Shinden Build
Old 04-04-2008 | 07:48 PM
  #76
Default RE: Shinden Build
have not done any pattern contests since 98,,been playing with the 50cc gassers and may venture into IMAC
Old 04-04-2008 | 08:15 PM
  #77
Dave you don`t need any more cooling holes in the cowling
use a 16-11 or 12 apc. for your prop and I think you will be happy
e-mail me if you need any info on this airplane
[email protected]
Bryan
Old 04-05-2008 | 12:08 PM
  #78
My Feedback: (13)
THANKS CAJUN,I MAY HAVE A QUESTION OR TWO EVENTUALLY.
Old 04-14-2008 | 10:21 PM
  #79
My Feedback: (13)
jetpilot12,what engine did you use?
Old 04-15-2008 | 06:12 AM
  #80
My Feedback: (19)
YS DZ 160
Old 04-15-2008 | 10:57 PM
  #81
My Feedback: (13)
does anyone have a canopy they would they be willing to sell.? mine was damaged and it will be a while before bvm will have any.thanks
Old 04-20-2008 | 06:20 PM
  #82
rodney tanner's Avatar
Has anybody used an OS 140RX with an ES or Aeroslave pipe on the Shinden or is only for a YS short pipe set up?
Thanks in advance for any info.
Old 04-21-2008 | 08:47 AM
  #83
ORIGINAL: rodney tanner
Yes, the airplane is design around the YS 160DZ or YS170DZ with the short Hatori pipe set up.
Old 04-21-2008 | 09:15 AM
  #84
AmericanSpectre505's Avatar
You can also request a full lenght pipe tunnel when you order it. Atleast that's what I was told last year from David Shulman. at BVM. I know David is no longer there, don't know if that changes anything? I was planning to run the OS-160 in one at the time.
Brian H. will know!
Bill H.
Dist-2
Old 04-21-2008 | 03:29 PM
  #85
My Feedback: (25)
I would be willing to bet that a Dremel and some balsa or honeycomb could ensure that you can stick a 1.40RX in it.
Old 04-24-2008 | 09:02 PM
  #86
Thanks Ryan. Checking the weight again, it will probably be an OS 160.
Old 04-25-2008 | 12:07 PM
  #87
My Feedback: (13)
canopy? anybody?i need one .bvm 's gonna get tired of me callin'
thanks
Old 04-25-2008 | 09:55 PM
  #88
My Feedback: (25)
Rodney,
You'll likely be better off with the 1.40, unless you're at a high altitude.
For a good fuse floor, if you don't have honeycomb, or don't want to put any in, I've had good luck with sealing some 3/32 contest balsa with Balsarite and then glassing both sides with very light fiberglass. The Shinden shouldn't be hard to stick a tunnel in.
Old 05-01-2008 | 12:22 PM
  #89
No, it probably won't be hard at all. That fuse is definitely not lacking in space for it.
Old 05-07-2008 | 03:07 PM
  #90
Seeking input on the elevator setup - how is the pushrod system came with the kit? how difficult is it to convert to using two stab mount mini-servos? other recommendations?
Meanwhile, is the airframe light enough to make the weight if the plane is set up as electric?
TIA,
Kevin
Old 05-07-2008 | 07:16 PM
  #91
My Feedback: (19)
The pictures that are shown or of the D.E.P.S. system from Central Hobbies. The Shinden
does not come with anything. As for electric, the first Shinden ARF was flown with electric.
In the beginning the kits were a little hard to make weight, but the new kits are much lighter.
It would not be hard to put two servos in the tail, but I would check with Bryan Hebert before starting.
Bryan's email address is [email protected]
Good Luck, you will love the Shinden !
Jon
Old 05-07-2008 | 11:12 PM
  #92
I just wanna second what Jon put in the previous post. Every batch of the Shinden has had changes made to it (from what I understand), and the ones being produced now should easily make weight as electrics (there were stab and wing weight issues that were addressed after the first run). As far as the servos in the tail, you may want to check with Bryan before committing to that path. I'm fairly certain he has built a Shinden from each batch (maybe not the most recent that just hit the states), and he would be able to better advise you on what it would take to make that a viable choice. No matter what, he's always available to offer advice on setup and trimming... there's nothing like having the designer available to troubleshoot problems (if you even have any) with his airframe...
Old 05-07-2008 | 11:47 PM
  #93
Thanks for the input guys, and I will ask Bryan for his input.
By the way, it is nice to know the plane is getting lighter by the batch, hopefully by the time new shipment arrives, it will be even lighter. Is there any hardwares that come with the kit?
Kevin
Old 05-08-2008 | 07:32 AM
  #94
My Feedback: (19)
Old 05-08-2008 | 07:33 AM
  #95
My Feedback: (19)
Nothing comes with the kit, but all of the control surfaces are hinged in the mold.
You will not find a better hinging on any kit on the market.
Old 05-15-2008 | 06:53 PM
  #96
My Feedback: (13)
got mine all done 10.99999999999lbs.got a conopy loaned from d8 flyers ,thank you,i have the unpainted version ,so i'll post a couple shots of it soon.
Old 05-16-2008 | 12:51 PM
  #97
My Feedback: (13)
HERE'S[img][/img] SOME PIX OF MY UNPAINTED VERSION,HOUSE OF KOLOR CANDY RED SILVER AND BLACK,WITH CHECKERS ON THE BOTTOM.ADDED WEIGHT WAS SUPRISINGLY SMALL.JUST CAN'T GET CARRIEDS AWAY WITH THE CLEAR.THEN BUFF TO TAKE SOME OFF AND MKE IT PURRTY.WELL WHEN I FUGURE OUT HOW TO ADD PIX ,I'LL POST THEM,SORRY
Old 05-20-2008 | 04:40 PM
  #98
My Feedback: (13)
IF I DID THIS RIGHT HERES MY SHINDIN.
ID:	953502   Click image for larger version
ID:	953503   Click image for larger version
Old 05-20-2008 | 07:06 PM
  #99
My Feedback: (27)
Very luxurious color red!
Old 05-20-2008 | 09:23 PM
  #100
WOW Dave, I likey the candy! Very nice Job, enjoy!
Todd
