Gas Groovy
NC
I am not sure that I am in the right forum for this question but I hope someone can help.
I have a World Models Groovy 90 that I have been flying with a Saito 125. I am thinking about removing the Saito and trying a gas engine. I was wondering if anyone has tried a DLE20 on the Groovy? The plane will just be a Sunday Flyer and not be used for any type competions.
ORIGINAL: tes21966
I have several threads in this forum that discuss all the details you need to be successful withthe popularsmall gassies of today.up to 60cc. Good luck
NY
You won't regret getting the DLE. I have helped set up a couple of them with stock mufflers and it could not be easier. Very well-mannered and reliable engines. As Matt said, the Tech-Aero IBEC is a must-have!!
ORIGINAL: tes21966
Where is the best place to get a tech-aero ibec
[/quote]
Plus its great to set-up your fail safe properly to disarm the CDI if you lose signal. You still crash of course but at least you're not chasing the model.
[/quote]
Personally I dont't think fail safe should be set up to stop a combustion engine, but rather throttle back to idle, for two reasons:
1. An idling propeller will have a greater braking effect than a stopped propeller, thereby reducing the model's speed.
2. Often the radio link/control is regained after a "glitch", and you will then be able to make it back to the runway and land, instead of landing/crashing somewhere whith a stopped engine.
This is pilot's choise, of course.
Regards,
Magne
