Tamiya 1/16 Centurion photo build log.
#52
To answer a few PMs.
This is the rear “electronics bay” and the arrangement I used. Without the battery taking up space in the bay there is a lot of extra room. In retrospect I would have placed the DMD11 closer to the center of the bay. I failed to consider the extra turret length when the rear turret basket was added. The added length covers the DMD11 and the turret needs to be turned to fully access it. Not really an issues once the DMD option selections are made. The “on/off” button I placed hidden at the rear of the tank and accessible without the need to remove the engine/electronics bay cover.
The battery is a 4200 mah NiMH (enough for a fun day if IR battling or two fun runs) and is safe to stays and be charged in the tank. If you are planning on running a Li-Poly battery it might be best (safer) to use the Tamiya electronics bay layout so you can remove it for charging and storage.
#56
#60
#61
#63
Here in the US it’s a 240G(golf). Interesting how there are so many “names” for what essentially is the same MG.
The longer it sits on top of the Centurion the more I am liking it vs the 1919. The 1919 just dates the theme “time frame” a little better.
#64
Tamiya 1/16 Centurion build progress photo.
Note: The Centurion has NO weathering yet and still needs the second antenna mounted. Also once again, the stock rear lower hull accessories have been deleted/changed to allow for my hard driving style and future modifications.
Tamiya 1/16 Centurion in mid 60s - early 70s IDF theme.
Panther F (01-28-2022)
#65
Yes, it has been in use since 1958 & adopted & produced by many countries. The UK was an early adopter & produced many variants - the L7A1, L7A2, the L8A1 & L8A2 for tank use, L19A1 heavy barrel, L20A1, L20A2 for pod mounts on helo's & light aircraft, L37A1 & L37A2 for tanks again, L43A1 RMG for CVR(T), L44A1 for RN helo's, L45A1 drill version, L46A1 skeletonised training version - neither of these last 2 can be fired.
The US was very slow to get the message to adopt it, putting up with that M60 pig for too many years & then when they finally adopted it, weighed it down with those silly heat shields. Once you've burnt your hand on the barrel, or seen someone else do it, you know to stay well clear.
Mal
Mal
#66
The kit supplied tow ropes - are they string? They don't hang quite right, wire rope describes wide curves, not the abrupt changes of direction shown above.
Also you should avoid putting the tow ropes on the exhausts, because they got too hot to touch/use in the event recovery was required, That includes not using the bracket mounted on the exhaust jacket.
Mal
Mal
#67
Mal
Mal
#68
Mal
Mal
In some area of this build I have to unfortunately compromise for the tank to be used and not damaged easily in the IR battling I partake in. The terrain can range from brush covered fields, open field, sandy desert, to city scapes.
#69
Nice build. Thanks for doing this. Is the tank light? It appears to me to be sitting higher then a Cent would, or it could be the camera angle.
cheers
Dave
cheers
Dave
#70
The tank weights in at ~10lbs (5kg). In the last photo it looks higher because it is resting on a foam block to keep the tracks elevated off the work bench. This is so I can run the electronics without worrying about accidentally driving the tank off the bench. Hard lesson to learn...LoL
#71
#72
Tamiya 1/16 Centurion tank progress photo.
Weathering is mostly done. Keeping it lightly dirty as it will gain more and more natural weathering as I use it outdoors.
First test run video on dirt is also up on my Instagram @ fsttanks so feel free to take a look.
Weathering mostly done and only a few items left to secure in their final places.
Tamiya Centurion tank on trials course.
#74
I added one more feature (not Tamiya) before I closed up the turret cargo bin with their lids. I went ahead and installed magnets to the underside of the lids for future “accessory” mounting on top of the bin that can be removable and changed out easily during the tanks life.
