Reload this Page >
Kolm 135 install in CARF Mustang
Old 01-17-2015, 08:20 AM
  #201
DrScoles
My Feedback: (18)
DrScoles's Avatar
Craig, I thought that also. My only reasoning is the placement of the exhaust might pre-heat the air before it goes past the cylinders? But then it would make sense to have the exhaust going the other way right??? LOL
Old 01-17-2015, 12:14 PM
  #202
kimhey
Originally Posted by DrScoles
Kim, can you redo the video in fahrenheit...;-) :-) ... So you got 250 on one cylinder, is that an acceptable temp? 50 degree difference from front to back, that seems tolerable. It will probably be a few months before I get mine back together, still a lot of finish work to do. Thanks for sharing the video and your experience with it. I read that these motors were broken in at the factory can that be verified??
If it is acceptable is something I also would like to know. My Moki runs at 120-125C (250-260F), and that has worked great so far. I am pretty sure that I red somewhere that the Kolm can run as high as 145-150C (290-300F), but I canīt find it again. I would like to have that confirmed, as I think that is very high...
To my understanding, the Kolm engines are run-in at the factory. Your question got me interested in getting that confirmed as well.
Thomas, are you there ?
Old 01-17-2015, 04:07 PM
  #203
kimhey
To adjust the H and L needles easily with the cowling completely on, I installed small cf tubes, to guide the screwdriver. I also did this on my Moki/Lavochkin 7, and it simplifies the adjustment greatly.
ID:	2064753   Click image for larger version
ID:	2064758   Click image for larger version
Old 01-18-2015, 11:27 AM
  #204
Ixtrim
Ixtrim's Avatar
Hello! Back again.
Painted my BF109 the Last days. So ... No time for RCU.
First: mY Spitfire with IL 150 was Running with cool air in On Carb side. Worked as well as from the other side with One difference: no Isolation on carbs needed. An Of course the intake have to be a little bigger, becaus You need air for cooling And for carbs.
then: mY Kolm went Up to 180 degree when cooling Wasn't perfekt aT starting Testing. No problem for the engine.
150/160 degree should be No problem for alltime-Running.
50 degree difference maybe Is No problem. But it's Not good.
If You do some Trys in flight you can have 20 degrees or less. Needs time to test an some modification of your cooling.
Important: dont Handle the temp-difference with the carb needle. Both carbs should be adjusted same.
How to do i told a Few posts behind.
Old 01-18-2015, 11:28 AM
  #205
kimhey
Successful maiden today!
In flight:
Sylinder temp no1 around 110 (+/-10)
Sylinder temp no2 around 100 (+/-10)
BUT, as you will hear in the (poor) video, the engine runs too rich, so the temperatures will maybe change as I get the engine tuned in.
https://m.youtube.com/watch?v=80qCjVnV-v8
Now I can get on with the scale details and try to choose a colour scheme
ID:	2065007   Click image for larger version
Old 01-18-2015, 11:43 AM
  #206
Ixtrim
Ixtrim's Avatar
Congratulatios!!
you are Right. Your engine is Very much to Rich !!!
I know with 4stroke engines it's hard to find Out in the ground if the needles are Right adjusted.
What prop have you mounted ? So i can Tell you how much rpm
you should have on ground.
Your temp is Very good. Difference also. Will get higher of course. But No Problem.
Old 01-18-2015, 01:08 PM
  #207
kimhey
Thanks Thomas! I must dedicate some of my success to you, as your knowledge and experience has been of enormous value to me. I have not installed the rpm sensor yet, but I have it and will install it soon. I used a Biela 28x14 today, but are about to drill/mount a Fiala 30x14 now. If you have best rpm for both, it will be nice.
Kim
Old 01-18-2015, 10:43 PM
  #208
Ixtrim
Ixtrim's Avatar
No Problem! like to see your success!
biela i donīt know... i donīt like them :-)
Fiala 30/14 2 Blade 5000-5100 rpm
Fiala 28/14 3 Blade 4700 rpm ... both on ground. in flight about 1300 plus
tom
Old 01-19-2015, 07:52 AM
  #209
kimhey
tom
Happy now Tom ?
Old 01-19-2015, 09:03 AM
  #210
perttime
perttime's Avatar
Congratulations!
She seems to fly well.
For color schemes... Everybody else already has a Spitfire in camo. Maybe pick something different? Desert Pink? Red or silver target tug scheme? One of various civilian schemes?
