kyosho inferno gt ready sey
Does anyone have any experience with the Kyosho Inferno GT ready set? I saw the it this months rca mag. |
RE: kyosho inferno gt ready sey
yes....yes i do
Does the car preform as well as you expected? I bought a inferno 7.5 rtr buggy some time ago and was not very impressed with the preformance of the rtr version. Is it a difficult to adjust the shift points , or have you felt the need to do that....thanks for the reply.....Bill
It's crazy fast on the road and burns the tires off. The stockers will last 3 days before your running on rims. You will definetly need a new set of rims and tires right out of the box. As far as the top end goes it's not the craziest i've seen, but thats due to the low low gearing.
I will be playing with some taller gears to get this big bodied car over 50mph. As far as the 2 speed goes, it's real easy to adjust and all the instrustions are included. My R/C car buddies love the cars performance and it shure is a crowd pleaser with the super realistic body. Good luck. You can't go wrong with this car. PHILSTER is another GT owner who has more experience with the car. |
I love the car. For a RTR, the engine is sweet. Shift points are as easily adjustable as they are on Monster Trucks. Most people report the shift point is a little early. Basically, you need 5-10 mins to take an allen wrench and make a quarter turn to a screw to delay the shift.
The car is huge compared to 1/10. It is more like 1/7 or 1/6 scale with the body. It gets looks. I am currenty running Ofna hard compound foams, which really make it feel more glued down. I love not worrying about stones, dips, ruts and such. It is a buggy with shorter, stiffer shocks. For tires and wheels, you are hanging with the 1/8 buggy crowd (17mm hex on the wheels). Ofna is like buggy central, so I head over to their site and look at the 1/8 buggy wheels and tires, copy the part number and find them at Tower or at my LHS. You can get Medial Pros from GS Racing, too. Ofna has slicks, gatorbacks and various foams. Spikes and nubs are too big for the body's wheel cut outs, but you could trim a little and run them. If you saw a RTR .21 powered buggy, that is not a straight up comparison to a .28 powered car with a 2-speed. I run Trinity MHP 20% with an OS 8 plug and she runs fine. Brakes are good. Servos are good for a RTR. Clutch bells with more teeth and dual brakes are just basic options, among others. |
Oh, I wanted to make a specific note on something: Radio Control Car Action was dead wrong on some things, because they didn't read the manual:
1. You do NOT have to take the trans out and you do not have to take the trans apart to adjust the shift point. You adjust it by sliding a gear forward, and tightening or loosening a screw. That's it. I forget what else they botched, but I think two of their errors were so bad that they'd need to print corrections in a future edition. Oh, yeah, they *****ed and moaned twice that the idle screw is a different type of screw than the high speed and low speed screws, requiring you to carry two screw drivers. First, if this is true, is it worth listing this as a 'miss'? Second, I just made a tiny idle adjustment yesterday with the same trusty old screw driver I use on all my vehicles. The idle screw is a phillips head, but one slot accepts a flat head screw driver anyway. I am not a fan of RC Car Action. They think their ***** doesn't stink. |
Thank you for your time and responce...the car sounds like a keeper....thanks
Thanks for the responce and the information. I've seen the car at my lhs and it is big. One Lhs sets up a track in there strip mall parkling lot twice a month(pretty rough surface), and this car sounds like it might be the ticket....Thanks.......Bill
1 Attachment(s)
These are the new tires I just picked up....They are a bit taller and fill out the wheel well nicely
Very nice...looks good....What no snow on the ground?
SupraTT, what tires did you go with?
Ofna# 86505....They came as a set pre-glued. They are alot better than the stockers
:D I have an OFNA GTP( same type of thing ), runs a Force .25 with 2 speed, I run both the foams and the OFNA belted slicks. Love this car!!! Larger than other 1/8 scale. Have to learn lots about suspention. Beast!
Ya ^^^^^ me too.....I need to set up the suspension properly aswell.....my rear-end whips around sooooo fast if I hit the gas on corners...this is my first on-road car so it's a day to day experiment. Im gonna start playing with the toe-in and such.
how well does the GT handle jumping?
