Kolm 135 install in CARF Mustang
#151
As I understand from this thread, front support is not necessary (Tom's words I think). That said, I am going to make supports for the cowling/side panels, and in that process, I will probably make front end supports for the engine while I am at it
#152
My Feedback: (7)
AB, CANADA
Ok here goes...pictures of my Carf Spitfire/Kolm 135 installation (and a few mandatory cockpit shots as well) Still lots to do, but I am getting there
I needed to mount the engine, so I can begin the baffling job/construction (which I must admit, is giving me "headache", as I have never done an inline engine before). I will copy fellow modellers solutions, based on pictures in this thread. There is not much room between the engine and the cowling at certain spots. I will make the left/right side panels of the cowling removable for easier access/maintainance.
All my previous models where fuelled with methanol and engine heating was never a problem. the last one was gasoline and the engine cooling was a nightmare for me.
#155
@youngguy, the air intake is not my work, it is something the previous owner did (before he lost interest in the project), and I will modify it to my preference later.
@lxtrim, I have mounted without rubber-locks. Are you saying that I will be fine this way, without front support? I am asking even though you have mentioned this before, since you have experience. Or in other words; if you were to mount a Kolm engine tomorrow, how you do it, based on your knowledge?
Kim
Kim
#156
Kim.
My il135 was mounted in spitfire for One Season without Rubber And without front Support.
Now problem, if your Firewall is stable enough!
I would do it again this Way.
Tom
Tom
#157
Thanks for quick response lxtrim. I have probably "overdone" my new firewall, and the fuselage in the firewall area and some 20cm back into the fuselage. Better to overdo this area, and extra weight is no issue with the Carf Spitfire
#162
NC
Hey Fellas, I have been following this thread for a few nights. I too have decided to build the Mustang with the Kolm 135. This is great having so many experienced guys in one place on this mission.
Dr Scoles I am very impressed with your work so far. I can't wait to see your beauty out of the paint shop.
I built the 50cc Aeroworks mustang but installed a DA 85 and a solo prop 4 blade. We also fiber glassed the airframe and used flite metal. I am thinking of using flite metal on this bird as well. Actually I was going to buy a BVM jet but after hearing the Kolm 135 I am just craving that sound. Plus I love the Mustang so it all works for me.
You guys have done some great jobs on these birds and I really appreciate the collective skills you all bring to the table. I am getting hungry for more info Dr. Need those pics. lol
#166
Back on the Spitfire/Kolm 135 after vacation, family and work... I have finally started on the cooling construction)
Here is a photo (dry fit) of the progress so far. Lots more to do, but I can imagine the end result now. Getting a snug fit between the cowling and the cooling plates, are really time consuming, wtih multiple cowling on/off repetitions. I have also installed two Futaba temp sensors (telemetry).
Kim
Kim
#167
My Feedback: (18)
Since this thread is getting some life, I will share some pics of my progress…. My buddy painted the plane with PPG liquid metal, it looks awesome. Depending on how you clear and weather it, it looks like metal… ;-) I have four pages of little tiny nomenclature stickers to put on, then it has to be cleared, then I can do final assembly. I love the distressed look that CARF or fiber classics or whoever did it put into the plane. Looks like the real thing!
#170
My Feedback: (18)
Not much. I paint about as well as my buddy fixes teeth…. I do know you have to paint the plane black, then clear, then you spray the stuff super thin. After that, you put a binder over the top, then its durable. Do your decals and weathering, then clear. I think you may put the binder on again after the black/clear..can't remember. I took a video of him doing it, I'll try to post.
http://youtu.be/mXgcww5J4LU
#171
Your Mustang looks great btw!
#172
Looks Very very good !
Go on.... Everything looks good. waiting for mY Mustang. Will Receive it in 2 or 3 Weeks.
Cooling looks also perfekt. Maybe You can Post some more Fotos?
Air in- cool side - thru the engine-warm side- air out ?
So everyone can Understand How to to...
greets
Tom
greets
Tom
#173
My Feedback: (18)
Two more pics, this thing is going to look awesome. I cut out a few hundred little decals today while I was watching football. Kids have been taking it to me lately, not sure how long it will take to get all the finish work done. There's no more fabrication, just gotta do the stickers then reinstall everything.
#175
greets
Tom
greets
Tom
Here are some photos....pleeeease share your thoughts if there is something to adjust. I have NOT yet installed a small inlet for the "warm" side, as I am uncertain whether it is neccessary or not? If so... is it better to make the small inlet at the front (next to the big inlet), and route the air to the "warm" side, or just make a scoop on the "warm" side (side panel), to give the carburators some cool air?
Photos in this order: Air inlet - "cold" side - "warm" side - Air outlet seen from the engine - Air outlet seen from underside cowling.
Kim
