Official HPI MT2 Thread
#9977
NJ
man i luv seeing this forum grow
anyway do you think the engine will get more air if i cut the front grill of and put a metal mesh in place of it?? the bodies old so i wanna experiment
#9978
GA
Do you have problems with the engine over heating? I do not have a problem with just the back top cut out and a hole in the windshield when it is 100 degrees out side. You all so get pretty good airflow from under the body. But if you just looking for something to play around with go for it. Post pictures if you do.
#9979
NJ
i though it would cool down the engine more and i wannasee how it looks... if it looks good ima buy a body and a small grinder to do a better job.. i just did a rough job to see how it turns out here a pic.. it sorta came out blurry
#9980
FL
ORIGINAL: 46u
No offense but where you surprised which one won?
ORIGINAL: nitro-is-deadly
lol got me there..but actually i was comparing speed as i only have 1 onroad and 1 off road atm. so if i was maybe talking ABout which 1 drifts better or which 1 jumps better would be apples n oranges yes?
no but the whole point was seeing how good the mt2 did vs a 70+ mph r/c on road
#9981
My Feedback: (14)
NY
All
NEVER CUT YOUR RX ANTENNA WIRE ON ANY AM OR FM RADIO, you will definitely have problems with it going out of range as close as 10ft. The RX antenna wire is cut to size using special tuning tools at the factory, no 2 RX antenna wires are the same length even though they may look like the same. Back in the day if we had to replace an RX antenna wire I would install a new one 2ft long, then I would have one of my friends go a block away with the TX while I had the car. Then I would have my friend move the steering back and forth while I cut the wire down in 1/2in increments until it was not glitching anymore. This was the best way to tune it without sending the RX back to the factory for tuning. The factory of coarse has special tuning tools to make it perfect but my method worked pretty good. I got this tip from a seasoned guy I trusted in my LHS many years ago.
As for the Nitro Devil rear pipe I have one and I love it. I switched from a ported stock HPI header and a tunable Cvec pipe. When I installed the rear exhaust I noticed I got more bottom end power and slightly less top end which I was happy with. I rather have more bottom end power (torque) then top end power (HP). It helps the truck power through the rough terrain like grass better. As for it getting damaged I have not had a problem as of yet. I did have to readjust the header pipe a couple of times by bending it away from the shock towards the center of the truck so it would not interfere with the trucks full range of motion rubbing against the shock. But I do have my shocks moved in one hole on the shock tower, which gives me less room to work with. The header pipe is very soft aluminum and bends easy. I hope I never have to replace it because I readjusted it too many times.
#9982
FL
any 1 got a opinion on the fuel best fitted for the MT2 ?
ive only used the O'donel
and traxxas top fuels..
any 1 got any different brands they use and how is the performance with the fuel?
#9983
ON, CANADA
i use nitro sidewinder race blend 20 /12,its bin great for my stock t15 lol what a joke that engine is now compared to my trx 2.5 in my other mt2 which i also run sidewinder
#9985
hi i have recently bought a hpi mt2 and got a problem the gear in the middle was all burnt out so i replaced it but now when i start the engine it goes of on its own any help would be tratfull thanks alot
george
RESSETTING THE CARB DIDNT WORK ANY HELP PLEASE
george
#9986
man this thread grows so fast............................ive looked around and i honestly think this is the thread with the most responce's ever one RCU
#9987
My Feedback: (14)
NY
ORIGINAL: georgealley
george
george
#9988
The only thing I can think of is that you have a MAJOR air leak. That is the only way your motor is going to throttle up without you opening the carb.
Is your idle stop screw adjusted properly? You should be able to close the carb enough to slow down the idle.
george
george
#9990
hi welcome to the forum. if you turn to page 6 in the mt2 manual, the throttle setup will be in there. good luck
george
george
#9992
looking good dude. ive just finished cutting mine out. going to give it a good clean and mark up where i want the masks. might give it its first coat tommorow
#9993
What kind of design are you going to paint on it? I'm getting this airbrushing down. Of course I'm getting used to it now after I did the shadow which should be a lot lighter but it still looks decent. I'm buying a few more bodies after the holidays. I want to paint some more now!
#9994
it looks really nice so far. that rip effect looks really cool. where the yellow maskin tape is...what colour are you doing that? and im doing tribal flames
ORIGINAL: nickrummy
#9995
are your tribal flames going to be solid colored? I thought about doing flames too. I started doing a template for them.
I'll be doing the part behind the torn effect fluorescent red backed with white to make it bright. Hopefully it is eye catching!
This is all for my girlfriend's younger brother. It is going to be his xmas gift.
Bought him some black hpi split 5 wheels and some new proline dirt hawg tires. I'm putting together a complete truck for him from parts I had leftover.
It'll have the T15 motor, this body and wheelset I mentioned above, venom temp/failsafe, aftermarket 3mm chassis and I'm thinking about putting my THS racing pipe on it too but i'm not sure yet. Either that or the stock pipe and the stock pipe is so horrible.....
#9996
hes a lucky boy.
ORIGINAL: nickrummy
#9997
GA
I commend all that have the patients to do a nice paint job on a body! I just do not take the time, as I know in six months I will have to replace it. I have often then thought about doing one just to put on while it was sitting but never have. Yes keep us up dated and keep the pictures coming.
#9998
ok guys ive noticed something. When i spin the back *wheel* foward the front wheels spin to. so does the clutch bell. is this normal? i thought when you spun both back wheels foward this is ment to happen?...i took it out for a spin and its not as bad as it was but still losen abit of power? [&:] im so confused on what it could be...could my slipper pad be glazed? so i would need to roughten it up? or maybe because ive got a new exhaust my slipper clutch setting would need to be tighter?
#9999
the power from that exhaust won't be enough to make serious adjustments on the truck.
Depending on how tight your diffs are you might get the front wheels to spin by spinning one back wheel. If your diffs are loose then the oppsoite rear tire will just spin the opposite way.
If you put the truck down on the ground and hold the spur gear and push the truck does the truck roll easiily or does the spur gear try to turn with the truck?
I'll keep you updated on the body. Hopefully it'll start looking better tomorrow or friday. I'm hoping at the end of day friday it will be finished.
I'm mounting up the tires tonight. I'm hoping to try out that tape trick to keep them from ballooning. Hopefully it works!
FL
ORIGINAL: nickrummy
hmm well should they be loose or tight because by taking what ur saying into consideration my came loose from the hpi factory w/e. when 1 wheel is spun the other spins the opposite way
btw nice job so far on paint post another pic when u get more paint on it :P
