Question on Tamiya Speaker Boxes >
Old 10-28-2015 | 04:57 AM
Default Question on Tamiya Speaker Boxes
Hi Guys,
Quick Question -
Is there a problem if I mount the Tamiya speaker without its huge box? I would think there may be some sound loss, but is there anything else that I should be worried about?
As usual thanks for your comments..
Larry
Old 10-28-2015 | 06:10 AM
YHR's Avatar
YHR
The Box is everything.
Old 10-28-2015 | 06:23 AM
Tanker 10's Avatar
I've thought of doing the same thing, it would sure open up some room.
Old 10-28-2015 | 06:28 AM
You can cut down the box and enclose it again with some styrene. But you need an enclosure for best sound performance.
Old 11-01-2015 | 09:37 PM
Shark27's Avatar
Larry,
I built my own speaker boxes to make room for a smoker in my Tiger 1 build.
Here was the result Tiger in action smoking.
While the amount of smoke was a bit over the top, I can control it remotely and activate it after the tank has been knocked out to represent damage.
Steve
Old 11-02-2015 | 07:09 AM
Panther F's Avatar
Mounting them without an enclosure is fine and you can actually test it out FIRST to hear the "bottom end" loss that will occur too before installing it. The tank itself will add some of that for you but won't be sealed so don't expect the same sound.
HTH
Jeff
Old 11-02-2015 | 11:59 AM
Hi Steve,
very interesting - I was thinking of doing something similar.
Thanks for the tips...
Originally Posted by Shark27
Larry,
Steve
Old 11-02-2015 | 12:00 PM
Thanks Jeff...
HTH
Jeff
