 delete >
delete
delete
Old 07-16-2010 | 07:57 PM
muzzgail's Avatar
Default RE: delete
P.S. this thread should get sticked...
Nearly, it got a fair bit of stick [X(]
Old 07-16-2010 | 08:08 PM
Banned
Default RE: delete
ORIGINAL: Dixty
Hello
Ground the jets before touching them! =)
When a jet is flying, it's hitting air molecules... it's rubbing against the air in other words.
When you fuel a jet, fuel is rubbing against tubes.
The turbine sucks fuel from the tanks, again the fuel is rubbing against tubes.
<a href=''http://www.experimentalaircraft.info/homebuilt-aircraft/aircraft-refueling-1.php''>http://www.experimentalaircraft.info...efueling-1.php
</a>http://www.forensicexp-vojvodina.org...lectricity.pdf<br type=''_moz'' />
It is reasonable to assume that an aircraft can acquire a charge of one million Volt or more, which it shares with the passengers inside the aircraft. [1]
For safety purposes, make sure you ground the jet and all the parts that can charge with static electricity (be it positive or negative), <u>before</u> touching it, well you dont have to touch the jet to make some sparks, just go close enough.
Also make sure you are grounded!
http://www.wikihow.com/Remove-Static-Electricity (point 7 is interesting)
Static electricity can set the jet on fire, the tank can explode, you can get electroshocked, burned, killed.
No one knows how it happened... http://www.youtube.com/watch?v=xAVMJBLy-UU
Old 07-16-2010 | 08:12 PM
Banned
Default RE: delete
ORIGINAL: trioval00
what really gets me is that in the video, the guy behind the camera focuses on the fire extingusher at 1.00 minute. Why did he say anything to the guys about that extingusher...... THEN look at 1:10, one of the guys brings over the fuel jug and attempts to defuel while the jet is burning.....................
Mark
Seen this happen many times over the years. Sometimes guys wouldn't even bring the fire extinguisher from their car or to the field at all. I would always make sure to go get mine or walk over and stand by holding it when I would see this sort of thing developing.
Bottom line, and biggest lesson from this video, ALWAYS have a fire extinquisher within arms reach of a starting jet and be ready to use it. Of course, many of us already know this, but unfortunately, there's a few who don't or haven't had the unfortunate happen to them yet.
Stay Smart.
Bryce
Old 07-16-2010 | 08:23 PM
ianober's Avatar
My Feedback: (12)
Default RE: delete
Everyone in that video should have gotten a Darwin award. The only thing that could have made that video better is if the guy shooting it zoomed in nicely on the extinguisher and then turned the camera around so I could see the look on his face. Unbelievable!!!![:'(][:'(][:'(]
Old 07-16-2010 | 08:31 PM
Banned
Default RE: delete
ORIGINAL: ianober
I know man, sure sign of a Maverick. Hopefully, someone may learn what not to do from this video and it may help to save a jet in the future.
Old 07-16-2010 | 09:52 PM
  #31
TimT2000's Avatar
Default RE: delete
ORIGINAL: Nightwalker
ORIGINAL: ianober
HI, This vid had a thread about a year ago that went a few pages, and it was stated by
someone that was there that the fire ext. was empty from another fire. I can't see the
guage but I did notice the hose is not stowed. Jets do make the best crashes and fires!
cheers Tim
Old 07-16-2010 | 10:06 PM
  #32
Banned
Default RE: delete
ORIGINAL: TimT2000
If there is not a sufficiently charged and operable fire extinguisher on hand (and within an arms distance) when attempting to start a jet, then don't start the jet.
ORIGINAL: TimT2000
Well Sir, I'll have to respectfully disagree with you there. That honor goes to the [link=http://www.youtube.com/watch?v=sU478UvcF6I]Jet Firetruck[/link] and motorhome, after it's been crashed.
Best Wishes
Bryce
Old 07-16-2010 | 10:11 PM
  #33
invertmast's Avatar
My Feedback: (23)
Default RE: delete
If this happened in the "states" then i believe the waiver holder is a perfect candidate for a waiver removal
Old 07-16-2010 | 10:17 PM
  #34
Default RE: delete
I was there during the fire. The fire extinguisher was tried but it was found to be NON OPERABLE. That's why no one grabs it under the table.
