Official Hyper ST thread!!
Ok everyone here is a thread to post all your pics, questions, tips, links, discussions etc etc. On the Hyper ST.
RE: Official Hyper ST thread!!
ORIGINAL: Ev1er
Ok^
Is the hyper st rtr better than the hyper 8 rtr?
Ok^
ORIGINAL: sirvancealott
The engine on mine has given me lots of trouble. Hard to tune and impossible to keep under 300 degrees. I'm switching motors.
CA
ORIGINAL: nitro _ burner
Engines in RTR's are never the best but it shouldnt be giving you that much trouble, most people change thier RTR engines for more powerfull race tuned engines. Just make shure your running all the needles (LSN, HSN, and mid-range needle) in the factory settings then try again from there. remember not to adjust the Midrange needle. and adjust the LSN once you have tuned the HSN.
ya i'm in the same boat you are. The Mac star .28 is junk. Doesn't run worth a hell under 300 degrees and the temperature of the engine is so unconsistent. Looking at Nova Rossi and wondering why nobody runs o.s. max. Looking in the back of some of my magazines and in the truggy and buggy class o.s. is number one in most race results, just wondering why i don't hear about them on here?
CA
ORIGINAL: Joe RC
Hmm this is the first that ive heard of the mac-star running realy hot, anyway it might of been your LSN set too rich......
Just curious "Sirvanceallot", is there somewhere on the internet you found the reviews for the hyper st? Just wondering because i have never read any reviews about it anywhere.
CA
CA
ORIGINAL: Joe RC
Any needle being too rich is not going to cause overheating. I think you mean too lean. By the way, sirvancealot, you had an air leak in your mac-star or fuel system, I guarantee it. It's just about the only possible cause for the symptoms you describe.
CA
ORIGINAL: foxy42
Thanks for your feed back. I didn'tunderstand how a rich low speed needle could cause oveheaing either, but that is what nitro burner said. Perhaps he meant lean. How can I determine if the leaky fuels system or engine is the cluprit and how can I determine where the weak link is? I definately don't want to burn another motor out! I blew air into my fuel line to check for leaks and I noticed that some air was escaping from the fuel tank lid, but whenI pressed the lid down hard, it would stop. Could this be the problem? Also, the high speed needle seat seamed to be leaking a small amount of fuel onto the carb body, so I put teflon ove the needle threads, but by that time the motor had already gone bad. Do you think these issues could cause the motor to burn out? Any recommended fixes?
ORIGINAL: foxy42
Have you run the new engine yet? Anything to report, or does it seem to be fine?
CA
ORIGINAL: foxy42
Leaky fuel tank lids are common and can cause an overlean condition due to the pressure from the line that leads from the exhaust to the fuel tank escaping through the leak, which results in a loss of the back pressure required for correct fuel delivery. I suggest you look into a fix or replacement for this, or you may indeed see your next motor going the way of the mac-star. Any leak from the carb needle seating would also be a worry, but not any more since you replaced the engine (and I'm assuming, the carb along with it). Fixes? Replace or repair the fuel tank if possible and check for other air leaks.
ORIGINAL: foxy42
Hey "Sirvancveallot", i blew in one of my fuel lines also and air came out of the top of the fuel tank like yours. Just try pushing down on the lid after each time you refuel. After i pushed down on the lid i blew in the line again and nothing came out. Just an idea that may work and be a little cheaper.
CA
ORIGINAL: Joe RC
Cool. ya keep me informed on how your new picco runs. I'm looking at getting either the nova rossi N528XR or the picco .28 P3. I'm gonna be racing mine so i'm gonna need a motor with a little more oomph. What kind of fuel do you run. I'm running o'donnell 20% right now in my mac star. Might be another one of my problems, i've heard o'donnell is the hardest fuel to tune with but once you get it dialed in it will have the most power. This is just what i heard not really sure. Also o'donnell doesn't have any castor oil in it which i don't like. I've heard good things about nitrotane so i think i'm gonna go buy a gallon and give it a try. Just curious to see what you run.
CA
ORIGINAL: Joe RC
CA
I'm sure he just got it mixed up, there's no way a rich needle can cause overheating, unless the overheating is caused by another needle being too lean, such as the high speed. But I can absolutely assure you that a rich needle on it's own cannot be directly responsible for excessive heating of an engine.
CA
ORIGINAL: foxy42
Think out-side the box people, if the LSN is too rich then you will lean out the HSN to compensate for it. and because the tuning is out of whack you will never get the needles set perfectly so its either going to run too lean or too rich.
This may be an "out there" theory, but you never know............
I hope you havent purchased a new engine for your hyper st yet. The problem isnt the engine, its the fuel tank. I know this sounds crazy but if you reverse the fuel tank in the chassis it will run great once the engine is tuned.
