RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official HPI MT2 Thread
Old 02-14-2005 | 09:48 PM
  #1251
Default RE: Official HPI MT2 Thread
46u
all the parts you listed, are all those parts stock on the 18ss
Old 02-14-2005 | 09:55 PM
  #1252
Well personally i love the THS pipe it gives a great little boost to the engine and has the sweetest little pure to it, and for all you bling freaks out there i dont think anyone can complain with the looks of the THS pipe.
Old 02-14-2005 | 10:22 PM
  #1253
46u's Avatar
46u
ORIGINAL: mt2sshpi
46u
Sorry do not no? I do not think some of then comes with the SS? But you should be able to find out on HPI web site. The parts we are talking about are some of the ones (as I put a lot in it) I put in my MT Racer Kit before I ever put fuel in it. It is not a MT2 but the best of the original MT that came with a lot of the hop ups right out of the box that the stander MT did not. This is the best I could fine for my MT Racer. I would get an 18SS but I have so much in my MT Racer with little run time on it (which I plain on changing shortly) so I am going to stick with it for a while. I have up grade to some MT2 parts. The new gear set others are talking about in this form that seems know one has yet are cheaper.
Old 02-14-2005 | 10:28 PM
  #1254
46u's Avatar
46u
For those that do not know exactly what I have here is the kit. I put a WHOLE lot more in it. I have over $1000 in it and I got a lot of the parts at a whole lot better deal then list.
http://www2.towerhobbies.com/cgi-bin...?&I=LXVM97&P=0
The pictures where before I put the MT2 shocks and the 100cc fuel tank.
ID:	229556   Click image for larger version
Old 02-14-2005 | 10:36 PM
  #1255
Spur gear stripped today, so i was going to buy slipper clutch. Which one is better.
This, [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXWC18]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXWC18[/link]
or this
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFYP4&P=Z]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFYP4&P=Z[/link].
The first one is more expensive, so is it better. Also, if anyone see's any U.S army decals for my humvee body, could you post a link. Plus, will the body i selected fit the truck.
Old 02-14-2005 | 10:52 PM
  #1256
MT2 Beater:
Number 1) is for the original MT, won't fit the MT2 unless you do a little mods.
Number 2) is for the MT2.
I'd get Number 2.
Just get this, you don't need the whole clutch:
http://www2.towerhobbies.com/cgi-bin...?&I=LXDLC0&P=V
Old 02-14-2005 | 10:53 PM
  #1257
Grantothismo
Do pretty much all the t-maxx/savage bodies go on pretty easly and look good on the mt-2?
Old 02-14-2005 | 10:57 PM
  #1258
jbooker82:
I don't know, I just took a chance on the Cuda. I really wanted to get the Charger, but the LHS did not have one.
I think you need to look for the smaller Savage bodies to make them work. The quad cab Dodge is too big, but the car bodies seem to work.
Old 02-14-2005 | 11:29 PM
  #1259
46u's Avatar
46u
The savage is 1/8 scale and the T max is 1/10. [8D]
Old 02-15-2005 | 04:54 PM
  #1260
46u's Avatar
46u
ORIGINAL: mt2sshpi
46u
Here is a place to get some of the gears a little cheaper then the tower. As much as $5 a gear cheaper. This is where I got mine.
http://www.carttonic.com/catalog/ind...21,11322,11896
http://www.carttonic.com/catalog/ind...96&pi_id=51513
[8D]
Old 02-15-2005 | 06:46 PM
  #1261
I'm getting the slipper clutch and removing the two speed, would the nitro racing clutch give any speed, or torque? Here is a link to it:
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXLW03&P=0]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXLW03&P=0[/link].
Also, would this clutch: [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFKM7&P=0]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFKM7&P=0[/link], work on the MT2.
Thanks a ton!!!!!
Old 02-15-2005 | 07:20 PM
  #1262
any one have fuel spitting out between the cooling head and the top of their motor? the screws seem tight but the fuel is getting all over my radio box & servo. thanks.
Old 02-15-2005 | 07:52 PM
  #1263
46u's Avatar
46u
My MT racer came with that clutch and I put one in my Nitro Rush and I like it. It is adjustable to where you can set it to come on at different RPM. The only problem is you have to cut it to do so and once you do that you are stuck with what you have. As far as a 15 tooth clutch bell depends where you run and what type of running you do. For me that is too tall of a gear. Will give you better top end at sacrificing torque and bottom end.
Old 02-15-2005 | 07:56 PM
  #1264
46u's Avatar
46u
ORIGINAL: longislandmt2
Sounds like a blown head gasket.
