RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official HPI MT2 Thread
Old 10-29-2006 | 04:54 PM
  #8376
46u's Avatar
46u
Default RE: Official HPI MT2 Thread
No but it comes in a can like a small paint can. I suggest you try Lowe’s, Wall mart or some place like that. You use it for making rubber handles like on pliers. You dip in and pull it out. Most be fairly thick. Sorry do not know what it is called. Never used any but have seen it somewhere in stores.
Old 10-29-2006 | 05:16 PM
  #8377
alright ill keep my eye out for that i want to try it.
Old 10-29-2006 | 07:50 PM
  #8378
murawskiallen's Avatar
does anybody know if there is such a thing as waterproof servos so i dont have to take a chance on trying to water proof them myself??
Old 10-29-2006 | 07:54 PM
  #8379
46u's Avatar
46u
Not that I know of and if they did I bet they would be high. They make water resistant starting off around $70 each.
Old 10-29-2006 | 07:57 PM
  #8380
MiamizFinest's Avatar
DAM 334 pages this had to be the biggest thread on the site!!!!!!!!!!!
this is my first post in this thread since i dont have a MT i use to have the MT1 but sold it before i even learned about this site so anyways i em goin to turn my RS4 3 into a MT2 do any of u have any suggestions for me????????im have a one of kind MT since i will be a MT but still set for street use...................LOL i know i need..........
A ARMS
DOG BONES
TIE ROD'S
is there anything im forgeting?????? i know i didnt mention shock towers since im goin to use the ones from the RS4 3 but im use the shocks/springs from a jato.......... em i forgeting anything??????
Old 10-29-2006 | 08:04 PM
  #8381
46u's Avatar
46u
In my opinion you would be a whole lot better off buying a MT2SS kit. The chassis you are starting with if I am not mistake does not have the turn up in the front. Very important for off road. I am only guessing I would think you will spend about or all most as much as getting the kit and will not be as good as the kit when you get done. If you look 4 or so pages back you will see this has been all ready covered.
Old 10-29-2006 | 08:17 PM
  #8382
ORIGINAL: 46u
UR 100% right it doesnt have the knouch in the front but im not goin to use it off road im only goin to use it on the street (plus rember i have to 2 speed ) so thats imposable to take off road...................... my reson for doin this is so i can put a .21 engine in it................ and with the longer MT arms ill have more control im trying to make something to give the .21 jatos a run for there money
Old 10-29-2006 | 10:54 PM
  #8383
i wanna see how it turns out
Old 10-29-2006 | 10:57 PM
  #8384
yeah so do i, post some pix when your done with it
Old 10-29-2006 | 11:10 PM
  #8385
ORIGINAL: murawskiallen
OH HELL YEA ill post pics im looking for the A-ARMS one ebay right now.............LOL im planning on dropping in the STS .21 in it im just waiting on 46u reveiw on it................. hey when im done what do u think i should call it?????a RS4 or a MT?????? LOL
Old 10-29-2006 | 11:18 PM
  #8386
mt4...lol
Old 10-29-2006 | 11:23 PM
  #8387
you should get the os .21 vz-b v-spec engine, go all out
Old 10-29-2006 | 11:24 PM
  #8388
mt4...lol
HMMMMMMMM NOT BAD LOL im makeing an order from ebay and the store owner doesnt have the ARMS ill pick them up sometime this week from a LHS
Old 10-30-2006 | 12:10 AM
  #8389
does anyone know of a way to retro-fit a big block in to the mt2? I have an mt2 roller as of now, I just need an engine and radio, and i'm set... but I have a 24.7 lying around and is there ANY way to make it fit, w/o buying the New Era Conversion?
thanks
Old 10-30-2006 | 12:17 AM
  #8390
MastaDizasta's Avatar
Use a standard big block engine mount, and drill new holes in chassis?
ORIGINAL: mtrchamp
thanks
Old 10-30-2006 | 12:19 AM
  #8391
true... well, it came with the aluminum engine mounts (stock or not, idk) but would I have to set it back any further because the driveshaft? I mean even puttin a trx 2.5 in it would be a hassle don't you think?
Old 10-30-2006 | 12:33 AM
  #8392
46u's Avatar
46u
http://www.neweramodels.com/cgi-bin/...d=&part_id=709
http://www.neweramodels.com/cgi-bin/...d=&part_id=710
Old 10-30-2006 | 09:27 AM
  #8393
... but thanks, I don't have $70 to go buy a conversion kit, lol
Old 10-30-2006 | 12:59 PM
  #8394
46u's Avatar
46u
Like some one said you can drill holes in your chassis but one mistake and that will cost you about $40 for a chassis then the cost of the big block mounts an the proper flywheel.
