Anyone own a Warhead?
#1502
RE: Anyone own a Warhead
I'd like to know too...has anyone BOILED their plastic parts yet with any success? How long do you boil them - I know it's on the duratrax site, but I wanted to know from an actual user.
#1503
ORIGINAL: danny f norman
here is a list of frequently broken parts for the new guys on here
#1 servo savers.... stock up on these or JB WELD
#2 shock towers
#3 clutch.... upgrade to a three shoe ASAP
#4 spur gears.... these seem to get striped by looking at them, follow the manual and make sure they're tightened properly
#5 bulkheads
#6 pull starters....havent broke mine yet but they do break easy
#7 carbs....they leak alot use a slightly fatter o-ring on the carb body at the base and push down tight then then retighten the pinch bolt
#8 exhaust gaskets.... leak alot too. the one for the savage seems to work
thats all i got off the top of my head i hope it helps
#2 shock towers
#5 bulkheads
I'm still "PRO" Duratrax and happy with my Warhead! At least they do something! I'm right?
just my 2 cents about all those whiners ..
regards from switzerland!
#1504
WY
That right there is the kind of crap that's getting the older "anybody own a warhead" people to quit coming and posting anything. A few people have been in the warhead for a couple months and are getting tired of EVERYTIME you get the truck off the shelf something breaks. You say something about it and next thing you know here's a new person stepping in that probly doesn't even have their truck broke in yet b****in about whiners. It's ridiculous.
#1505
CA
So I finaly got back my parts today!
Now I need to remember which screw went where! The engine they sent back was obviously refurbished, the fly wheel was all dinged up like someone was using a starter box, and there is no glow plug! I sent mine out with a glowplug!
So before I start this thing up, what should I do to the engine to make sure it doesnt leak and how can I test it. I really dont want another occurance of last time (see my post above)
#1507
WA
Ok, today I was ripping my warhead up and down the street and it took off without me. The weird thing....I HAVE a failsafe but it didnt actuate the servo(brake). Lukily it wasn't at full throttle and I could catch it(barely). I had to step on the wheel to stop it while I was running at my full speed. Anyways, back to the point. ***.........What would cause this. I turned it off and then back on and it was ok. Moved everything around and had full control. I fired it up and bam, the servo went full throttle and the warhead almost took out my 3yr old across the driveway. It also seems the voltage reading is fluctuating bad? any ideas?!?!?!?!?. I am afraid to drive it now.
#1508
FL
I would check your receiver batteries. When their voltage drops, strange things can happen within the receiver and cause all kinds of weirdness.
#1509
TX
ORIGINAL: dpc1234
#1510
IA
Ok,
Im sure this will be asked a half of dozens times again after I post this. But I just ran my HPI Carb in my kids truck and it runs a whole lot better then the stock crap. The idle needle is stronger metal and the high speed needle is thicker then the thin stock DT Carb needle.
Also incase anyone is waiting for a idle needle for there stock Dt Carb. Yes-you can use the HPI IdleNeedle for the stock Dt Carb. There demensions are the same.
Im sure for all of the new guys in the forum, your probably wondering what Im talking about. I will show it the carb I am talking about so theres no question about which carb.
Till then, back to hibranation....
http://www2.towerhobbies.com/cgi-bin...8&I=LXFRE3&P=K
http://www2.towerhobbies.com/cgi-bin...8&I=LXFRE8&P=K
#1511
FL
Okay, I have now run a gallon of fuel through mine and am yet to break a servo saver or bulkhead. Took it out to the BIG field today and did some jumps on a rock pile and just plain ran the heck out of it all over the field. Was getting a foot or so of air on the jumps and nothing broke. I am not a timid driver and have been pushing it more and more and it just keeps on ticking and taking it. But then again, disaster could be hiding its' ugly head and waiting just around the next u-turn.
Of course, there are lots of way to look at production runs. The majority of pieces will come off a production run in the norm. Some will come of the line as lemons and then some will come off as real screamers. It is all in the mix of the parts and the bell curve. I personally think I got one of the screamers because of the few problems I have had.
Anyway, this thing is really coming into its' own and I must say, I love the WarHead.
#1512
WA
lukskywalker,
Glad to hear you got the carb. It does make owning this truck a whole lot better. I am at the point where I beleive the truck would have been better in kit form not RtR. The truck is good but the radio and motor leave alot to be desired. Anyways, I like my carb still as well but now I am on the hunt for more torque after I get the latest problem solved.
MotorPsyko,
I am running regular Alka batts but they are new. The failsafe is a Venom Smart temp. No problems with it till now.
quickster47,
I am going to check each batt individually now. The failsafe keeps fluctuating on its voltage reading between 3.9 and 5. It is odd.
MotorPsyko,
quickster47,
#1513
WA
On Another note, Anybody know about the Axial .32 motor. A store on ebay has 5 left at 139.99 + shipping. it is 8 port and Axials website says it has a 2 yr limited warranty.
#1514
TX
ORIGINAL: dpc1234
lukskywalker,
MotorPsyko,
quickster47,
lukskywalker,
MotorPsyko,
quickster47,
#1515
MA
Don't waste your time testing the batteries, you have to replace ALL of them with fresh ones. Please consider getting a rechargable hump pack.