Old 02-15-2005 | 08:26 PM
  #1265
can any one tell me what difference having more teeth on the clutch bell makes?? Sorry if a lame question but im sort of a noob!!!!
Old 02-15-2005 | 08:50 PM
  #1266
ALSO, DOES ANYONE ELSE HAVE PROBLEMS WITH THE MT2 OVER HEATING? IM NOT RUNNING TOO LEAN AS I HAVE MADE SURE IT IS TUNED IT CORRECT, IF ANYTHING IT IS A ALITTLE RICH AS THERE IS ALWAYS SOME DROPLETS OF FUEL EXETING THE PIPE.
BUT AFTER ABOUT 1 - 2 TANKS OF FUEL THE HEADER IS VERY HOT AND THE ENGINE WILL STALL AND NOT START UNTIL IT HAS COOLED..... ANY HELP??
Old 02-15-2005 | 08:55 PM
  #1267
Thanks a lot for the help!
Old 02-15-2005 | 09:55 PM
  #1268
Well I have my answer for the engine mount... For the guys that have it, What kind of flywheel and clutch system are you using on your O.S. 18?
Anyone???
Bruno
ORIGINAL: Bruno
Hey guys, it's good to be back posting again! I am ready to put all the hop ups i bought during the winter on my truck. I have two questions for the O.S. 18 owner; What kind of flywheel and clutch system are you using? And what engine mount did you put on? As a side note, did you guys check out the MT2 SS on the www.hpiracing.com ? [X(] Some pretty nice stuff installed on it. I like the heavy duty diff.
Bruno
Old 02-15-2005 | 11:34 PM
  #1269
mt2sshpi
I ordered those gears from tower hobbies. Then i called hpi to see if they would work. They only work with the original MT. They just said that they wont work. Those gears u46 listed are not the mt-2 ss gears. Hpi's part number for the ss gears is 86336.
Old 02-16-2005 | 12:35 AM
  #1270
46u's Avatar
46u
I think you might want to look at this or either Tower has the listing wrong! The gears I am talking about will work with the MT2 but might not be the ones in the SS but they are heavy duty and will work! Correct me if I am wrong but I have talked to people that put these in their MT2. Scroll down and see what Towers has listen under parts and options for the MT2. The differentials on both the MT and MT2 are the same! Correct me if I am wrong but I do think I am thinking correctly. HPI support is pretty good but they all so told me I could not put the 100cc fuel tank in my MT Racer and if you look in this form I did it.
http://www2.towerhobbies.com/cgi-bin...I=HPIC1401&P=Z
Old 02-16-2005 | 12:43 AM
  #1271
46u's Avatar
46u
ORIGINAL: jbooker82
mt2sshpi
How did you order these when the listing says they are not in stock yet or is that wrong?
Old 02-16-2005 | 12:46 AM
  #1272
I thought that they would but then i called them to ask. They said that they wouldnt so i returend them so i could get my 45 bucks back. I didnt want to be stuck with them. They say that the dirve cup that goes on the pinion or bevel gear is to small for the shaft that the mt-2 uses. Same thing with the ball differentail that lists under mt-2 parts. The dirve cups for the axles that go to the wheels are to small. The Mt-2 has bigger axles. I have found that getting or trying to find what works between the MT and MT-2 can be quite fun. I am sure you could make the gears work. I am just going to wait until the ones that come with the mt-2 ss come out.
Old 02-16-2005 | 12:53 AM
  #1273
46u's Avatar
46u
ORIGINAL: jbooker82
This might be so and it would not be the first time a listing was worng. But I know since untill now they did not make the HD gears others have use these in the MT2. Whis I had both in my hand so I could see. [8D]
Old 02-16-2005 | 01:06 AM
  #1274
46u's Avatar
46u
You know what else? I just went to HPI’s web site and looked at the number for the stock gear for the MT2 and they have the same number as the stock gear for my MT Racer. They both take an A855. So if the axels are larger the ball cups where they go in to the gear must be the same. Goes to show HPI could be wrong all so? I think they told you that as they new the one gears would work but did not know if the others would!
Old 02-16-2005 | 02:04 AM
  #1275
46u's Avatar
46u
OK I figured it out! The one gear will work but this one will not unless you change other parts or what I think would be a minor modifications. Drill a hole may be a little more.
http://www2.towerhobbies.com/cgi-bin...?&I=LXTB55&P=Z
The ball cup where the drive shaft goes in that goes to the spur gear or slipper clutch is probably too small for the MT2. I am glade I did all this research as now I see how to put the MT2 slipper clutch in my MT Racer. Jbooker82 you did the right thing to cut down on any hassles. Bottom line in a way we all are right. Or you could look at it like I was wrong. Either way we know now!!!!!!!!!!!
