CARF F4U-1 Corsair build thread
#2401
Got the go ahead from the owner of this Corsair on the cowl sectioning, so I will be cutting it apart and making that mod. First time for this one. Always makes me nervouis.
The cowl will be in two halves for easy removal without pulling the prop. This is made easy because the cowl flaps are not part of the cowl. I'll be adding an extra mounting bolt and changing the location of all of them. Two for each half.
This will make Moki maintenance very easy.
This is where I will be cutting it apart. The picture is of the top, and the bottom is the same. Scale size screws will be used in the CARF locations to screw it together. I'll also add a guide pin top and bottom, drilled into the Steel Powder in the nose of the cowl.
Have you had any issues with the split cowl, as we discussed some months ago ?
Thinking of vibrations working screws loose and lack of rigidity.
Mine is marked out ready for cutting (if I dare) !
Steve D
#2402
My Feedback: (221)
Here is the thing though, you want to glue the guide pin tubes in the cowl BEFORE you cut it apart. This insures that the two halves will be in perfect alignment. I will be going back to this part of the build soon and I'll add some more pictures of the finished cowl and how it all works.
My reason was two fold for this mod. First, not having to pull the prop to service, adjust and test run the Moki, and second, in static, to display both the completed look from one side and that big beautiful radial from the other.
#2404
My Feedback: (221)
Yep. :-)
I'm confident in the design. I gave this a lot of thought.
I understand the concerns and well know how we have worked at keeping our cowls tight over the years. I've addressed this in the way it is all held together. Plus, it has (4) mounting bolts in the cowl flap ring, two each side, and a seat in the back to hold it in place and virtually eliminate movement from vibration.
I think I will do another series of posts on the process of installing the flaps and cowl, including this mod. I have had several PMs lately on the subject.
This aircraft continues to find new builders and owners. My brother and I will continue to work on mods and improvements as long as the interest is there. So far, it is.
#2405
My Feedback: (221)
wing pictures
here are some progress pictures of the wing systems.
Sorry. new computer and it looks like I clicked something i didn't need to.
You can see the electric gear control box (top left), the gun system control box (top right), the control valve for the air gear doors (left), and the ''equalizers" for the ailerons and flaps (center).
This is all in the opening on the top of the wing.
The battery for the gear will mount to the spar, seen at the top of the picture.
The spot to the right of the equalizers would be the control box for the wing, however, this plane has the 'plug in wings'.
#2424
Nice tail door system.
Did you find that the system you used previously (with the ball links/rigid connections to the tail gear) didn't work too well, as I fancied giving that a go). - See post 682 for those who haven't seen the earlier version
Your new method looks a little more complex to install/set up - plus it looks like you have no chance of adjustment once the pull-pull wires are crimped ??
Keep posting !!
Regards
Steve D
#2425
My Feedback: (221)
Hi Gary,
Keep posting !!
Regards
Steve D
Keep posting !!
Regards
Steve D
As for the cables, I had planned to use a small spring in the system so I could put some tension on the cable to insure it stays tight, but I deemed this unnecessary. I have a couple more videos to post but am having a little trouble with them. I have uploaded one 3 times and it keeps rejecting it.
More on this subject to come.
