youon face book?
J.C.
Old 09-07-2014, 05:52 PM
  #1064
jws_aces
My Feedback: (33)
jws_aces's Avatar
With the lights and rear fins plus I have a antenna on the front I can lay it on a flat floor with foam. I did have it on the shelf you see in the picture one time but I had to remove the rudder so it didn't hit the roof of the trailer. That was on the return trip after I found the cracks and had not made the spar tube support.
I am on facebook but don't use it very much.
Old 09-07-2014, 06:01 PM
  #1065
j.c.a.
I am thinking of doing some kind of a rolling dollie to put the plane in the trailer to avoid hanger resh from carring in and out of trailer
J.C.
I just started using face book basicall just for the planes.
Old 09-09-2014, 06:09 PM
  #1066
j.c.a.
I have the GBR electric Brakes installed and can not get brakes to lock, I have even tried a battery straight to the electro magnets and still does not lock. Today I installed the air brakes back on the wheels with a BVM smooth stop valve and still the brakes don"t lock. Any suggestions would be appreciated.
With the air brakes can you hear a very slight air leak at the wheel?
J.C.
Old 09-10-2014, 06:11 AM
  #1067
marc s
marc s's Avatar
The brakes (GBRJET option) were never designed to lock, just to apply a decent braking function (in selectable functions and power) so the jet slows up in the same way as the full size.
marcs
Old 09-10-2014, 09:17 AM
  #1068
jws_aces
My Feedback: (33)
jws_aces's Avatar
J.C.
JC,
I had to shim the bolt on my Skygate to take out the little bit of slop. I had the same air leak until I found it. What you are doing is making sure the oring is all the way up in the wheel. Take a pump directly to the one wheel. press the backing plate and wheel together and see if it stops leaking. That is how i found my leak. I put a shim on the bolt on the open side of the wheel to pull the wheel up tight. You can lock the bolt in place when you get it right with the set screws on the brake backing plate.
I have leave off my hubcaps to get to work right. I have a little bit of drag also but it will stop better. It will not lock up.
Old 09-10-2014, 04:08 PM
  #1069
j.c.a.
marcs
Thanks for the reply Marc, on the bench it has some drag, but it is not stoping the plane enough ,I fly on a grass field which I would think created a little more drag than pavement and it needs more braking power I don't notice any difference between 7.4 or 11.1 volts. I have not tried the air brakes at the field yet but I dont think there would be much difference
Thanks Again
J.C
Old 09-10-2014, 04:15 PM
  #1070
j.c.a.
Originally Posted by jws_aces
JC,
Thanks Jeff, I will be looking at my skygate brakesbut I think they are different will let you know!
J.C.
Old 09-10-2014, 05:30 PM
  #1071
jws_aces
My Feedback: (33)
jws_aces's Avatar
There is a guy I met up at Michigan Jets name Curtis who has the Tomahawk Hawk help me with my brakes there. He notice the landing gear was a little different but he said the brakes were very much the same with the oring.
Old 09-11-2014, 04:20 AM
  #1072
gapellegrini
JC go check out this video from yesterday at Michigan jets. I tell you it was flying awesome.
https://www.youtube.com/watch?v=bBGcFz9dyjs
Jeff,
Is this a Tomahawk plane?
Gabriel
Old 09-11-2014, 04:47 AM
  #1073
jws_aces
My Feedback: (33)
jws_aces's Avatar
Originally Posted by gapellegrini
Jeff,
Gabriel
No it is Skygate. JC has both is the reason I posted it for him.
Old 09-11-2014, 05:38 AM
  #1074
gapellegrini
Jeff - Thanks.
JC - Which one do you preffer?
Best,
Gabriel
Old 09-11-2014, 02:37 PM
  #1075
j.c.a.
The Tomahawk flys awesome , have not finished the Skygate ,I could not say, but I hear they fly very similar
J.C.
