Reload this Page >
Hangar 9 60cc Corsair
Old 06-29-2014, 07:50 PM
  #876
DOC
My Feedback: (57)
The DLE55 RA fits very well. You must make a small cut out in the bottom of the engine mounting box to accommodate the muffler, and a small cutout in the Cowl to allow the top of the spark plug cover to exit. the Engine will extend about 3/8" beyond the cowl, using the stock standoffs. The dummy scale engine should be mounted on a piece of 1/8" ply and it fits nicely well into the cowl .
Old 07-01-2014, 05:42 PM
  #877
glazier808
glazier808's Avatar
Count me in on this one...,one on pre-order. I'll be going with the RimFire 65cc equivalent electric motor on mine...
Casey
Old 07-01-2014, 06:01 PM
  #878
djohnson
Fireynz
The corsairs are scheduled to be in the USA warehouses
on July 29 but as you know that is what is scheduled as of now .
Good luck with your project as I really like mine and the best
flying scale model I have flown or owned.
Dan
Old 07-02-2014, 04:51 PM
  #879
ashworthb
Has anyone flown the H9 60cc Corsair with an Evolution 7-77 radial using a Biela 4 blade 18x14 prop?
Old 07-03-2014, 01:59 PM
  #880
glazier808
glazier808's Avatar
...I really hate waiting
i WANT MINE NOW!
Lol
Casey
Old 07-03-2014, 02:10 PM
  #881
glazier808
glazier808's Avatar
I've got to give kudos to Horizon hobby. I first called their shipping department and ask for shipping quote to Hawaii. They emailed me a quote of $78.83....when I called again to confirm(as this seems unimaginably low), I was told "send me the email". Once he saw that, he went with $78.83 on the spot for shipping....needless to say, I immediately went ahead with the order!
That's true customer service!
Casey
Old 07-03-2014, 06:58 PM
  #882
glazier808
glazier808's Avatar
Also as far as the gear goes, is there any advantage in going with the air set up over the electric? I'm getting ready to start at page one now, so I'll hold anymore questions.
Casey
Old 07-03-2014, 07:45 PM
  #883
SkyPilot101
As far as air vs electric, one thing stands out....air works!
Old 07-04-2014, 04:49 AM
  #884
SWORDSN
My Feedback: (13)
I agree,but nothing is perfect.I have seen a lot of problems with electrics at our field and they had to return them for repair.With air you usually can repair them yourself,,just find the leak.That's my experience.
Old 07-04-2014, 10:32 AM
  #885
glazier808
glazier808's Avatar
So has anyone had good luck using the electric retracts? I usually have pretty good luck with running air myself. Does Sierra make a set for this bird?
Casey
Old 07-04-2014, 10:45 AM
  #886
BarracudaHockey
BarracudaHockey's Avatar
I have the E-Flite electrics on the Spitfire and they have been fine and while I haven't flown them yet, the 60cc Mustang retracts appear very stout and have bench tested very well.
Old 07-04-2014, 12:49 PM
  #887
acdii
I have Eflites on my P-51, flew it today for the first time and they worked fine during the two flights. I have Centruy Jet on my 60 Corsair, and during the build they have been working without a hitch, but time will tell once it starts flying how well they hold up.
Old 07-04-2014, 01:57 PM
  #888
DOC
My Feedback: (57)
I have the electric Robarts, Mains and tail wheel they seem to work well, But slow. They take 15seconds to actuate (ON 9 volts).. I plan on using 4 servos on the doors. No problem on going down, but how can I slow the doors down to allow the Retracts to get up before the doors close?
I have a Spektrum 18.
Old 07-04-2014, 03:22 PM
  #889
acdii
I have a sequencer for doors that might work for this, got it from Tower. Not sure if the DX18 has that feature, heard it could do something like this, but thats as much as I know about it. My JR 12X can slow the flaps speed, maybe the DX18 can do that for the gear doors.
Old 07-04-2014, 09:01 PM
  #890
AZThud
Doc I have a DX 18 and with that you can adjust the speed of the doors, independently, I used the expansion module for the gear and doors. Go into the servo setup and select the expansion channels and then Speed. The 18 also has a sequencer built in. That is where I suggest you start. Assign the Gear to WHL and DOR for the doors. It took me some time to get them working the way I wanted but its not too tricky.
Good Luck.
Cheers
Old 07-05-2014, 11:11 AM
  #891
Heat1960
Did the maiden this morning and awesome flying warbird. Very pleased. Zenoah ZP62 for power and almost 4 lbs in the nose to balance. Takes off very scale. I have the Robart air retracts and no issues so far.
Cal.
Old 07-05-2014, 11:19 AM
  #892
Capt G
My Feedback: (8)
Capt G's Avatar
I have Robart E retracts in the GS P-40, GS Corsair, GS Spitfire and a GS P-51. All work great on 6 volt NIMH rcvr pack.
Old 07-05-2014, 03:46 PM
  #893
DOC
My Feedback: (57)
Thanks Thud, I just got off the Spektrum site. and they go thru the entire set up. You can use the same switch but must use 2 channels. Wheels and Doors( gear and aux ? ) I gave it a try but it is still in progress, needs work. As you know they don't have master-slave . It isn't easy but it will work.....
Old 07-06-2014, 09:21 PM
  #894
rslstft
My Feedback: (10)
rslstft's Avatar
Doc,
With the Corsair I put together, I used the sequencer built into the DX18. You can adjust the speed of the doors opening and closing and the time between the gear moving and the doors opening or closing. I did use 4 servos for each main gear door, all on the X+ module, but everything works perfectly. Oh, and I used the recommended Robart gear using air and they have been just fine and hold air for more than a week.
Old 07-10-2014, 01:56 PM
  #895
CaptRKO
CaptRKO's Avatar
The wait is killing me!
probably go with AIR retracts.....it hearing good things about electric.
Old 07-18-2014, 01:51 PM
  #896
mrplay
Yes go with the air, I had 2 sets of the electric go wrong on the bench, so glad after that I told them to send me the air, so easy, they work, yes the air stays in them for over a week on mine too
Old 07-18-2014, 06:10 PM
  #897
captainron
captainron's Avatar
I'd like to trade my ESM Corsair for one of these.
Old 07-20-2014, 12:32 AM
  #898
vasek
vasek's Avatar
Good luck with that LOL
Old 07-21-2014, 03:33 PM
  #899
kalzone
Casey
i had good luck with the electric retracts from the week before joe nall until now. the plane sat for 2 weeks then the right gear stoped working. i called serria they sell gear for this corsair $430 with sipping but you have to call its not on the website. i have not flow the new gear yet i am installing the new gear now ill post pics as i go.
Old 07-21-2014, 09:36 PM
  #900
glazier808
glazier808's Avatar
Kalzone, thanks for the reply! I love my sierras(5 sets), and I'm so glad u mentioned this as I was about to order the air setup from Horizon. I'll call Darrel tomorrow now! I to am going to power my Corsair with an electric motor as well. I will use the Rimfire 65cc equivilant, 12 cell (2-6 cell6000MaH batts) and Castle HV160 ESC. Could you possibly provide me a pic of your firewall/battery box setup? Looks slick!
I'm also toying with throwing in a sound system, as I happen to have the new high power 50 watt system from Benedini, complete with correct radial sound already programmed to it.
Here is a sample of the same sound system I have on hand flying with the same radial programming...it sounds pretty good if you ask me!
http://youtu.be/YOeivH3yAZ0
Mahalo,
Casey
