Official HPI MT2 Thread
#3676
ON, CANADA
oh and thanks hope it clears fo you as well .
ORIGINAL: mt2nitronut
yes all stock i,m getting new mt2 tomarrow or monday is breaking in the motor hard to do or straight forward fallow directions to breaking in onlt the t 15 tho,yeah cant wait iffy on the break in tho first time rc breakin ,used mt was already ready to go.but give it back to my step son who i baught it off of so he could bye parts for a ford tempo station wagon he,s only 16 car nut lol ,i seen it hurt him selling it so i figured what the hell christmas coming 250 bucks up what more would he want cant wait to rip and bash him and i two trucks better qaulity time having fun.
ORIGINAL: CS MT2
do you still have the stock tank with primer? This could be a reason why. Honestly it is best to prime the carb using the rotostart or pull start if you have that. Just cover the exhaust outlet with your finger and then pull/rotostart for a couple pulls/seconds and fuel will rush to the carb better than any primer could ever do.
Taking a break right now from breaking in my savage, first tank through so far and letting it cool for a bit. Can't wait for it to be done so I can drive
Luckily rain has cleared up here for a couple days but supposed to start again saturday. Hopefully you will have good weather there so you can start yours up too.
#3681
ON, CANADA
ok then use roto to prime
ORIGINAL: Grantothismo
friday13:
12" I bought Ofna fuel line holders and looped it around the handle thingy thet MT2 has in the middle.
friday13:
#3682
TX
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXJFE2 This is the tank I use, drops right in, just have to move the rear tank mount back, there are already holes in the chassis for this.
As far as break in, the alternative to following the manual is look on page 121. 46u posted a different way to break in the motor and I am somewhat following this method right now except for the first tank part. For that I am combining hpi's method of letting it idle and varying the throttle (while on a stand, tires off the ground) to keep clearing out the excess fuel. And in case you don't know (when reading 46u's post) to find bdc, rotate the flywheel until it is easy to turn. This is bdc, if it is hard to turn, you are either entering or leaving tdc.
Also, if you use this tank, you may want to add an extra o-ring under it on each screw where the screws go through to bring the height up a little so it doesn't rub the chassis. Although with the stock tank on mine, it also rubbed a little, but this tank seems to be a little deeper.
#3683
ON, CANADA
this is a list from asiatees that i pick out for my mt2,Shopping Cart
think that might just a bout cover it. i would like to get blue instead of purple but i,m sure i can refinish parts myself.
Qty Remove Item Options Price
Nitro MT 2 Aluminum Steering Assembly Set Silver
#NMT2048S $19.95 USD
Nitro MT 2 Aluminum Front Knuckle Arm Set 1pr Silver
#NMT2021S $17.95 USD
Nitro MT 2 Aluminum Front Shock Tower Silver
#NMT2028S $11.95 USD
Nitro MT 2 Aluminum Rear Shock Tower W/ Screws Silver
#NMT2030S $11.95 USD
Nitro MT 2 Aluminum Front & Rear Threaded Shocks Set (4) Purple
#NMT23100115P $43.95 USD
Nitro MT 2 Aluminum Rear Hub Set - 1PR Purple
#NMT2022P $11.95 USD
Nitro MT 2 Aluminum Front Arm Set Silver
#NMT2055S $20.95 USD
Nitro MT 2 Aluminum Rear Arm Set Silver
#NMT2056S $19.95 USD
Nitro MT 2 Al Front/Rear Gear Box 2pcs set Silver
#NMT2012S $33.95 USD
Nitro MT 2 Al Front Lower Arm Bulk - 1 Pc Silver
#NMT2008S $19.95 USD
Nitro MT 2 Al Front Bearing C-Hub (8 Deg Caster)-1 Pr Purple
#NMT2020AP $17.95 USD
Nitro MT 2 Titanium Completed Tie Rod - 3 pc set
#TNMT2160 $21.95 USD
Nitro MT 2 Al Rear Lower Arm Bulk - 1 Pc Purple
#NMT2009P $16.95 USD
Nitro MT 2 Al Steering Plate - 1 Pc Purple
#NMT2049P $4.95 USD
T-Maxx Aluminum Competition Ready Threaded Shocks (8) Blue these are just a creation tool for me add on test for different purposes.
#DP100B $69.95 USD
#NMT2049P $4.95 USD
#DP100B $69.95 USD
#3686
ON, CANADA
thanks for the tips learning alot through this forum
ORIGINAL: and_des
I use this tank from ofna just a bit of work to make it fit.[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBM24&P=7[/link]
#3687
BC, CANADA
So choked been working on my new Mt2 SS kit and I go to mount the exhaust manifold and one of the screws that came with the kit has no head on it so darn close yet so darn far[>:] Anyone notice that when droping in the engine there is no mention as to the meshing of the gears?
#3688
ON, CANADA
the meshing is easy to see by eye really just make sure the gears are meshing correct inbetween each other lol
ORIGINAL: tum_yeto
#3689
ON, CANADA
can you believe it missed out first atemp ups shipment got to wait till monday now had to go to work left a note for supper to sign guess she missed them to .
#3690
ORIGINAL: and_des
Grantothismo
Do you mean the zip tye on the front bumper? They are there because the screws broke inside the bottom part so that was the only way I found to hold those two parts together, it’s a quick fix but its good enough for me.
friday13
I have long fuel line for went the truck flip over I have more time to get to the truck to put it back on its wheels, and like Grantothismo said it help keep a decent pressure in the system.
Grantothismo
friday13
By the way, do both lines must be around the same length?
#3691
#NMT2049P $4.95 USD
#DP100B $69.95 USD
#NMT2049P $4.95 USD
#DP100B $69.95 USD
#3692
tum_yeto
For the gear mesh I use a piece of letter paper put it between the cluch bell and spur gear push the motor against the spur making sure its at the right angle. After that remove motor screws one at the time to put a bit threadlock. I've been doing this for a long time now and never had a problem, still ruining original spur on both of my trucks.
#3693
ON, CANADA
KACHING IS RIGHT FRIDAY Slowly but surely
ORIGINAL: friday13
"KA-CHING!"
#NMT2049P $4.95 USD
#DP100B $69.95 USD
#NMT2049P $4.95 USD
#DP100B $69.95 USD
#3694
nice shopping list mt2nitronut . Mine will be very similar . I would like to thank the people who answered the tuned pipe question
I did find this on ebay though http://cgi.ebay.com.au/GPM-HPI-MT2-A...QQcmdZViewItem
#3695
ON, CANADA
thanks narly it will take some time but i would rather put away for the whole kit and cabuttle so i can create the new machine.all at once enjoy the trades of the rc world awesome machines out there.
ORIGINAL: narly
#3696
ON, CANADA
was waiting for ups shipment today but i had to work guess super wasnt home when ups came a ringin da-,got to wait till monday,new mt2 with some hop ups parts filter gear clutch bell shocks etc etc.
ORIGINAL: narly
#3698
ON, CANADA
spares could come in handy sometime you just never know but if you need money for other upgrades or better parts why not.
ORIGINAL: kuhndog599
never mind i tried it and it does. should i keep my other mt for parts or sell it.
#3700
NY
Hey guys,
If I wanted to save some money on gettng a MT-2 18SS/radio/accessories, would the below Radio be ok or just a waiste of money? I figure I can save a $100 since I am new and have to buy everything at once. THANKS.
http://www2.towerhobbies.com/cgi-bin...I=LXEDP1**&P=0
