Reload this Page >
GTM 1/2 Scale Fokker Triplane
Old 02-15-2013, 08:58 AM
  #276
vertical grimmace
vertical grimmace's Avatar
Default RE: GTM 1/2 Scale Fokker Triplane
The DR1 had a throttle?
Old 02-15-2013, 10:33 AM
  #277
TKFOKKER
Gentlemen
I have a friend who is looking to buy a built 1/4 scale Fokker Triplane, a Balsa usa if possible. Built.
Let me know if there are any out there.
TK
Old 02-17-2013, 07:55 AM
  #278
puplover
Thank you Geezer from Houston. Will check it out.
Puplover
Old 02-18-2013, 10:58 AM
  #279
TKFOKKER
Camera died, no pic's till I resolve the problem.
TK
Old 02-24-2013, 08:18 AM
  #280
TKFOKKER
Well I found another camera in the drawer, not as nice as the old one I had, but will do for now.
Finally finishd up the three cockpit brass parts. Now I can get back to working on my own stuff.
TK
ID:	1855713   Click image for larger version
ID:	1855714   Click image for larger version
Old 02-24-2013, 08:36 AM
  #281
geezeraviation
geezeraviation's Avatar
Tom, you should have cued up a drum roll for that, well done, beautiful work. Anxious to see the airframe come together, go man go! lol
Doc
Old 02-24-2013, 06:38 PM
  #282
Rebel Flyer
Insane... Simply beautifull. How many hours do you have in all the brass there?
Why don't you sell me one of those? How much will that cost me?
Rebel
Old 02-25-2013, 06:43 PM
  #283
TKFOKKER
Today I managed to make up the patterns for the turtle deck and side plywood fairing. Also I made the foot skid area on the cockpit floor. I used corregated plastic which will be painted with aluminum.
TK
ID:	1856291   Click image for larger version
ID:	1856292   Click image for larger version
Old 02-25-2013, 08:42 PM
  #284
valleyk
Absolutely stunning TK! By the way that book on the bench looks very interesting.
Old 02-25-2013, 08:46 PM
  #285
abufletcher
abufletcher's Avatar
ORIGINAL: valleyk
I was thinking the same thing. What the title?
Old 02-26-2013, 02:12 AM
  #286
Teus
Teus's Avatar
It don't surprises me if it is the 3D DR-I book from kagero.
[link=http://www.shop.kagero.pl/en/fokker-dr-i-the-aces-aircraft.html]Fokker DR.I The aces" aircraft[/link]
A must have for DR.I lovers
Old 02-26-2013, 05:10 AM
  #287
TKFOKKER
Yes Gentlemen that is correct. I have a pile of Dr.1 books and this one is right at the top for detail shots. Very useful to the model builder!! I highly recommend it if you are a triplane person.
Thanks Guys
TK
Old 02-26-2013, 06:11 AM
  #288
geezeraviation
I just ordered one off Amazon, looks like aa good addition to the files.
Doc
Old 02-27-2013, 07:34 PM
  #289
TKFOKKER
Doc they also have the D-7, same format.
Well I decided to re-inforce the tail area where the stab bolts down. Added a few triangle supports. Also started to get the servo's figured out. Location and how I will do it. Up forward as much as possible for the servo's weigh in at 1/2 a lb. a peice. I will run carbon fiber tubes all the way back to some bellcranks then cable out to the horns. These are Hitec 805 MG, @ 343 oz each, two on elevator one on rudder. I plan to put the batteries and reciever on the same location. Access will be thru the belly panel.
TK
ID:	1857146   Click image for larger version
ID:	1857147   Click image for larger version
Old 02-27-2013, 07:39 PM
  #290
abufletcher
Why not a full pull-pull cable system? What's the advantage of the CF tubes?
Old 02-28-2013, 04:02 AM
  #291
TKFOKKER
Abu
There will be a scale cable coming out of the proper location at the tail. A pull pull off a large bellcrank just inside the fuse. The long carbon tubes will be over 4 ft. long to get there from the front connected to those bellcranks.
TK
Old 03-06-2013, 01:27 PM
  #292
jeffEE
jeffEE's Avatar
So while doing more research on my Fokker V. 11, I came across this web page.
http://www.fokkerdvii.com/pics/
I know that many of the WWI builders out ther may have already found it, but in case you missed it, it contains 3 pages of pictures. And not all DVII's, most are of the factoy and the building process. Some I have found in other places, many I had never seen before. But the one that caught my eye was this one. It showes a DRI tail skid with a control horn to be used for direction control. I never knew a tri plane had that. Learn something new everyday I guess. I also liked the one where the 2 guys were painting a DRI's wing.
I just looked at the DRI picture a bit closer. I do not think its a DRI. It lookes like it is a wooden frame. The web page must have the wrong label on the pic. Oh well, so much for my big discovery.[&o]
ID:	1858959   Click image for larger version
Old 03-11-2013, 08:23 AM
  #293
Cal Branton
My Feedback: (17)
Some progress on Kirk's and my Triplane.
ID:	1860736   Click image for larger version
Old 03-11-2013, 08:26 AM
  #294
Cal Branton
My Feedback: (17)
More
ID:	1860738   Click image for larger version
Old 03-11-2013, 10:31 AM
  #295
TFF
Looks like all Dr1 fuselage labels are really Camel pix.
Old 03-11-2013, 11:23 AM
  #296
wally3185
My Feedback: (26)
wally3185's Avatar
Does J D ever help you?
Old 03-11-2013, 11:33 AM
  #297
Rebel Flyer
No,but a little Tennessee sipin clear does from time to time.
Old 03-24-2013, 09:18 AM
  #298
Cal Branton
My Feedback: (17)
Some progress on the LG
Old 03-24-2013, 03:51 PM
  #299
TKFOKKER
Hey Kirk looking good!!!
I picked up my wheels today. Aluminum black 16 inch rims 40.00 bucks each plus tires and tubes. 130.00 total. The white tires might not work, i started standing off the tread and did not come out as good as the tires I used on my 1/2 scale D-8. Might have to look for diffrent rubber. The rims are real nice. Now I have to get my axel made up.
TK
ID:	1866086   Click image for larger version
MousePower (02-13-2021)
Old 03-24-2013, 04:04 PM
  #300
TKFOKKER
Having finalized the servo mounts, I have now been working on the bellcrank area. I need to send away for my push rods nd servo connector ball links. I will be using carbon fiber rods with 6/32 ball ends. As you can see I have made my bellcranks from G-4 material. I most likely will also change the brass tubes holding the horns to carbon fiber. Still a lot of work in this area.
TK
ID:	1866089   Click image for larger version
ID:	1866090   Click image for larger version
ID:	1866091   Click image for larger version
