Reload this Page >
Hangar 9 60cc Corsair
Old 04-18-2014, 04:44 AM
  #826
acdii
What ever happened to even scales? .76, Yikes!
Here is why I was asking. This particular plane will fly on the 7-77 radial, so in "theory", a B-25 or P-61 of the same scale "should" be able to fly on a pair of then, but that doesn't always work out. A 1/8th scale B-25 comes out around 40#, so a 1/5th could be closer to 60#. A 1/7th scale P-61 needs 40-50CC gas to fly well. I would have loved to put a pair of 7-35 radials on it, but not enough power. In the full scale planes, the Corsair, B-25 and P-61 used practically the same 18 cylinder engines. They weren't identical, B-25 used the R-2600, the Corsair and P-61 the R-2800. So in scale, the same engine should be able to fly all three, but that doesnt really work out does it.
From the way it looks now, the plane is scaled to fit the engine, and not the other way around. Make an engine that can pull a plane of this weight, then design the planes scale around the engine. Is that what others are seeing?
Old 04-18-2014, 03:10 PM
  #827
BobH
I'm pretty sure two 777 radials will fly a 50 pound plane with out great difficulty. It's a bomber not a fighter for starters. So speed isn't important. If you use the calculus of 1 hp per 10 pounds you end up needing 5 hp of thrust.
I have see the 777 fly a FW 190 that was 30 plus pound. It was decent performance. Could it have been better? For a fighter maybe yes. But it was pretty scale looking.
Old 04-18-2014, 06:24 PM
  #828
acdii
The 777 wont fit the 1/8th scale B-25, nor the 1/7th scale. If they would fit 1/7th I would consider them for the P-61. The diameter of the 777 is 9.1, the cowl on the 1/7th B-25 is 8 -9 ", so it wont fit. It would have to be 1/5th scale to fit properly, and at that size, It is more than likely nearing the 100 pound range.
Old 04-20-2014, 04:25 AM
  #829
frisconick
I finally got the second flight in on my Corsair. The repaired/replaced electric gear worked great. Flies heavy. Keep some speed up on landings. All was good. I like a little more aileron throw than the low rates recommend. Thinking back, I think I flew the first flight with everything on high and didn't think it was too much.
Old 04-20-2014, 08:17 AM
  #830
Fly2XS
My Feedback: (65)
Fly2XS's Avatar
Great to hear Nick!
Any pictures to share?
Old 04-20-2014, 12:53 PM
  #831
captainron
captainron's Avatar
Hey Nick, congrats on the 2nd flight. You and I have been on a couple of builds together. Didn't you build the Hanger 9 Ferocious Frankie with me years ago? Anyway, I pulled the trigger on one of these F4U's from my local Hobby store. He's saying late June. I'm not going to have the luxury of a fancy radial engine. But I am considering my old tried and true ZDZ 80. Should do the job. I'm also staying with Robart pneumatic retracts. I have used the electric from Robart and I'm using them right now on a Top Flite FW 190, and they work great. The only place I've ever seen guys having problems with the electric is on the Corsairs for some odd reason. Anyway, you guys are all awesome, I've pretty much read the whole thread........Lot's of good info here.
CAPTAIN RON
Old 04-20-2014, 03:27 PM
  #832
frisconick
Yes. I went through three H9 "Frankies": one mid-air, one mysterious roll-over into the ground, and sold the third. I now have a TF GS P-51 that I glassed and painted in the same FF scheme. It flies great. I had it at WBOR two years ago. I just hope these electrics keep working !!!
Old 05-01-2014, 02:24 AM
  #833
jamessymons
Hi Everyone
I Installed the first main retract in the wing centre section. Operated just fine. Put the wheel on, retracted the wheel. Heard a small crunching noise, now the retract does not cycle. I can hear the electric motor running in the retract but the worm drive is not turning. Have any of you guys experienced the same problem ?
Very dissapointed as i live in South Africa so returning the retract to Robart is a hassle for me. Also, now my faith in the retracts have been dented and in the back of my mind I am worrying that the other retract will suffer from the same affliction.
