RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official HPI MT2 Thread
Old 07-17-2008 | 12:16 AM
  #17476
Default RE: Official HPI MT2 Thread
hmm, ya got me stumped then. Only thing I can say is try swapping the servos from the nami to the mt2 and see what happens then.
Old 07-17-2008 | 12:48 AM
  #17477
My Feedback: (19)
i got thinking tonight when i took my truck apart to clean it, is there a way to turn the mt2 into electric?
Old 07-17-2008 | 09:25 AM
  #17478
Sure, you would just need to come up with a mount for the motor and then just swap it out. The new brushless systems have a lot of torque. If you used a lipo pack you might be able to get one small enough to fit where the fuel tank is now.
Old 07-17-2008 | 10:10 AM
  #17479
what would give best traction hpi sand throwers or proline sand paws
Old 07-17-2008 | 11:11 AM
  #17480
My Feedback: (19)
ORIGINAL: KeithjV
well i got thinking that if i re done the guts of the truck that i could get it to work with either lipo or nimh batteries. i thought about trying to get the motor where the tank is, the esc either where the motor is or the throttle servo and the batteries in the other spot that the esc isnt.
Old 07-17-2008 | 11:46 AM
  #17481
drift what kind of surface are you running on?
sniper I would try to put the motor where the engine is now and the battery where the tank is. The esc you could mount on top of the receiver box or up by the front shock brace.
Old 07-17-2008 | 12:28 PM
  #17482
i say take everything off except the servo and drive line and see what fits then make mounts for it
and any ideas on the tires i listed
Old 07-17-2008 | 12:37 PM
  #17483
dragon, what type of surface are you going to be running on?
Old 07-17-2008 | 12:59 PM
  #17484
beach sand, i was thinking hpi sand throwers or proline sand paws, which would give the best traction
Old 07-17-2008 | 03:39 PM
  #17485
It looks like the sand paws should give you better traction in the sand. But the throwers look like you might be able to run on some grass as well as the sand. I could be run though.
Old 07-17-2008 | 05:03 PM
  #17486
ok would those fit on some 2.2 axial beadlocks
Old 07-17-2008 | 05:13 PM
  #17487
xxSLiMxx's Avatar
ORIGINAL: DriftingDragon
Are 2.2 beadlocks any good on a nitro? I have a rockcrawler and it moves slower then i can walk and sometime the bead pops off. I would think on a nitro the tires should be glues to the wheel.
Old 07-17-2008 | 06:20 PM
  #17488
how do you put the 18ss+ air filter together cause this is the first nitro i got and there is no instructions for the filter in the book
Old 07-17-2008 | 07:20 PM
  #17489
ORIGINAL: xxSLiMxx
ORIGINAL: KeithjV
Keep us posted muddy I hope you get it working tonight.
Thats a nice setup there xx. How do you like that rear exhaust?
I love it...no more messy left rear tires
what exhaust header and pipe did you use. wanna put a rear exaust on mine to
Old 07-17-2008 | 07:21 PM
  #17490
xxSLiMxx's Avatar
ORIGINAL: jumpanddrop
ORIGINAL: xxSLiMxx
ORIGINAL: KeithjV
Its made by Tsais, it comes with everything you need to install it. Have a look about 2-3 pages back (pg 691) theres pictures of my truck with the rear exhaust!
Old 07-17-2008 | 07:31 PM
  #17491
ya i saw that, im going to look for one of those now. also it makes more room for a bigger tank
Old 07-17-2008 | 07:32 PM
  #17492
xxSLiMxx's Avatar
You can fit a savage 160cc tank with a stock exhaust.
Old 07-17-2008 | 07:41 PM
  #17493
what site did you buy that exhaust from?
Old 07-17-2008 | 07:43 PM
  #17494
xxSLiMxx's Avatar
i got it from my LHS, But here if where i 1st found it http://tsais.com/products/exhaust/E1019-21.html
Old 07-17-2008 | 07:58 PM
  #17495
sweet man thx
Old 07-17-2008 | 08:32 PM
  #17496
Hey drift, what part are you having trouble with?
I know of a bunch of guys running the beadlocks and Ive never heard of them slipping under "normal" use. Could the tires be the wrong size for the rims you are using?
Old 07-17-2008 | 09:28 PM
  #17497
i havnt got the rims and tires yet
i figured out the filter but should the flywheel be rubbing against the brake disc cause i cannot mount it any other way
Old 07-17-2008 | 09:59 PM
  #17498
No it shouldnt rub. Can you move the engine forward on the mounts at all? It should only take a mm or so to clear.
Old 07-17-2008 | 10:18 PM
  #17499
i have no adjustment forward and back[:@]
Old 07-17-2008 | 10:19 PM
  #17500
xxSLiMxx's Avatar
Try posting a pic, maybe we can spot the problem.
