Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
Reload this Page >
FANTASISTA EVO Build Thread by ISAAC NAJARY
Old 08-15-2015, 12:44 AM
  #101
najary
najary's Avatar
More
ID:	2114467   Click image for larger version
Old 08-15-2015, 07:17 PM
  #102
rbarthur
Issac, does the plans show the degree of travel for the flying surfaces? i.e how many degrees of "UP and "DOWN" for the elevator. Similar for the ailerons. If there is no mention on the plans what is your best guesstimate.
Old 08-18-2015, 08:36 AM
  #103
najary
najary's Avatar
More
ID:	2115205   Click image for larger version
Old 08-18-2015, 08:38 AM
  #104
najary
najary's Avatar
More
ID:	2115207   Click image for larger version
ID:	2115208   Click image for larger version
ID:	2115209   Click image for larger version
Old 08-18-2015, 08:40 AM
  #105
najary
najary's Avatar
More
ID:	2115211   Click image for larger version
Old 08-18-2015, 08:41 AM
  #106
najary
najary's Avatar
More
ID:	2115213   Click image for larger version
Old 08-19-2015, 09:48 PM
  #107
najary
najary's Avatar
More
ID:	2115614   Click image for larger version
ID:	2115615   Click image for larger version
ID:	2115616   Click image for larger version
ID:	2115617   Click image for larger version
ID:	2115618   Click image for larger version
ID:	2115619   Click image for larger version
Old 08-19-2015, 09:49 PM
  #108
najary
najary's Avatar
More
ID:	2115621   Click image for larger version
ID:	2115622   Click image for larger version
ID:	2115623   Click image for larger version
Old 08-19-2015, 09:51 PM
  #109
najary
najary's Avatar
More
ID:	2115625   Click image for larger version
ID:	2115626   Click image for larger version
ID:	2115627   Click image for larger version
Old 08-21-2015, 05:04 AM
  #110
bandicootf16
Hi Isaac
Nice work on the cooling ducting for the C54 and esc. Will you be using the Peter Haase light weight heat sink. Is this your first contra. Will you be starting with the recommend 22x20 rear and 22x18 props.
David
Old 08-21-2015, 05:45 AM
  #111
bandicootf16
Hi Isaac
A few more questions if you don't mind. In post 36 you show a link between the two undercarriage legs, aluminium I guess. What is it's purpose. Does it make the undercarriage behave more like a single piece gear set resisting potential folding back of the gear. Would a carbon link be better.
What wheel axles are you using as shown in post 37.
David
Old 08-23-2015, 09:56 PM
  #112
najary
najary's Avatar
More
ID:	2116370   Click image for larger version
ID:	2116371   Click image for larger version
ID:	2116372   Click image for larger version
ID:	2116373   Click image for larger version
Old 08-28-2015, 05:49 AM
  #113
najary
najary's Avatar
More
ID:	2117016   Click image for larger version
ID:	2117017   Click image for larger version
ID:	2117018   Click image for larger version
ID:	2117019   Click image for larger version
ID:	2117020   Click image for larger version
Old 08-28-2015, 05:55 AM
  #114
najary
najary's Avatar
More
ID:	2117022   Click image for larger version
ID:	2117023   Click image for larger version
ID:	2117024   Click image for larger version
ID:	2117025   Click image for larger version
ID:	2117026   Click image for larger version
ID:	2117027   Click image for larger version
ID:	2117028   Click image for larger version
Old 08-28-2015, 06:02 AM
  #115
najary
najary's Avatar
Originally Posted by bandicootf16
Hi Isaac
David
Hi David
Yes, I will use the Peter Haase light weight heat sink.
This is my first contra and I will be starting with the recommend 22x20 rear and 22x18 props.
Best regards,
Isaac Najary
Old 08-28-2015, 06:39 AM
  #116
najary
najary's Avatar
Hi Isaac
David
Hi David,
Most of the time, especially in a hard landing one undercarriage leg tach the ground before the other one, The link between the two undercarriage legs, made of aluminum, disperses the forces to the all area of the undercarriage mount.
I think that aluminum will transfer the forces better then carbon because the bolt undercarriage will squeeze the carbon.
I use these wheel axles:
http://www.probuild-uk.co.uk/landing...er-wheels.html
Best regards,
Isaac Najary
Old 08-28-2015, 06:51 AM
  #117
najary
najary's Avatar
Hi,
The plans mention only the elevator movement: 15 degrees up and down.
Best regards,
Isaac Najary
Old 08-28-2015, 08:41 AM
  #118
rbarthur
Isaac,
That helps.
Roger.
p.s. great craftsmanship.
Old 08-28-2015, 02:39 PM
  #119
drac1
drac1's Avatar
Originally Posted by najary
Hi David,
Best regards,
Isaac Najary
I used 1/16" solid carbon for this link. It does not crush.
Scott
Old 08-29-2015, 03:12 AM
  #120
MAVROS
Isaac just wondering what you mix the sanding sealer with in your post # 114
regards
Old 08-30-2015, 10:20 PM
  #121
najary
najary's Avatar
regards
It is talc.
Best regards,
Isaac Najary
Old 08-30-2015, 10:21 PM
  #122
najary
najary's Avatar
More
ID:	2117571   Click image for larger version
ID:	2117572   Click image for larger version
ID:	2117573   Click image for larger version
Old 08-30-2015, 10:22 PM
  #123
najary
najary's Avatar
More
ID:	2117575   Click image for larger version
ID:	2117576   Click image for larger version
Old 08-31-2015, 11:57 PM
  #124
MAVROS
Thanks ......so you brush this talc and sanding sealer straight onto the carbon ?
regards
Old 09-03-2015, 05:15 AM
  #125
najary
najary's Avatar
regards
Yes this fills the pin holes in the carbon.
Best regards,
Isaac Najary