1 Attachment(s)
I wouldn't tinker with toe in yet. I'd try the camber first. Add a little negative camber to the rears. Negative camber is when the tops of the tires lean in towards the body.
When the car corners, the cornering action actually puts more rear rubber on the road (when set with negative camber) as the car rolls over to that side, getting more rear tire to contact the ground, while simultaneously the front tires (set up with positive or nuetral camber) roll over onto their sides somewhat, giving up some contact area when cornering. Through a turn, you have given the rears a little more advantage than they'd have otherwise. Ultimately, you might not be able to overcome an 'oversteer' condition completely, but you can fight it. Oversteer is when the tail comes out first -- Usually a product of vehicle weight balance, power transfer and suspension/chassis design. For example, tail- heavy rear-wheel drive cars like a Porsche 911 can mimimize the oversteer and make it usable, but it is unlikely, even with a lot of rear negative camber, that it will ever be nuetral or understeer. If you can add beefier rear tires, that would help, too. Cars prone to tail-out driving benefit from negative rear camber (possibly in conjunction with positive front camber) and oversized rear tires. Toe in: This might affect the responsiveness and or tracking of the car (ability to respond to input and/or maintain a given path over bumpy or rutted surfaces). Toe in would be more forgiving, but less responsive. Toe out would be more responsive, but more prone to upset from bumps and ruts. Even off raod vehicles use some degree of toe out. |
Philster comes through again......I will give it a shot.
i have a few questions, this thing is making me rethink buying a revo. how do they handle jumping? are the bodies hard to get when you need a new one? whats the max ground clearance on the GT and can i slap some buggy shocks on there for more? thanks a ton in advance
Jumping: No.
Bodies: Painted = $120 (U.S. Dollars). Clear = $50-60 Bodies can be ordered from Kyosho direct or from dealer. No one stocks them. Buggy shocks: You could, if you get the buggy towers (from the 7.5 buggy) You could buy a buggy though. Groud clearance: 1/2 inch to maybe 3/4" max. |
it cant take jumps? its a buggy fo jeebas sake. well if i bought a buggy it wouldnt come with the car body, i like the realism of the car and the 1/8 size should make it be able to handle better off road than i 1/10 thanks for the info philster
Philster,
Is there an factory or aftermarket swap for the pull start?....I like pulling a trigger better than a rope. How long have you had the inferno GT? |
next week im ordering me up one of these,My LHS is way over priced on RTRs so im gonna have to order it online, but in the mean time im gonna head over there and pick up some wheels and moab tires they look perfect for on/off road
Does anyone have video running theirs???
Also where is the cheapest and dependable online store to order the gt from? |
video would be great, i never seen one run
I was always a big pull start guy, but my Mayhem has taught me to love the shaft start. The back of the Kysoho GXR28 doesn't look like it will accept a shaft start backplate. I am going to bring it into HobbyTown (where I bought it) and see if they have any Tiger Drives that will fit. They are usually nice enough to tinker with stuff like that. If anything, they could tell by looking at the back with the pull starter off that hopefully it is a rather univeral set up and we can find a Tiger Drive.
Jumps: Guys, understand that you are trying to have it all. Even real cars dont' have it all. In other words, you can't have a Monster Truck, a Buggy and a Touring/Rally Game car all in one. Something on the suspension has to be 'purpose built'. Rally game cars, like the Inferno, devour asphalt, packed dirt, grass, gravel and almost any street and parking lot condition: that is Rally Game. It has shorter shocks and towers than a buggy. Purpose: Better on-road handling than a buggy. A buggy has more shock travel and taller towers. Purpose: To handle off road conditions primarily. Videos: None to be found. My HobbyTown gets dealer/street prices on my Inferno GT stuff. A 10 dollar part direct from KyoshoAmerica is like 6 at Hobbytown. Just google, "Kyosho Inferno" or "Kyosho Inferno GT" and you will find dealers. You can order parts and parts bags direct from KyoshoAmerica (not full kits or cars). See website. Lists dealers, too. The most fun I have had was on a gravelly road that was next to some nice worn grass. Plenty of power to get through the grass, and all bumps. Jumps are OUT. No questions. Look up "rally game" to understand what rally games means (see race pics, videos, etc). Inferno GT is 'rally game'. |
Philster,
If you have any luck with the tiger drives let us know....thanks for the info |
I know this is not the correct forum......but. Just asking for your thoughts....as stated previously in this forum, I have a mp7.5 sports rtr buggy.When it get on the pipe, it screams...but theirs no snap at the low end. My tuning skills are basic. If I pinch the fuel tube at idle the rev's come up...but does not stall. Am I drowning it or starving it? I run an OS #8 plug and the motor has had about 25 tanks of fuel run thur it. Any thoughts? After haft a tank of fuel has run I'm at about 225 deg.