Old 01-19-2015, 09:15 AM
  #211
Ixtrim
Ixtrim's Avatar
So much better
which scheme you have Chosen?
Old 01-19-2015, 09:29 AM
  #212
Greg Wright
Greg Wright's Avatar
Here's one for you.
Old 01-19-2015, 09:37 AM
  #213
perttime
perttime's Avatar
Originally Posted by Greg Wright
Here's one for you.
Claveworks might have a few more schemes that are of interest to us who like what-if stuff
Old 01-19-2015, 10:02 AM
  #214
Greg Wright
If i was building a spitty, I would totally do this scheme even if it's not real.
A perfect flat black finish with gold paint would be Bad ASS!!!
Old 01-19-2015, 09:03 PM
  #215
Chris Nicastro
Chris Nicastro's Avatar
+1!
Cool fantasy scheme, just paint the pilots helmet like Senna!
Or for a more scale look do the one black wing underside.
Old 01-20-2015, 04:07 AM
  #216
DrScoles
My Feedback: (18)
DrScoles's Avatar
Congrats Kim! Looking forward to hearing/seeing video with the engine tuned in.
Old 01-20-2015, 03:12 PM
  #217
kimhey
Thanks, me too
Old 01-21-2015, 06:06 AM
  #218
DrScoles
My Feedback: (18)
DrScoles's Avatar
I got some heat shield from summit racing. Says it will take 1000 degrees direct and reflect 80% of radiant heat. They have it in sleeves. blanket, and even adhesive tape. I ended up not using the blanket, I just cut the sleeve lengthwise and it was a good fit to adapt around the carbs. Of course I forgot to isolate the fuel nipples after I did it, duh.... no biggie. I used safety wire here and there to keep it together. I'll wrap the exhaust as well, but haven't cut them yet. Any suggestions on if it should be loose or tight? I'm leary of wrapping this stuff tightly around the exhaust, seems like having an air layer in between would be safer.
ID:	2065904   Click image for larger version
ID:	2065905   Click image for larger version
ID:	2065906   Click image for larger version
ID:	2065907   Click image for larger version
ID:	2065908   Click image for larger version
ID:	2065909   Click image for larger version
Old 01-21-2015, 06:22 AM
  #219
Bumble.bee78
Hi I have the CARF Spitfire which I've been flying for 3 yrs. I made it into the 3W17 scheme. Now I am ready to add cannons and guns to the wings. Can anyone point me in the right direction or where i can find them. i hope to change my 3w 85xi to the Kolm IL 150 in the near future.
ID:	2065917   Click image for larger version
ID:	2065918   Click image for larger version
ID:	2065919   Click image for larger version
Old 01-21-2015, 06:32 AM
  #220
kimhey
I wraped the insulation tight around the exhausts.
Old 01-25-2015, 10:03 PM
  #221
Ixtrim
Ixtrim's Avatar
Very good!
That will work!
Tom
Old 02-10-2015, 06:47 AM
  #222
kimhey
I flew the C-arf Spitfire/Kolm 135il some more today, and still have engine tuning issues as on the maiden flight. The engine runs rough, and I canīt get more than 4200-4300 on ground with the Fiala 30x14. The H needles are set to 1 1/2 turn out as per the manual, and I try to lean both carbs the same, but I end up either too rich, or the engine dies...
The L needles are left at 1 3/4, and the Idle is "ok" at 900rpm.
On my Moki 150, it is "easy" to adjust the carb, but I am really struggling to get my Kolm dialed in.
ANY help is appreciated!
Kim
Old 02-10-2015, 12:58 PM
  #223
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Hey Greg Wright... PM sent to you....
Old 02-10-2015, 09:36 PM
  #224
Chris Nicastro
When I tuned my own 92 Kawasaki ZX7 750 and I synced the carbs I used a flow meter to balance 4 carbs at once. I have not seen any way so far to sync the multi carb engines from any make in this hobby. Even if you had to do it one at a time it would be great to do so you know that each cylinder is doing.
Old 02-10-2015, 10:51 PM
  #225
Ixtrim
Ixtrim's Avatar
Kim!
I canīt really say what the problem is.
H needle 1 /3/4 is to rich, you are right. what fuel do you use ?
take sure that both carbs are doing 100% at full throttle ( look at the carbs where the ball links are connected)
tom
