YS-170CDI Flight Report
#76
ORIGINAL: atul123
JB - speaking of a "maching plane" for the 170CDI, can you suggest one? The Focus 2 is an option but what are the others? And where can we get them? Any pointers would be appreciated.
Atul
ORIGINAL: Jeff Boyd 2
Great points . . The 170CDI would not typically be used in a 'Sport' style airplane (we can spec other sizes and type of engines to perform well in Sport planes with out the expense of a YS170CDI). As Atul mentioned, Giant scale and Pattern (which is really ONLY where you would use a 170CDI) are totally different animals. Only a Giant Scale pattern plane would fly anything like a pattern plane
. Giant Scale aeros fly great, but they aint no Pattern plane ! We choose our weapons
Cheers, JB
Cheers, JB
Atul
Cheers, JB
#78
Hi Atull
Be carefull to your choice to avoid to be over limit of 5 kg, cdi is a little heavier than normal Yamada 170.
I did a mistake about % oil. I saw Steph Carrier's father this morning. He told me there is 6 % oil and not 5 or 7 %. I'm very confused !!!
But % nitro is good. It is 20 %.
Regards
Regards
#79
The fuel economy is great. I flew an entire contest this weekend which included two warm up flights Friday (consisting of 2 seqences each plus a few maneuvers), four P09 rounds yesterday and two P09 rounds today on one half gallon of fuel.
I'm running a mixture of 3/4 Cool Power 30% nitro 5% oil, and 1/4 of 20% nitro heli fuel. There were many positive comments about the engine this weekend- presentation against the cool blue sky with little or no oil trail, power, smoothness and consistence- and easy starting each round.
All the best,
Don
All the best,
Don
#80
Hi Guys, i have a great planes 81" yak 54 and it needs an os160 i would love to try a dz170 on a 21X10 prop would this engine power this plane. I already have a gas powered qq yak so would like glow thought of os 200 but to heavy.
Mark
Mark
#81
ORIGINAL: Don Szczur
All the best,
Don
All the best,
Don
MattK
#83
CA
ORIGINAL: preatorian
Hi all,
very interesting result for 170 cdi ! Does anybody know where can I order this engine with the ignition system?
Best regards
Hi all,
Best regards
The factory told a friend of mine that the best thing to do is place an advance order with a hobby shop in Japan. Most hobby shops there do not need any advance payment but are taking orders. Trouble is, you need someone that speaks Japanese - either yourself or a friend, etc.
I've placed my order already
Atul
#85
TX
ORIGINAL: MTK
So that's around 9% oil, correct Don? And around 27.5% nitro
MattK
MattK
My experience with YS engines told me that they transitioned better on higher nitro content but with ignition this is usually not so critical. So why the high nitro content? There's certainly not any saving on fuel cost.
CR
#86
Has anyone tested YS with mueller-modellbau-technik electronic ignition?
http://www.mueller-modellbau-technik.de/
Regards
Regards
#87
My Feedback: (46)
NJ
ORIGINAL: Charley
I've converted several glow engines to ignition, even run one (Saito 1.50) on gas. In general, larger engines can run less oil, glow fuel or gas. Also, with spark ignition engines running methanol perform well on less nitro content than they need on glow ignition.
CR
ORIGINAL: MTK
MattK
MattK
CR
Charley, its all about performance in pattern. You can never have enough power<g> From what I've seen they run smoother and burn less fuel than the standard glow version. Then again, I fly electric<g>
#88
TX
Regards
Regards
CR
#89
Charly, look at this http://www.justengines.unseen.org/ac...s.html#aJW2014
I used it to convert 110s. Runs great on 5% nitrro, smooth transition,some fuel economy.
& a price is not so bad!
Rostislav
#90
My Feedback: (8)
WA
Slava, that is great. I assume the power is similar as well? The switch to 5% is reason enough to try that. Did you just drill a hole in the hub for the sensor magnet?
Charley, CH Ignitions has been converting glow engines for over 20 years, and they have a good conversion ignition that is much less expensive.
#91
Terry
The power is similar to when I was running 15% glow, & some what less than 35% I run latelly.
Hub is just big enogh to take 3mm magnet , mounted sensor with a plastik tierap holds good , & I can adjust timing.
Rostislav
Rostislav
#92
My Feedback: (8)
WA
That sounds great. As long as the tie wrap doesn't allow the sensor to slip you should be OK. I was thinking of converting a YS 1.20 I have but was unsure how to secure the sensor, and don't want to mount an internal magnet as in the 1.70 conversion.
#93
TX
ORIGINAL: BTerry
CR
#95
When I just did my convertion I run 35% nitro for couple flights to see if I lost power .
Didn't affected plug any how ,nitro % shouldn't be a problem
#96
TX
ORIGINAL: slava
CR
#98
TX
ORIGINAL: slava
I didn't try FAI fuel, just 5%. I wouldve but don't have it avail.
On 5% it was turning 15x8 at 9300rpm. & 16x8 at 9500 on 35%
CR