The price for a Inferno GT @ my LHS is $389.00 US What do you think? I'm wanting one Badddddd! |
yea, im not saying i wanna jump it like an MT, like 20 ft in the air. i mean like a foot or two, you know add a little excitement to racing. i mean keeping the jumps somewhat close to scale, know what im saying? nothing crazy just some air time
The chassis is up to jumps. The body, though, completety encompasses all parts of the chassis, so you'd be shredding up a $70 body. The chassis bumpers are not set up to deflect when landing, so I think it'd torpedo into the groung, rather that skim into a landing a la the buggies.
Hey I'm also thinking about this car. How fast does it go and is it good for a guy who hasn't ever used nitro before?
All nitro cars require someone to assist a rookie. All.
Here is a video, but the car in the video (Blue Subaru WRC) is almost straight out of the box. It has Ofna soft foams that stick TOO GOOD, becasue they grab so hard twice they roll the car. The Inferno Gt in the video is out of the box, and the trans is in second gear the whole time because the owner didn't get a chance to adjust it. Car is also sitting higher than it should because the owner didn't get a chance to lower it. http://rivercityrc.org/records/videos/clark.wmv |
That video looks amazing..I think I am sold...and going to order through http://www.rcplanet.com/kyosho_infer...71087_prd1.htm .They have it for $379.00....about $430.00 shipped.
Is this a dependable site to order? |
Yes - dependable, but the final price is kinda steep.
Let me look around for ya. |
yea, thats the same place i was gonna order from a lil later this week$488(GT,2 sets of moab tires and fed ex 1-3day)
ORIGINAL: Philster Yes - dependable, but the final price is kinda steep. Let me look around for ya. Thank you kind sir...;):D I tried looking around that is what I came up with[sm=confused.gif] Actually one of my LHS is the only one that carry it...well they sell for $449..before taxes.So if I do buy it from them it would cost me $486.00...[>:]Damn LHS rip off[:@] Do what you can Philster (or anyone else that knows a place that sell it chepear).....and Thanks again..... |
Well, $389 seems to be the going Web rate. I can't see the shipping differences without actually entering all the info for my billing.
I got mine ordered through HobbyTown USA for $369. I know the Inferno GT is pretty hot right now, so prices did go up. I got mine when there was a light buzz about it, but it is getting very popular. |
ORIGINAL: Philster Well, $389 seems to be the going Web rate. I can't see the shipping differences without actually entering all the info for my billing. I got mine ordered through HobbyTown USA for $369. I know the Inferno GT is pretty hot right now, so prices did go up. I got mine when there was a light buzz about it, but it is getting very popular. Another question.....Where can I get unpainted bodies? I read somewhere that the painted bodies sells for $120.00 on KYOSHOAMERCA site...which is nice how very much detailed it is but damn[X(]........ Thanks again...................;) |
Kyosho bodies are some of the best. The $119 price tag is the price for a painted body at 'list price' direct from Kyosho. The street price for painted bodies (gotten from a dealer) is between 60-65 U.S. bucks, which is about right for a huge body.
According to Brian at Kyosho, clear bodies will ship soon for about 45-50. |
Just ordered mine through RCPLANET.com.$395.00 shipped.Actually less than I expected.Can't wait!!
:D [sm=thumbup.gif] |
how did you get it cheaper than what the web site says?
Also its $50 shipping for 1-10 bodies but how much are the bodies? i eamiled Deltaplatik about it but the price list is in euros what would it be in US? |
