IS-2 Buld thread
Old 05-16-2011 | 12:13 PM
Default RE: IS-2 Buld thread
kclank,
Wow, this is going to interesting to watch. Keep on posting.
Jim
Old 05-18-2011 | 02:37 PM
kclank's Avatar
another little bit done. I will start filling and sanding now to blend in mismatches and fill gaps. i am also planning on adding epoxy between the skin and sub-frame for added strength. After sanding the fenders will be added. then on to hatches, etc.
Old 05-18-2011 | 05:22 PM
Looks really good to me so far...........do you ever hold scratchbuilding classes? I could stand to learn some new ways of doing things.
Old 05-18-2011 | 06:53 PM
yellowshaker's Avatar
Really good proegress! Can't wait for this thing!
Old 05-19-2011 | 07:16 AM
kclank's Avatar
ORIGINAL: Rex Ross
Looks really good to me so far...........do you ever hold scratch-building classes? I could stand to learn some new ways of doing things.
I do not think I could teach you anything in this hobby Rex. But i would take your money and you could sleep through the class. BTW this is a kit (it says so on the advert.) not a scratch build.
I will bring your track links to this weekend's meeting.
Old 05-19-2011 | 08:53 AM
  #31
HAL_HUSKER's Avatar
2kclank
awesome job... very interesting... welldone
Old 05-19-2011 | 12:14 PM
  #32
ORIGINAL: kclank
ORIGINAL: Rex Ross
Are you saying that I am one of those old dogs who can't be taught new tricks? Also, I only go to classes that are free. The neat thing that caught my attention was the subframe that you "scratchbuilt" on your "kit" to support the exterior skin. That gave me an idea on how to do a future bucket list project a lot easier and better. Thanks.
Old 05-19-2011 | 05:34 PM
  #33
kclank's Avatar
ORIGINAL: Rex Ross
ORIGINAL: kclank
ORIGINAL: Rex Ross
Are you saying that I am one of those old dogs who can't be taught new tricks? Also, I only go to classes that are free. The neat thing that caught my attention was the subframe that you ''scratchbuilt'' on your ''kit'' to support the exterior skin. That gave me an idea on how to do a future bucket list project a lot easier and better. Thanks.
Thanks but again i do not want to take the credit. the sub-frame was part of the kit. It is kind of like building a boat from the inside out. As far as you being an old dog? hmmmm! niceness lessons kicking in here. My dogs might take umbrage if i included you in their circle of quality. lol
Old 06-19-2011 | 05:48 PM
  #34
kclank's Avatar
A few more pics of my latest activity. added fenders, bracing, weld lines, exhaust, deck grill, aft hatch, etc.
ID:	1625430   Click image for larger version
ID:	1625431   Click image for larger version
ID:	1625432   Click image for larger version
Old 06-19-2011 | 05:57 PM
  #35
Wow! This is tempting me to try to build an IS 3 out of plastic sheeting(just basic, little bit of water injection here and there) and generic parts.
...I need to get to the drawing board. Wait, Check out this...http://forum.worldoftanks.com/index..../page__st__160
Go to the JS-2C. Now thats gonna require some gears.(if your doing suspension)
Old 06-19-2011 | 06:27 PM
  #36
Buckeye36's Avatar
That is really looking good!</p>
Old 06-21-2011 | 11:41 AM
  #37
kclank's Avatar
Go for IT!
Old 06-21-2011 | 04:41 PM
  #38
Looks great so far kclank. Can't wait to see the finished model. One of the guys that comes up to battle with the N.E.A.D. boys has one and it is freakin awesome. I didn't get to go too the last meet and missed it but i saw the pics. Great model.<div>  </div>
Old 06-21-2011 | 05:02 PM
  #39
kclank's Avatar
thanks for the kind words. i have not had much time to spend on it but it is getting there.
