RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Tamiya Pershing in progress... (https://www.rcuniverse.com/forum/rc-tanks-369/9504087-tamiya-pershing-progress.html)
yellowshaker 02-27-2010 04:00 PM
RE: Tamiya Pershing in progress...
Ohhh, yep I knew about that..thought you saw something in my posts and werre replying to me...sorry. Sev, one question. My Pershing does not shut down form the TX. If I turn off tx, the main gun fires lol. I have to shut the tank switch off to shut her down.
sevoblast 02-27-2010 04:46 PM
Go thru the initialization process, top of page 22. Should fix you right up.
TankCarl 02-28-2010 04:53 PM
Okay, I was able to run all functions without a receiver battery. I am seriously thinking of removing the metal tray the electronics sit on,as my receiver is pressed tight up against the hull top.
But, at least i have room to fiddle around.
Next up is painting the inside surfaces of the track bloks Flat Black,to simulate the rubber inner surface. Also, the end connectors and the center guides will get a basic coat of rust.
yellowshaker 02-28-2010 05:00 PM
Good deal Carl! Post some pictures of the beast when it's done!!
Panther F 02-28-2010 05:02 PM
On my Pershing build I did not use that 'metal tray', and I cut the speaker box down so the battery could slide back giving some room for the wiring and connectors. All Tamiya connectors were eliminated, splicing the DMD/MFU leads to one battery connection ... using a single Deans connector. And, on all my Tamiya tank builds I hard wire the motors in, so there's less connectors in the way.
Soldering is so much more fun! :D
- Jeff
Chow_Hound 02-28-2010 05:37 PM
Really great work. Well done!
edoubleaz 02-28-2010 06:15 PM
"I too want the Sherman. Is there any way to make the recoil correct on it?"
Yes, but it is a bit involved.
http://web.mac.com/ethandunsford/DAK...Turret.html#37
TankCarl 02-28-2010 10:09 PM
Jeff,that crossed my mind. That soldering would cut down the excess wire in that area, My futuba receiver is a bit larger than they may have planned for this vehicle,so I see removing that tray as a quick fix,which is replaceable,if I need it.
More pictures when I get everything painted and weathered.
it is fun to have this as a runner, but for the Chicopee MA show, I will have it as a model for judging...
yellowshaker 03-01-2010 09:03 PM
1 Attachment(s)
I wanted to continue to post pics of the progress here. I just recieved the Kenny Kong T-81 tracks for Fireball today. I test fitted them and gave her a run...everything worked out fine. I then pulled one side off to begin painting them and though it might be cool to see one side painted and the other unpainted...so here are the pics...As usual, they are not the best...but you get the idea...
TankCarl 03-01-2010 09:15 PM
Nice track. What are they made from? Are they pre linked?
yellowshaker 03-01-2010 10:14 PM
They are Kenny Kong's metal T-81's. They actually came pre-assembled and I bought some extras just in case. He gave me more than enough though. I had to take 5 links out of each set to install them correctly. Very good quality, IMO. I only have experience with the HL metal tracks and these are by far, superior in every way!
CHIEFSONN 03-01-2010 11:39 PM
Super job on the Pershing, man you took this tank to the next level ,looks great Joe keep up the good work.
Wayne
yellowshaker 03-02-2010 01:23 AM
1 Attachment(s)
Thanks so much sir! The only issue with these tracks is the clearance for the skirts...I am going to have to see how much I an grind before I go through lol.
TankCarl 03-02-2010 07:39 PM
By addin a spacer strip inside the sand sheilds, you may gain additional spacing. However,the attaching screws may be too short. You could glue a piece of styrene over the original hull mounts,and tap into that as a "new" mounting point.
yellowshaker 03-02-2010 11:18 PM
I was thinking about that too Carl but the concern is then losing the correct lines at the front and rear mating surface...I am going to test a few things and see what looks best. Thanks for the idea though...
For now I am working on the hangers for the extra track links
yellowshaker 03-03-2010 12:48 AM
1 Attachment(s)
Well, this is as far as I got tonight...Here is what I am trying to accomplish and my progress...
Rebellion13 03-03-2010 12:51 AM
Very nice, now go get some sleep. Tomorrow is a brand new day:D
yellowshaker 03-03-2010 01:05 AM
LOL, yea, I hate leaving things unfinished brother. Work is going to be a bear tomorrow.:D
BiggTony 03-03-2010 01:52 AM
Oh man, that is looking so awesome! Great work so far.
yellowshaker 03-03-2010 01:54 AM
1 Attachment(s)
Ok, this is it for tonight....tomorrow I will make the mount for the vertical track.
Rebellion13 03-03-2010 02:21 AM
I thought I told you to go to bed, what are you still doing up? Wait what am I still doing up, ugh work tomorrow
Cheers,
Wade
sevoblast 03-03-2010 02:40 AM
Methinks we've created a monster here! Such work from someone who just a very few months ago was a newbie....track racks are very well done! Nice work, Joseph! I am impressed.
I'll have the Kenny Kong tracks in stock shortly on the etoarmour sight, they are in transit as we speak. Can't wait for that little deal to come to fruition.
yellowshaker 03-03-2010 02:45 AM
Next ones I buy from you Sev. Thanks for the kind words. Your JT is an inspiration to better myself brother. As you've told me, if someone doesn't make the parts, we have to make them ourselves. The pins would be correct to hold them in place?
And Rebellion....I'm sorry lolol. I'm going to bed...
yellowshaker 03-03-2010 01:32 PM
1 Attachment(s)
Ok, I was hard at work today...well, on making the brackets at least. lol. Here is the last one...now to paint them up adn do the welds...
edoubleaz 03-03-2010 01:53 PM
Now you've done it! I'm gonna have to redo my Pershing!
