Official HPI MT2 Thread
#8701
NJ
wow something wrong ok ill just give u the name HPI engine mount 20mm purple.... go look it up on towers.. sorry id noe wuts happening -_-
#8703
GA
I have these but either the ones you listed or the ones I have listed are fine.
http://www2.towerhobbies.com/cgi-bin...&I=LXCLR3&P=ML
#8704
CA
hey guys, i just found proof of the firestorm 2wd truck coming out, as was being talked about a few pages back. its up on hobby people .net. don't bother checking it out or anything yet, they don't even have a picture or anything, but now we know that hpi IS making it. sort of interesting i guess.
#8708
CA
i don't have a job [
]. yet. but im planning on starting at my lhs pretty soon. it is tough doing any of this on such little money. but guys, i had a couple of questions...does anyone here run any good bodies besides the stock one? (which one, easy to fit?) and also, ive read that the stock gearing is a little skimpy on the low end, and that the stock suspension is a bit soft. any recomendations?
#8709
i have another question my first was, if i got a new 13t cb could i run it on the stock 49t spur gear or would i have to get a new spur as well... and my second question is, should i adjust the gear mesh after installing the 13t cb or can it stay the same as when i had on the 15t cb???
#8710
GA
ORIGINAL: murawskiallen
#8712
yes it is the ss i dont run rtr trucks cause it doesnt seem like much of a hobby if i dont put it together and personalize it the way i want
#8714
thanks 46u, i just wasnt sure if it would work because i got the 13t vented cb and it came with a chart that suggested that it wouldnt work with the 49t spur but i guess that is only for the svage engines
#8715
GA
I hope I do not end up eating crow but it should work if you have enough adjustment in the slots for the motor mounts on the chassis. I know I had some problems when gearing mine do to the slots but cannot remember what it was. If you want to gear it down and cannot use the 13CB you can get a 52t spur. But the infromation that comes with the CB is for the Savage. Sorry if I gave you wrong information!!![X(]
#8716
GA
ORIGINAL: unclezesta
#8717
yeah i guess i could do that but if i used a 52t spur as opposed to the 49t spur wouldnt that decrease the acceleration and increase overall speed?? im going for acceleration the top speed isnt that important to me
#8718
GA
To gear up more top end you go up on the CB or down on the Spur.
To gear for more low end or torque you go down on the CB or up on the spur.
So a 52 tooth spur would be a lower gear then a 49 spur.
#8720
CA
Do you have a link as I looked and could not find it right off hand?
http://www.hobbypeople.net/guru/hps_844036267.asp
thats all the evidence we have so far. there's nothing there but the name.
