Pitts S1-S by EMHW
#1902
I have been pondering what is next or needs to be next and just realized, I am almost done with the details until after painting. I will (hopefully) get the cover plates done tomorrow and I think it is time to finish the top wing. Then I believe, other than finishing the canopy, it will be time for some paint. Everybody cross your fingers with and for me.
#1905
Sitting here pondering a good way to put the fairings on the L/G and I'm not really liking the gear covering method I utilized. It is just to flexible and wrinkles up at the balsa block points no matter how well its shrunk. So! I pulled out a piece of that .040 PTEG and commenced to wrapping the gear. I think I like it, stiffened it up real well and also fattened it up a bit as well. The first pic is the left side without the PTEG. Pic 2 has the PTEG wrap.
#1907
It seems the closer I get to the end of this build the more it takes to impress you guys. Quite frankly I thought the wrapping of the L/G with plastic was shear genius! LOL
#1909
Actually, it is a pretty smart solution. What did it take to get the plastic to conform to the L.G. legs? I am assuming the plastic is wrapped 180 around the gear legs.
But because we love you (a little bit anyways)
Ken
#1910
Back in near the beginning of this thread a few guys posted places that had photos of the Red Eagle Pitts. I have been looking for those links as well as where I found my pics at but can not find either. Please post where those pics were at, I need a couple good shots of the eagle and all mine have been reduced for posting here.
#1915
http://www.freesmileys.org/
http://www.sherv.net/emoticons.html
On the other you have to copy the URL and hit insert picture. That will also work here.
looking more and more better, My English teacher can take a flying hike
Ken
#1916
That's a hard one to explain, short version. Clamp one side on flat, heat at curve and pull around, when close use a flat surface like a sanding bar to press flat while heating. I use the covering gun for heating, just watch the plastic as one goes.
#1921
I believe so, you want a link?
http://www.rcgroups.com/forums/showt...di+sheber+pitt
Did you ever start your little one??
#1922
Thanks Robert I will book mark that.
I have to wait a bit yet, till at least late next month. Not going to be in shape to do much of anything for awhile, neck surgey. Replace a disk. Got fitted for the neck brace this morning.
Packing and moving most of our stuff to storage. Until I start getting disability We are moving in with some friends from church as we can't make rent till then. So I am not even working on my little CL RM Bibe that is getting close to covering. After we are moved out I will order plans from the contact you gave me.
Here is a picture of it if you don't mind and the build thread.
http://www.rcuniverse.com/forum/cont...-bi-plane.html
Ken
Ken
#1924
Thanks Steve
Things have a way of working out. The process is just bewildering. This past week when I was confined to my recliner for 48 hours (after a CT-milogram) convinced me my wife is not physically able to hold up for an extended convalescence on my part. So being with another family for that period will take a load off of her.
After the neck surgery I am looking at hand and lower back surgeries. In a few months I should start getting disability, and then we can get our own place again. In the mean time I wont be such a rough burden on my wife with others around.
The Lord always provides. Often not in the way we expect or want. But he does better than our expectations and wants.
Ken
Ken
#1925
The new cockpit aluminum was positioned last night. This morning I have repositioned the windscreen more appropriately. The glass frame was a bit out of shape so I am making another one. I probably could have used heat to reset the previous frame but it also had small notches from the cabane.