#1516
WY
Most failsafes will not run with alk, as stated allready. If you were able to catch it, it may have been somewhat working, but your idle is a little high and that's why it kept going. When you shut it off and back on it may have just had "one last surge" from the batteries and that was it. As also allready stated, get a 5 cell rechargeable pack in there and it should fix it (hopefully) and double check your idle position to make sure when it's running it will stay still without you holding the brake. If nothing else next time it may take off slower and be easier to catch.LOL
#1517
CA
ORIGINAL: J_ME65
#1518
MA
Here we go.........
He said Most. Venom is an exceptionally good fail safe. The best IMO, but then again my opinion doesn't mean S&%$ to some because I whine and cry too much!!!!!!!!!!!!!!! Excuse me if I seem to be on the Defensive, it's a shame but it seems it's the way one has to be here.
Most failsafes
#1520
WY
MOST failsafes won't work properly with alkaline batteries. With each rechargeable cell in say a 1200 5 cell pack, each battery is rated at 1200 mah. In standard AA batteries the average mah per battery is right around 750 - 800 mah. When you use normal batteries they are 1.5 volts where rechargeable are 1.2. Thats why it takes 5 rechargeable to make the same volts as 4 regular. With the mah though, it does not make up the difference so you don't have as powerful batteries for near as long. That's why they recommend the hump packs as an aftermarket item and why they say most failsafes will work better with the hump packs.
#1521
Got my HPI S-25 Carb today and just measured everything to the stock Super Tiger replacement carb I got from DTX They are exactly the same, the slide and idle speed screw are the same. Checked everything with my dial calipers and the parts are completly interchangable. I do not know if this is the same as the original as it is on the truck. Thought I would post a few pics. for everyone to see.
#1522
PA
Hey guys thought I thought I would fill you in on my new engine break in today.
Heat cycled my engine today it went well. I did 8 cycles.
Does anyone know how many cycles need done?
This might be a little long but, I beleive it will help the new guys and the guys that are getting new engine from DT.
Temps outside where around 32, so keeping the engine up to temp ( minimum 200) was a must. I heated up the head to 140 to releive the pinch before starting, put a cut sock around it till it reached 200 then run it for 2-3 min. I didn't time it I just guessed. I filled the tank to 3/4 before each run to keep adjustments I made after each cycle consistant. After each run I left it cool to 75-80 before heating it up again to run it.
I did smooth steady throttle, from slow speed to WOT for 1-2 seconds. WOT times got longer as the cycling progressed.
Cycle #1 leaned the HSN 1/4 from the factory setting because I know it comes rich. did 4 stroke but temps were up wher they belonged so a little extra oil won't hurt it actually helps. temps 210-230
Cycle #2 leaned HSN 1/8 still 4 stroking at lower speeds but 2 stroke at higher, smoke good. Temps 200-225. idle was a little high.
Cycle #3 leaned HSN 1/12, temps 195- 215, the 195 was at the end of the run. did end up richening the LSN to get my pinch test right.
Cycle #4 leaned HSN 1/12, temps 205-215, still a little rich
Cycle #5 leaned HSN 1/12. temps 220 steady, good smoke, idle is creeping up.
Cycle #6 lowered idle, lean HSN 1/12, temps a little higher 230-235, engine is showing signs of power, good smoke, idle still high
Cycle #7 lowered idle, changed nothing else, temps 225-238
Cycle #8 lowered idle, changed nothing at this time, run this time with 1/2 tank to see if it was going to lean itself out, it did, temp got higher as tank drained to 1/4. temps 225-240 still good though, I had to richen up the LSN, as I started to punch it from a stand still on this run, it was starving for fuel, this inturned lowered my idle, so I had to up the idle a little, pinch test was good. I should have richen the LSN up earlier, this would have dropped my creeping idle down as the engine progress to be broke in.
Let me say when I broke in my original engine I was green. I tried to heat cycle it the best I could. I know now it was far from good, keep reading.
Once I was done (dark outside), I took it in the garage for the once over. I pulled the plug and I put some after run oil in the carb and head. Then I spun the flywheel to check the pinch, wow, it had a strong pinch at TDC, just like it should. I know it may not be fully broke in yet, but so far the results seem promising. My last engine I could barely feel the pinch at all. I beleive this engine is going to be better then the old. My rookie break in on the first engine is probably to blame for that.
#1523
hey spac
i have a paper here i found from a website about heat cycling according to what you said you did it right. it says to "run 2-3in. intervals and dont be scared to to adjust settings to keep temp above 200. cycle this way for 15 min of ttl run time. then go to 3-5 min intervals until a total of 25 min run time is achieved. it says you'll have better performance and longer life on the motor." thats the way i'm doing it if they send me a refurbed motor back
#1524
MN
That's the break-in method the "legendary" Stephen Bess made famous (the Bess Heat-Cycle Method) and the one many (most?) racers use for their high-buck, high-performance, long-lasting engines. I hightly recommend it!
#1525
PA
Well I'm probably about done then. I will take it easy the next couple runs though to be safe.
hey spac
i have a paper here i found from a website about heat cycling according to what you said you did it right. it says to "run 2-3in. intervals and dont be scared to to adjust setttings to keep temp above 200. cycle this way for 15 min of ttl run time. then go to 3-5 min intervals until a total of 25 min run time is achieved. it says you'll have better performance and longer life on the motor." thats the way i'm doing it if they send me a refurbed motor back
hey spac