Old 10-30-2006 | 01:41 PM
  #8395
nickrummy's Avatar
46u, I'm going to pick your brain for a bit if you dont mind.
I had an RS4 Evo with a .18 OS CV-R in it with 19/23 cb and 41/37 spurs. Put that in the MT and the tires are way to big to turn over. Doesn't shift out of 1st and stops at about 1/2 the rpm range.
do you have a 2 speed in your truck? I've been crunching numbers all morning to figure out what I want to use. Stock MT gearing for the single speed is 4.33 (12t cb and 52t spur) so I really want 1st gear to be around 4.33 Here are some ratios I worked out. (sorry there are a lot)
I'm liking these first two options. 4.73 1st gear ratio would be CRAZY accel with the bigger motor yet be faster in second gear than a stock MT. The next ratio is awesome too, almost stock gearing for accel but 2nd is a lot smaller for a lot of top end.
gear ratio options with 11/14 clutch bell
spur (52/49)
1st gear – 4.73
2nd gear – 3.50
spur (47/43)
1st gear – 4.27
2nd gear – 3.07
spur (43/39)
1st gear – 3.91
2nd gear – 2.79
spur (41/37)
1st gear – 3.73
2nd gear – 2.64
gear ratio options with 12/15 clutch bell
spur (52/49)
1st gear – 4.33
2nd gear – 3.27
spur (47/43)
1st gear – 3.92
2nd gear – 2.87
spur (43/39)
1st gear – 3.58
2nd gear – 2.60
spur (41/37)
1st gear – 3.42
2nd gear – 2.47
gear ratio options with 13/16 clutch bell
spur (52/49)
1st gear – 4.00
2nd gear – 3.06
spur (47/43)
1st gear – 3.62
2nd gear – 2.69
spur (43/39)
1st gear – 3.31
2nd gear – 2.44
spur (41/37)
1st gear – 3.15
2nd gear – 2.31
Old 10-30-2006 | 01:44 PM
  #8396
nickrummy's Avatar
Here is a video of my MT. It's the first truck. It is running the 19/23 pinions and 41/37 spurs from the onroad car. You can hear how much its struggling. It's running pretty rich too.
http://smg.photobucket.com/albums/v4...ent=HpiMTs.flv
Old 10-30-2006 | 01:52 PM
  #8397
ORIGINAL: nickrummy
spur (52/49)
1st gear – 4.73
2nd gear – 3.50
spur (47/43)
1st gear – 4.27
2nd gear – 3.07
spur (43/39)
1st gear – 3.91
2nd gear – 2.79
spur (41/37)
1st gear – 3.73
2nd gear – 2.64
spur (52/49)
1st gear – 4.33
2nd gear – 3.27
spur (47/43)
1st gear – 3.92
2nd gear – 2.87
spur (43/39)
1st gear – 3.58
2nd gear – 2.60
spur (41/37)
1st gear – 3.42
2nd gear – 2.47
spur (52/49)
1st gear – 4.00
2nd gear – 3.06
spur (47/43)
1st gear – 3.62
2nd gear – 2.69
spur (43/39)
1st gear – 3.31
2nd gear – 2.44
spur (41/37)
1st gear – 3.15
2nd gear – 2.31
nice numbers but let me ask u are u only goin to use it onroad right??????? the 2 speed althought it fits the MT it doesnt have a slipper (i wish there was a way of puting one on) if ur goin offroading with the 2 speed its might not last u very long
Old 10-30-2006 | 02:01 PM
  #8398
nickrummy's Avatar
I've been debating that too. I'll be honest, I won't be able to stay away from offroad. I'll probably see how the 2speed holds up and if it doesn't deal with it then. Maybe try to use a savage 2 speed or design a slipper.
Old 10-30-2006 | 02:06 PM
  #8399
46u's Avatar
46u
Sorry the only 2 speed I have is in my Savage and the only thing you can change is the CB or Spur which are single gear. Sorry when it comes to gearing I do it by trail and error. If I am not mistaken doesn’t the RS4 Evo have a different gearing in the differentials as well? Not sure if this well affect anything but thought I would mention it. Sorry I cannot help more but good work.
Old 10-30-2006 | 02:20 PM
  #8400
nickrummy's Avatar
The MT and RS4 RTR 3 both use 13t input gears and a 38t ring gears which is a 2.92 ratio. The big difference is the Evo has a tire diameter of around 2.5" while the MT is around 5". Thats why the gear ratios are so different. They do have 2 speed clutch bells for 2 speeds that were made for the MT. This was the part number that came with the 2 speed kit.
http://www2.towerhobbies.com/cgi-bin...20&FVPROFIL=++
