Pitts S1-S by EMHW
#1926
Since you had to do a redo, your are right to completely redo everything affected by the original redo.
Are you redoing redo's?
Redo until it is correct Robert. This ain't no bird for halfway measures.
We will stay here and cheer you on
Ken
Ken
#1932
Well sorta, I had a few places I would like to take it to this year. But they were not in my original timeline, added later. In reality there is no time clock on my builds, just the present.
Did someone say something about airspades?
Well yes I do have airspades!!
They will be non-functioning, a simple clip on for display.
#1935
On mine, because that is the way of the full scale. On the full scale, I would assume the front is round tube because it needs the strength to support the stab and itself whereas the tail wires are self supported by each other in completing a circle around the tail.
#1936
Originally Posted by [email protected]
I know you had a date you wanted to have it done for. Just wondering g if you were still going to make it.
#1941
Well, as soon as the wife is ready, she will be taking me to the emergency room. I had the airframe mounted to the picnic table going to finish the run in. And when it started, well, lets just say "Luck was not on my side". See, I had not fastened the tail down and when it fired up I did something stupid! Stay tuned for more of the story.
#1948
And now for the rest of the story!
When the engine fired up, my first reaction (as usual) was to get behind it. As I cleared around the side of the fuse the tail started to lift, yes I forgot to secure the tail. I reached for anything to hold the tail down, in the moment all I could see was the plane doing a loop around the end of the picnic table and disintegrating. Well, just my luck my hand finds the aluminum that surrounds the cockpit and a sliding gripping motion does not go well with a sharp object. I lacerated all four fingers down to the bone. So! My ability may be limited just a bit but for a little while. Even though the hand may be limited I will give it until tomorrow and get back at it, slowly!
#1949
Tomorrow I will get the fuse back on thee table to finish the run-in. I will take a pic so you guys can see how it was mounted and then you will understand why I hand visions of it going around and over the end of the table.