Old 06-22-2011 | 01:22 PM
  #40
kclank's Avatar
More pics. added the spare track mounts, spare fuel tank mounts and tanks, fabricated a travel lock for the gun, built more hinges and mounted the engine hatch, added some stowage, some tie down rings, and a pioneer tool.
ID:	1626422   Click image for larger version
ID:	1626423   Click image for larger version
Old 06-22-2011 | 01:27 PM
  #41
kclank's Avatar
Hey Sevo. In the center bottom picture of the 7 you had sent me before. Frontal view. Can you tell me what the object immediately to the left of the driver's view port is (as you are looking at the tan)? Some kind of mount or?
Old 07-04-2011 | 07:38 AM
  #42
kclank's Avatar
A small update. Started work on the turret. The turret supplied with the kit is a Juwa KV-85. I begin by modifying the mantlet, since the IS-2 is slightly different from the KV-85 as it is off set and a small bit wider. I have adapted a driven sprocket to the turret ring and positioned the turret drive motor. I am trying to use a modified Heng Long recoil motor. All things are moving pretty slow at the moment.
Old 07-04-2011 | 07:43 AM
  #43
kclank's Avatar
ID:	1631308   Click image for larger version
Old 07-04-2011 | 10:17 AM
  #44
Panther F's Avatar
I'll be watching this as I will be doing a similar build only making a KV-122.
- Jeff
Old 07-04-2011 | 01:12 PM
  #45
kclank's Avatar
ORIGINAL: Panther F
- Jeff
thinking about it myself
Old 07-04-2011 | 02:32 PM
  #46
Panther F's Avatar
I finish this Sherman I'm working on, then return to the Panther I started way back I'll start another side project using the HL KV tank.
I have that same turret kit and a muzzle brake on the way. Around here somewhere is a barrel that should work and some DT late wheels that might look good. Should be a breeze.
After a while, all those Russian tanks start looking the same.
- Jeff
Old 07-04-2011 | 03:47 PM
  #47
That is exactly the purpose of my first question in the beginning of the build. Did they supply an actuall IS-2 turret or the KVV-85. Obviously it is the KV-85.
I am not dissapointed but I would have liked to see an IS -2 turret especially with the price of these high end kits. It bugs me that they just substitute one for the other, rather than cast the proper turret. You are still doing a wonderful job kclank and it looks great. Looking forward to the finished product.
Old 07-04-2011 | 03:53 PM
  #48
kclank's Avatar
ORIGINAL: Panther G
Other then the mantlet and gun can you specifically point out the differences between the KV-85 and IS-2 Turret. So far i have not seen them. Anxious to learn!!
Old 07-05-2011 | 12:10 PM
  #49
The cupola is slightly different. the IS turret is longer and also slightly wider. The gun mantlet as you stated is different. I know there was one or two other small differences. It probably really does not matter. The turret looks good scale wise with the kit, so no real issue. I just get a little bugged with the substitution thing. <div> When i pay good money for a specific item, I like that item to be as accurate as reasonably possible.</div><div>Kclank , I'm definitely not trying to get you upset. I love the job your doing and i really like the kit. I'm just a little flakey with some things. LOL</div>
Old 07-05-2011 | 12:51 PM
  #50
kclank's Avatar
ORIGINAL: Panther G
Hey Bro, not upset. i just not have been able to discern many differences and looking for real help. the hatches, hings, periscopes, vents, hooks, weld lines, etc all look the same to me.
I just now did some scale up measurements from a Tamiya 1:35th JS-2 turret, multiplied those measurements by 2.1875 (should be the factor for 1/35 to 1/16th up-conversion) and the numbers are spot on (plus or minus 5%). Can you tell me or show me the source of your data. BTW the cupola is also virtually identical. At the moment i am fairly confident of the relative accuracy of the JUWA KV-85 turret vs. the IS-2. I remain open minded to any reference material you can point me to, As always keep in mind different factories and versions. I am building a 1944 Chkz. Back to you.
