RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Help decide
Old 10-20-2008 | 09:52 PM
Default RE: Help decide
what engine/pipe and electronics are you selling the st1 with?
Old 10-21-2008 | 05:14 AM
DS's Avatar
DS
just stock pipe nd electronics
Old 10-22-2008 | 07:14 PM
IL2mSturmovik's Avatar
modhobby has 8ights for $389!!!
Old 10-22-2008 | 07:34 PM
Eganwp's Avatar
You sure you want to go to all this work and $$ man? Not that I believe the ST-1 is the fastest truggy out there, but it does very well and for me it's all in the durability. You can't bash a RC8T or an 8ight-T worry free, because it can get pricey quickly, and really loosen Up your "expensive tightly tuned" race truggy. For me, I spend much more of my time just having fun with RC (ie. Bashing with buddies, or just ripping up some jumps, hill climbing, etc). The ST-1 is probably the most durable truggy you'll ever own. I know several people that break things so fast on their 8ight-T's in a hard bashing session. Worse yet is probably the all around slop you'll cause to it with bashing.
If I were you I'd rather just keep the ST-1 for bashing sessions (and honing your race skills) and save up until next year for the RC8T. If you really aren't driving the ST-1 then, sell the whole bundle in exchange for an RC8T. Or keep it as a parts truck for your RC8T as several parts on the RC8T are directly taken from the ST-1 (ie. all 3 diffs, shims, bearings, etc). The other thing is, the ST-1 isn't THAT slow. Like has been mentioned so many times before, it's generally max a second or so slower per lap. And that's if your driving skills are 100% and the only thing holding you back from 3rd to 1st for example, is your truck. I've read a couple threads on here where guys have owned the 8ight-T, RC8T and ST-1 and overall liked the ST-1 better. Easier to drive and more durable were the main points. I just wouldn't want you to drop $1200 on a new RC8T and realize it didn't really get you any further along in the race scene at this level.
Anyways, do what you like but that's just my $.02
Eganwp
Old 10-23-2008 | 08:44 AM
INTEGRA's Avatar
slop is your friend in 1/8 offroad....this aint 1/10 Carpet you know. [sm=lol.gif]
Old 10-23-2008 | 09:26 AM
  #31
The Hedgehog's Avatar
If that's the case the ST-1 should be king of offroad racing
Old 10-23-2008 | 11:47 AM
  #32
vnmsgt's Avatar
wrong post[&:]
Old 10-23-2008 | 11:51 AM
  #33
For the record, I also had Hyper ST brake probs. BUT it was in the setup, and I was too lazy to fix it. I ran with and against numerous Hypers, and they all had spot-on brakes - spot-on stock brakes... I even asked a bunch of guys at a few races if they had brake-issues, and they were like "what are you talking about??"..
Basically my linkages were a mess, so it just didn't work right. Do your linkages right and the brake thing isn't an issue. OK one guy(with great brakes.. ) did say he'd sprayed his with brake cleaner and it took a liter or two for them to "break in".. - but his Hyper was dialled. And all stock..
Old 10-23-2008 | 12:45 PM
  #34
i disagree with Eganwp. Sell the ST1 and put it on ebay.
Old 10-23-2008 | 01:00 PM
  #35
vnmsgt's Avatar
ORIGINAL: HerrSavage
Must have been a bad batch of breaks then. 2 others locally had hypers with the same issue as me. We all sold them. Was a shame too because we all really liked the hypers but could not get them to stop right. I could see the Hyper ST having problems because it has different linkages but the PRO had easy adjustments to do the brakes and still could not get it right. They would be awesome for about 2 minutes and then fade to nothing. I would let the car sit after running the tank and then they would work again and fade to nothing. Just got annoying.[:@][:@]
Old 10-23-2008 | 03:11 PM
  #36
DS's Avatar
DS
http://www.amainhobbies.com/product_...oducts_id/7459
is this a good engine for a truggy for racing? Also what pipe would i need with it?
Old 10-23-2008 | 03:34 PM
  #37
If you're really on a budget, get a Mach 427.. They're on e-bay all the time.. You then need part # SWK8057(type it in on amain or ebay..) to make it start-box-able... Forget the 28..
Old 10-23-2008 | 04:04 PM
  #38
INTEGRA's Avatar
x2....u can snag a 427 on ebay for ushally less then 100$
Old 10-23-2008 | 04:59 PM
  #39
DS's Avatar
DS
what about this
http://www.axialracing.com/main_details.php?Id=3128
Old 10-23-2008 | 05:06 PM
  #40
If you want to be the slowest truck on the track sure it will work Get a mach 427 or Sportweks .26 amain has them for like $120
Old 10-23-2008 | 05:51 PM
  #41
DS's Avatar
DS
thats the engine imgoing with the v2
Old 10-23-2008 | 05:53 PM
  #42
DS's Avatar
DS
how does the kyosho st-r kit compare to caster kti and gs new advanced truggy kit?
Old 10-23-2008 | 10:59 PM
  #43
how about save some more and get the D8T when it comes out!
Old 10-24-2008 | 06:54 AM
  #44
DS's Avatar
DS
Is the scanner rc servos from rcmart any good? And what does bb mean, is that good with a servo?
http://www.rcmart.com/catalog/rc-ser...Path=1099_1029
http://www.rcuniverse.com/market/item.cfm?itemId=445883
Old 10-24-2008 | 07:15 AM
  #45
Ok, it's obvious you are on a tight budget, too tight to build yourself a proper kit with proper components.
Your best bet is buying used RTR packages that racers are selling from this season, otherwise you are going to be left with sub-par equipment and probably nothing better than your ST-1 at the end of the day.
Old 10-24-2008 | 09:26 AM
  #46
INTEGRA's Avatar
RC isnt Cheep.....PERIOD
Old 10-24-2008 | 10:15 AM
  #47
vnmsgt's Avatar
ORIGINAL: st1_racer
BB mean ball bearing.
Old 10-24-2008 | 02:03 PM
  #48
DS's Avatar
DS
thought so
Old 10-24-2008 | 02:33 PM
  #49
DS's Avatar
DS
http://www.amainhobbies.com/product_...ducts_id/18223
how much torque does this have, running y harness
Old 10-24-2008 | 02:38 PM
  #50
qaiz's Avatar
That servo is too weak for anything in a Truggy....
IMHO, servos is not a place where you should skimp out..
Save up, and get good equipment from the start. Its cheaper to buy a $75 servo that lasts 6 months instead of buying a $25 servo every month.
You need atleast 150oz/in for throttle, and atleast 200oz/in for steering IMO..
ORIGINAL: st1_racer