Old 07-16-2010 | 10:18 PM
  #35
Default RE: delete
I wonder how many millions of turbine jet flights we had worldwide and only this one caught fire from a static issue and not something else???
Old 07-16-2010 | 10:41 PM
  #36
TimT2000's Avatar
Default RE: delete
ORIGINAL: TimT2000
ORIGINAL: TimT2000
Best Wishes
Bryce
I must agree,, that was way better!! Cheers Tim
Old 07-16-2010 | 10:48 PM
  #37
rcjets_63's Avatar
Default RE: delete
ORIGINAL: invertmast
If this happened in the ''states'' then i believe the waiver holder is a perfect candidate for a waiver removal
Is there a waiver REMOVAL process for a single incident???? (and I ask that as a serious question).
Looking at article 24 and 25 of AMA 510-a, it describes the suspension process and that repeated suspensions may result in removal of the waiver. (Incidentally, you can still fly a turbine when your waiver is suspended and you don't even have to be on a buddy box you just need a to be under the supervision of an experienced turbine pilot).
So it would appear that if you do something mind-bogglingly stupid, you could get suspended but not have your turbine waiver removed since there was only one suspension.
Wild
Regards,
Jim
Old 07-16-2010 | 10:58 PM
  #38
Default RE: delete
I highly doubt this was caused by static electricity ...
Old 07-16-2010 | 11:59 PM
  #39
olnico's Avatar
Default RE: delete
Hello
For safety purposes, make sure you ground the jet and all the parts that can charge with static electricity (be it positive or negative), before touching it, well you dont have to touch the jet to make some sparks, just go close enough.
Read more: http://www.rcuniverse.com/forum/m_98...#ixzz0tud2Dtyl
Is it April the first ?
Our jets cannot accumulate enough static electricity to trigger a fire. Mostly because they are made or electrically inert material. I think that the author of this thread is mixing up real aviation ( aluminium planes ) with hobby ( wood, fiber, foam planes )...
The only problem with static electricity in very specific cases ( very dry and dusty environment ) is the ECU watchdog triggering that might result in a flameout.
Old 07-17-2010 | 12:54 AM
  #40
rcjets_63's Avatar
Default RE: delete
ORIGINAL: Dixty
deleted by me
Oh, come on now. Welcome to the feeding frenzy that is The Jet Forum.
Jim
Old 07-17-2010 | 04:32 AM
  #41
invertmast's Avatar
My Feedback: (23)
Default RE: delete
Yheaa...removsal is kinda harsh.. I'm sure the owner has changed the way he does things now to save himself the damage to the wallet... atleast I would hope so. I guess it could happen to anyone, especially if the extinguisher truly didn't work like the one poster said it didn't....
ORIGINAL: rcjets_63
Wild
Regards,
Jim
Old 07-17-2010 | 03:24 PM
  #42
Default RE: delete
I find that explanation just a tad odd:
1) if the jet went on fire and the pilot grabbed that extinguisher to try to use it, surely the extinguisher would by lying somewhere near the aircraft, where it was discarded rather than being put neatly back under a bench several feet away.
2) if the extinguisher was PREVIOUSLY found to be inoperative, why was a new start subsequently done in the full knowledge that the only available extinguisher was useless ?
Sorry, but for me this does not seem to add up.
Gordon
Old 07-17-2010 | 04:59 PM
  #43
highhorse's Avatar
Default RE: delete
Gordo, as I recall reading in another thread, the ext was previously known dead.
So, yeah, the guy gambled and lost. An expensive lesson.
Old 07-29-2010 | 01:40 PM
  #44
Default RE: delete
ORIGINAL: DelGatoGrande
ORIGINAL: Dixty
.. make sure you ground the jet <u>before</u> touching it....
?how i can ground the d@m thing with out touching it?
DelgatoGrande is the only one that needs cool water in her atitude!
Old 07-29-2010 | 05:07 PM
  #45
j.duncker's Avatar
Default RE: delete
I think this matter has been covered in full and the OP has now deleted the starter post.
Locking it,
J.Duncker Jet mod
