Reload this Page >
New transmission from ETO Armor
Old 08-03-2014, 06:52 PM
Martellus
Very exciting. Beautiful work
Old 08-12-2014, 07:01 AM
sevoblast
A few more photos of the ongoing work on the new transmission systems from ETO. So far Tiger 1, King Tiger, Sherman, Panther and KV1/KV2 are finished. Thursday we go to machine shop to drop off the drawings for hole placement in the trans mounts and get a few other odds and ends made for the systems.
JS 2 is going to be fun. As any of you who have one know the stock TU's sit at an angle for correct alignment with the final drive shaft exit from the hull. We might have to get creative on that system but we will get it done.
ID:	2021809   Click image for larger version
ID:	2021810   Click image for larger version
ID:	2021811   Click image for larger version
Name:	005 (2)aa.jpg
Old 08-12-2014, 07:08 AM
sollie
sollie's Avatar
Damn, it look so strong. Nice work Robert
Old 08-12-2014, 08:18 AM
Martellus
I love that design, simple and robust
Old 08-12-2014, 09:04 AM
cleong
The complicated part of this deal is hidden in the gray cylinders that go between the motors and the gearbox bulkheads. They are, however, probably better protected against dust and dirt.
Old 08-12-2014, 09:07 AM
  #31
sevoblast
The system will have the final test in about 10 days. We will do a Tank Day at 35th Battery Museum during which children will be invited to run the tanks. If they survive that, which I have no doubts they will, then we have a winner here. I will of course post photos of that event.
Cleong, very true but you are correct, no dust or dirt can get in the reduction systems.
Old 08-12-2014, 09:30 AM
  #32
Martellus
I understand, I meant more of the frame and mount
Old 08-12-2014, 10:28 PM
  #33
sollie
sollie's Avatar
be sure to make a video Clip of those tanks running about now :-)
btw, how about these New ones, would they fit to replace and old type TU ?
Old 08-13-2014, 12:06 AM
  #34
sevoblast
Yes, Sollie, it should. That is from an early Tamiya King Tiger? Videos are VCO's department, she's the expert on them. I'll get her on it early next week and see what we can do.
Old 08-13-2014, 12:20 AM
  #35
sollie
sollie's Avatar
I would Guess so, just a question about getting parts for a TU like that over @ World RC Tank Community on facebook from a user . I mentioned the up comming TU's from you instead of searching for parts for the old one
Old 08-13-2014, 04:16 AM
  #36
sevoblast
Have him get the measurements of the width of the output shafts end to end and also the width of the hull inside. It does look like the original KT set up and if so then yes, my KT system will fit.
Old 08-14-2014, 10:03 PM
  #37
sollie
sollie's Avatar
The measurement of the width of the output shafts is 12.5 cm, the width of the shafts and to end is 16 cm.
Old 08-17-2014, 12:50 AM
  #38
sevoblast
16 cm is King Tiger. My transmissions will fit, no problems, although you may have to drill mount holes in the lower hull.
Old 08-29-2014, 08:28 AM
  #39
sevoblast
Default Update transmissions
It's been a few days since an update. I now have 11 transmissions built. Machine shop has the mounts for drilling for the standoffs and to make one other little oddball part we both forgot in the production drawings stage. I expect both batches to be ready early next week. I have also told machine shop to make another batch of all the machined parts, this because the interest in this system is pretty strong. I have also ordered all the other goodies from my suppliers in EU.
Part of the new batch of machinings is for Panther/Jagdpanther. Since the nose of that tank is pretty crowded we had to modify a couple parts to keep to my goal of everything bolts in with just two additional holes drilled in the hull floor.
Enjoy the new photos. There will be more coming as the new parts are delivered and all the tanks will be photoed with the system installed. JS is still a head scratcher but we'll lick that little problem also.
ID:	2026979   Click image for larger version
ID:	2026980   Click image for larger version
Old 08-29-2014, 01:32 PM
  #40
sollie
sollie's Avatar
looks like the Stock ones in my Tam JP needs to be replaced With one of you're baby's . Any test drives yet ?
Name:	IMG_6768 (Medium).JPG
ID:	2027016   Click image for larger version
Old 08-29-2014, 01:51 PM
  #41
thecommander
They look bullet-proof and very solid. I can't wait to get my hands on them.
Old 08-29-2014, 08:09 PM
  #42
sevoblast
Sollie, I expect the special Panther/Jagdpanther parts shortly. The moment I have them in my hands a Panther will be tested. The modification to my system involves the final drive and is quite simple for the machine shop to do, it's just them finding the time to do it and make enough of the modified parts for me to get to work on Panther.
Old 08-29-2014, 09:09 PM
  #43
Strato50
Strato50's Avatar
Robert whenever you start looking at the HL / Taigen side of things I suppose they would fit both versions. .say, KV-1 HL plastic and Taigen metal lower hull.. the spacing is the same so the mounting plates on your gearboxes should fit both, perhaps?
Anyway I bet a lot of Taigen Tiger, KV-1, KT and Panther (Torro metal) owners would love these (including me)
Old 08-30-2014, 02:43 PM
  #44
crxsidan85
my tamiya tiger 1 could use this i am afraid to really drive mine hard as the stock gearboxes can fail rather easily sometimes. when will eto have these available?. do you guys have tiger 1 metal tracks as well?
Old 08-30-2014, 11:41 PM
  #45
sevoblast
Strato, when I'm finished with the Tammy line I'll work on the others.
crxsidan, I expect to have the mounts in my hands later this week. Once I have them we're in business and I'll announce here.
Old 08-31-2014, 05:36 AM
  #46
YHR
YHR's Avatar
Gear Ratio? Will you be making different bevel gears to allow the ratio to be changed? Seems like it would be relatively easy to interchange drive shaft bevel gears.
Old 08-31-2014, 06:16 AM
  #47
Panther F
Panther F's Avatar
I don't think a lot of HL owners will put a tranny in their tank that cost's about 3 times as much as the tank. Maybe a fully customized HL tank that Tamiya or Taigen doesn't make.
I plan on getting a few of these monsters for my tanks that REALLY need them.
Jeff
Old 08-31-2014, 08:21 AM
  #48
sevoblast
Dan. After I get things up and rolling I will experiment with different bevel gears but one has to be careful as the geometry of the system is designed for 1:1 on the final drive shafts . However, there is a different path I'm taking on that. If its successful it will be announced.
Old 08-31-2014, 10:04 AM
  #49
YHR
YHR's Avatar
Yes now that I look at it again, it isn't a case of just installing a larger bevel, You would have to move the drive output center line to do this, and of course this isn't adjustable.
They probably have grunt, and this torque will carry through all ranges..
Old 08-31-2014, 09:02 PM
  #50
sevoblast
Hence my different tack. As they are they are stump pullers and quite robust. The acid test will be this weekend. We will take one KT with the system to Battery Museum for Tank Day and let the children have at it. If they can't hurt it driving through all kinds of terrain no one can. Fortunately the driving area is far enough from the cliffs they can't drive it in to the sea.
