World models spot on 50
Old 04-13-2007 | 06:32 AM
bahamadude's Avatar
Default World models spot on 50
Anyone have done a review on this yet ?
Old 05-24-2007 | 08:40 PM
Default RE: World models spot on 50
Mr.Bahama dude purchase one then do a reviewAnd dont forgot the formula
keep your mouth close,eyes and ears open
Old 05-25-2007 | 03:45 AM
bahamadude's Avatar
Hmm bahamadude all one word !
Thanks for the reminder
Old 05-30-2007 | 10:01 AM
Any flight reports? Do you have any planes to compare it with?
Old 06-05-2007 | 07:41 PM
Hello, I just finished a Spot On 50. Put a OS 61 on it. No flights yet because of the weather. I will keep you posted.
Old 06-05-2007 | 08:09 PM
bahamadude's Avatar
os 61 Heavy duty hehehe
I was thinking of the new os 55
Old 06-09-2007 | 08:17 PM
Flight Report:
This is the Best Flying Airplane I have at the moment. Great Flying caracteristics + the 61 is perfect for it. The plane will end up being nose heavy. Total dry weight was 6.0 lbs but I had to add 2 oz in the back to get it to the recommended CG (117mm). I had to use the Spinner they supPLY + A Top-Flite wood propeller to reduce the nose weight. DOWN SIDE: Some of the decoration came off on the first flight (triangles on Stabilizer, left side) which is not a big deal, but really sucks. The Landing Gear is EXTREMALY heave, I will replace it with CF once I find it. You have to through away the screws they supply for you to use as axles (thats a no-brainer). I did all that my heart let me handle on the first two flights ( Knife edge are rock-solid no coupling, Snaps, Square Loos, Triangle Loops, All the snaps you can imagen).
Great Flying Airplane, I will start looking at 120 in a few weeks.
Best Regards
Old 06-09-2007 | 08:51 PM
Here is aPicture of the Spot-On 50 at the Airfield today. The quality of the Picture is low becauese I took it with my cell
Old 06-09-2007 | 09:22 PM
Who makes it?
Old 06-09-2007 | 09:30 PM
Made by: The World Models, distributed by www.airborne-models.com. Very un-expensive.
Old 06-09-2007 | 10:32 PM
What design is on the bottom? Does it have a airfoiled stab? Are the wings and stab plug-in and adjustable?
Old 06-10-2007 | 08:10 AM
http://www.airborne-models.com
sorry ducati didn't see your link.
Old 06-11-2007 | 07:57 PM
Antique:
The wings and stab are Glued in place. The Stab as well as the rudder have an airfoil. Here is a picture of the bottom of the wing.
ID:	702259   Click image for larger version
ID:	702260   Click image for larger version
Old 06-11-2007 | 08:23 PM
ducati996, Thanks for the info. I'm trying to make up my mind what I want to buy. I didnt consider the spot on because I thought the wing area was kinda small. What is the wing loading on your plane?
Old 06-12-2007 | 09:09 AM
Antique:
With the OS 61 the total weight goes up to 6 lbs making the wing loading 25.668 oz/sq ft. At 5.3lbs, like they advertise, the wing loading would be 22.673 oz/sqft.
Old 06-20-2007 | 08:53 PM
Antique:
I would like to show you some pictures of my radio set-up. I knew that my airplane was going to be nose heavy so move the radio as far as I could. Here a two pictures of the set-up. Hope this helps you on your set-up. From the picture I just notice that you can not tell, but the batery and the radio are actually under the Rudder servo tray( to the left and to the right of the servo).
ID:	707926   Click image for larger version
Old 06-27-2007 | 09:17 PM
My Feedback: (17)
Thanks so much for this info. Mine is on the way. Is there room for a header and pipe in the belly using a OS61 RF or OS61SF or a ST61XE?
Regards,
- Michael
Old 07-01-2007 | 05:50 AM
Nice looking plane! i am getting one soon and doing a Brushless conversion I have a World model Skyraider Mach 2 which i have converted to electric and it flies great!
this model could run the same sort of power system. Will let you know how i go and post up pics once done!
Old 07-01-2007 | 10:35 AM
MNATION:
With the OS61 the plane is nose heavy. I had to add 2oz to the tail to make it balance and had to use a plastic spinner. The wing load is already high the way I have it, so I would guess that using a tune pipe will make heavier. ABout having enough space on the belly pan I could not say because I have never use one. I have 15 flights on it and it is really good. The vertical performance with a 13x6 is good but is not unlimited. I will continue using other props to use how the engine performs.
Old 07-02-2007 | 02:04 PM
and compaired to the vensu 40 and kyosho oxalys 50... is this any better.. or is it the same or maybe even a little less good at f3a type flying? anyone knows?
Old 07-02-2007 | 04:01 PM
bahamadude's Avatar
ORIGINAL: golffreak_33
Would love to hear about your electric conversion.
What setup do you have planned to use ?
Old 07-02-2007 | 09:05 PM
apereira's Avatar
I will try mine with the YS63S, you can probably buy three of this aircraft for the engine price, but when I replaced my OS61 with that one, wow, it is 200gr lighter and has at least 30% more power in my opinion.
Regards
Old 07-03-2007 | 12:54 AM
ORIGINAL: bahamadude
i plan to use the same set up which is in my sky raider only difference isa that i will use a biger prop to get more power.
The set up is fairly cheap and very effective.
Set up is
Hextronic 50-55B 600 KV Motor
http://www.unitedhobbies.com/UNITEDH...idProduct=4907
hexTronik PRO 80A BESC w/ PC Programmability
http://www.unitedhobbies.com/UNITEDH...idProduct=4315
HXT D9 4100mAh 4S 15-25C Lipoly Pack
https://www.unitedhobbies.com/UNITED...idProduct=4129
i am runnig a 13X10APC-E Prop which gives me around 600-650Watts of power and average of 43amps. Thats at full throttle but most of my flying is done at half throttle and i get around 10-15mins flying times with no hassle of nitro motors and no cleaning up
i will probly run a 15X8 OR 14X8 OR 14X10 Prop to get a little more Power around the 750-800 mark maybe more. as i am going for performance over long run times.
If you have any other questions feel free to shoot them my way.
Old 07-04-2007 | 02:08 AM
But have anyone flewn it yet?
How does it compaire to the other 40-50size patterns on the market?
Old 07-05-2007 | 03:43 AM
does it have a canopy release mechanism like the groovy 50 3A?
