Official HPI MT2 Thread
My Feedback: (14)
NY
RE: Official HPI MT2 Thread
46U
What happened with the Diff Case??? Did you get everything together or is there a problem with the case preventing you from puting your rear together???
I run these on my MT2 with the graphite shock towers - work great. I love the range of adjustment on them..
ORIGINAL: 46u
One more thing about this piece of junk GPM differential case half the screws are wrong. [:'(]
They don't appear to have a diff-case/bulkhead on the page, but you could enquire to see if they might produce it...
http://www.rc-edit.com/products.php?kit=7&lang=en
Just an idea
GA
ORIGINAL: Joebaby35
46U
46U
GA
ORIGINAL: rcnz
Have you enquired with RC-Edit? I'm pretty sure their stuff is billet...
Just an idea
ORIGINAL: 46u
Just an idea
Yes their stuff is billet and well made but do not make much for the MT. I just looked and could not find any differential cases.
does this include the shims & everything i need http://www.jespares.com/catalog/prod...oducts_id=1552 it says "set" so im guessing it does?. also what grease should i use?
can some one please help me, my mt2 isnt starting. I took the glow plug out(not sure if its good or not cant tell, idk how) checked the fuel lines,glow starter,etc idk what it is. So i took the whole engine off washed it lightly with soap and water and checked it over. The only thing thats weird is that b4 i took the engine off and stuff, when i pulled the pull start halfway through the cycle i could hear like this slight -tttiisstt- sound amost like an air leak. Any help is greatly apprecieated
also my pull start is starting to slip(ie doesnt turn the engine over every time) how can i check to see if its still ok, or check if its bad?
ps the engine i have is an omega xt .12 se
ORIGINAL: djheptic
You'll also just need to download the 18SS manual from HPI, its got instructions on how to install the parts into the diff case.
Is there an conversion kit to put an .30 size engine into my mt2? I know it is possible..but I just don't know how. Maybe one of you expert can share with some of us..
GA
ORIGINAL: rcnz
I just use the HPI Grease...yes this set include shims and everything you need to replace the stock pot-metal gears.
ORIGINAL: djheptic
http://www2.towerhobbies.com/cgi-bin...?&I=LXTB43&P=Z
GA
ORIGINAL: tigerdragon
http://www.neweramodels.com/cgi-bin/...d=&part_id=709
http://www.neweramodels.com/cgi-bin/...d=&part_id=710
thats just silly. if they supply no shims [:@]. im going to email the store and ask them. as i wont be ordering until wednesday/thursday
ORIGINAL: 46u
I do not think it comes with the pinion shims and the only way I know to get them is with the spider gear cup set. I use Harley wheel bearing grease.
ORIGINAL: rcnz
ORIGINAL: djheptic
GA
ORIGINAL: rcnz
Sorry...I meant to say it only comes with the larger shims for the casing itself. No pinion shims...I never actually had to shim the pinion on mine anyway...only the casing...
ORIGINAL: 46u
ORIGINAL: rcnz
ORIGINAL: djheptic
GA
This is a better picture for the final gear set. It comes with the big shims but not the pinion shims.
http://www2.towerhobbies.com/cgi-bin...237&I=LXJYM2&P
i think that is just silly. you pay good money for the set...and they dont include what you need. what has the world come to now a days []. so you are saying i will need to buy the spider gear set / Bevel gear set and the toothing is 13T & 10T right? and these include the shims i will need?. i only need 2-3 shims on the pinion.
just looked on the site and they are only £5.00 so its not that bad
does any1 here have problems with the front uprights in there mt2 i am forever having to work on it wer the screw has broken the threads on the upright at the bottom, the screw stays in but the upright pops of causing dog bone to pop off as well. its usally only the left side of the car.
yeah had that problem not long ago. the cap head screws wear the threads down and make the hole alot bigger so the turn buckle comes off. thats why i am going to upgrade to the alu ones.
ORIGINAL: adz06
it happens me almost every time i have it out i have just kept replacing them with the cheapy plastic 1s if i replace them with alum ones would i need to replace anything else?
im very puzzled. my gears are meshed properly but i have a tight spot on my spur-gear [&:]. its been there for a while now but i thought i would just see if any of you might know what it could be. as i said its been there for a while so its nothing to worry about, if it wanted to strip it would have stripped by now. knock on wood lol. any ideas? thanks
get the alu turn buckles and uprights. I think the cap head screws will fit. not entirely sure as i do not own alu turn buckles and uprights (yet) i know alot of people on here do have them. im sure 46u has them. also a good investment is [link=http://www.jespares.com/catalog/product_info.php?cPath=347&products_id=2789]these[/link]. im getting them for my mt2 very soon once i sort out my diffs
ORIGINAL: adz06
GA
ORIGINAL: djheptic
Being I cannot see or know what all is wrong with yours hard for me to say what you need. Is it all bad or what? The final geas come as a set. Ring and Pinion
GA
ORIGINAL: adz06
http://www.rc-edit.com/piw.php?partN...&kit=7&lang=en