James
Old 05-01-2014, 04:34 AM
  #834
David Eichstedt
My Feedback: (17)
The Corsair had an uncommonly long gestation period. We sized it before we knew about the 7-77, which we acquired through partnership. The cowl diameter was driven by the large 3-cylinder Saito glow engine that preceded the FG-84.
Old 05-01-2014, 05:25 AM
  #835
njmheli
Hi James.
Sorry to hear about your retracts...........yesw,this has happened to a "few" of us now !!!
Please see my post # 698 on page 28..............hope this will help..?
Kind regards......Nick (UK)
Old 05-03-2014, 03:26 AM
  #836
Fly2XS
My Feedback: (65)
Fly2XS's Avatar
Great feedback! Thank you David!
Will the tail hook option be available through HH sometime?
it looks like the tail wheel could simply be modified by replacing the rear hing pin with a longer pin to accommodate a hook. A small servo could be added to raise and lower it.
Old 05-03-2014, 07:59 AM
  #837
MANFRED
My Feedback: (27)
Anybody use a DA-60 on the ship? If so, what size standoff did you use? I'm going to pick up a blazing star unit if I can find the dimensions needed from firewall box to cowling front.
Old 05-04-2014, 07:15 AM
  #838
Cristian2fast4you
Cristian2fast4you's Avatar
Finally, the maiden happened yesterday. All went well, except for the second flight when the motor stopped and had to do a dead stick landing. It felt like a carrier landing. No major issues.
And a video of the maiden...
http://youtu.be/n4iXbgbv6Lw
Old 05-04-2014, 11:42 AM
  #839
SWORDSN
My Feedback: (13)
Christian,What engine are you using?SOUNDS GREAT!
Old 05-04-2014, 02:19 PM
  #840
kalzone
hi everyone i have had the first tow flight on my corsair today it is a wonderful flying beauity. i am running the eflight power 360 with 4 6s 5000 lipos. the only problem is that on the second landing the left main folded up and broke the electric acuator. has anyone had a problem with these already ?
kallin
Old 05-04-2014, 07:47 PM
  #841
Cristian2fast4you
It's the Evo 7-77 with a Keleo exhaust ring.
@kalzone
No problem with the retract. If it folded up it means it was not fully down and locked
Old 05-05-2014, 11:01 AM
  #842
glazier808
glazier808's Avatar
kallin
First off... welcome to RCU!
I would love to see some pics or video of your set up. I'm big fan of the Eflite systems. It's nice to see that they have finally stepped up to larger sizes (with the 360). Could you share the details on your setup as well, what ESC and batteries are you running? Flight times?
Thanks a bunch!
Casey
Old 05-05-2014, 07:02 PM
  #843
kalzone
Thanks a bunch!
Casey
casey
thanks for the welcome. my setup is the eflight power 360 ESC is the castle 160 amp this is the one they recommed with it and im running 4 6s 5000 lipos. prop is a 24x14 menz 2 blade
flight time so far is 6 mintues but only using 2700 out of 5000 from the lipos. had a gear problem on the second landing and parts on the way when i fly again ill take a video and post it here.
Old 05-10-2014, 01:31 PM
  #844
kalzone
https://www.youtube.com/watch?v=j3tR3sofeqM
this is the 3 takeoff. i have six flight on it now.
Old 05-11-2014, 12:08 AM
  #845
Cristian2fast4you
Landing approach....
Old 05-11-2014, 07:29 PM
  #846
kalzone
all the decals on ready for joe nall !
Old 05-12-2014, 03:46 AM
  #847
kalzone
https://www.youtube.com/watch?v=q3-X3Bw2SI4
this is a video of a short flight with the corsair
Old 05-12-2014, 10:53 AM
  #848
glazier808
glazier808's Avatar
Nice! Tell your girl, she did fine! She got the good stuff. Nice speed on those passes! Looks like a great combo!
Casey
Old 05-12-2014, 10:54 AM
  #849
glazier808
glazier808's Avatar
Are you running 4 batteries?
Old 05-12-2014, 07:24 PM
  #850
kalzone
yes 4 eflight 6s 5000mah lipos. the speed is 90mph straight and level wide open and 140mph in a wide open dive. this is acording the the gps sensor with my onboard telemetry. prop is a 24x14 menz 2blade
