Reload this Page >
3W Bearcat with Moki 300
Old 10-17-2019, 04:29 AM
  #276
mitchilito
My Feedback: (7)
I couldn’t find door cylinders online to fit my inner gear door needs so I had Sierra Giant Scale make me a set: 1/2X2 inch. They’re perfect. Darrell at Sierra does beautiful work.
if you look closely you can see where I mounted this cylinder first. It was too close to the hingline allowing flex. Bottom picture shows how new position results in much better triangulation.
Old 10-20-2019, 01:19 AM
  #277
mitchilito
My Feedback: (7)
Default Finished:
Old 02-02-2020, 04:02 AM
  #278
mitchilito
My Feedback: (7)
After a bunch of deliberation I decided to bolt the motor mount on instead of gluing. I attached servos and ignition to mount so the whole assembly is removable as a unit.
Old 02-08-2020, 06:43 AM
  #279
mitchilito
My Feedback: (7)
So, engine is installed, cowl is mounted and baffling is installed. Cowl has 5 bolts holding it on: two flush bolts on bottom and three bolts that bolt in from the INSIDE of fuselage for invisible mounting.
Old 02-17-2020, 10:31 AM
  #280
mitchilito
My Feedback: (7)
Well, after 4 years the day has finally arrived. It’s time to close the hole in the fuselage for the smaller canopy. I have been dreading this literally for years! Didn’t really know how to approach it but I think I figured it out: I used some very nice 1/32 basswood sheet to back up the hole. I covered this wood with release tape then glued it in place.
Old 02-17-2020, 10:36 AM
  #281
mitchilito
My Feedback: (7)
Then I used a light filler to fair the whole mess in to fuselage height. After sanding to blend in I covered with my green adhesive release film. I have used this process several times now and it has never failed to produce great results.
Old 02-17-2020, 10:43 AM
  #282
mitchilito
My Feedback: (7)
I then put a layer of 3oz glass a layer of 6 oz and a final layer of 3oz over it.
Old 02-17-2020, 11:55 AM
  #283
mitchilito
My Feedback: (7)
All that work for this little part!
Old 02-17-2020, 11:56 AM
  #284
mitchilito
My Feedback: (7)
Really getting close now.
Old 02-18-2020, 03:54 AM
  #285
mitchilito
My Feedback: (7)
I decided on a 7 inch spinner. It’s a compromise of scale looks and necessary cooling air access. Unfortunately it HAS to be smaller than the full scale Bear.
Couldn’t find one to buy so I’m making one.
Old 02-20-2020, 04:06 PM
  #286
mitchilito
My Feedback: (7)
Default Rare Bear Spinner
Chucked a block of foam in the lathe and removed everything that didn’t look like a spinner!
Getting close
Perfect!
Old 02-27-2020, 12:12 AM
  #287
geebeeman
My Feedback: (21)
Reading your build brought back some fond memories. I lost mine on the third flight due to aileron flutter. It was the first time I really ran it at full throttle (3W-155 four cylinder). I saw the aileron buzz & the wing immediately exploded. Make sure all your control horns have extreme gluing surface area. There just isn't sufficient structure in any of the control surfaces. Awesome flying airplane up till then! Landed like a trainer.
Old 02-27-2020, 04:33 AM
  #288
mitchilito
My Feedback: (7)
Yep, these airframes are famous for flutter problems. Then to compound the problem 3W drills holes in the base of the hinges in the wing weakening them drastically. Crazy.
I’m going to take a number of steps to prevent flutter in general, including sealing the surface gaps, counterbalance etc.
Its going to be FAST with the Moki 300. Although probably not faster than your setup was. Main thing holding the Moki back is getting the right prop on it for max speed and my gorgeous SL 4 Blade is a beautiful compromise.
Old 02-28-2020, 04:51 AM
  #289
mitchilito
My Feedback: (7)
Here’s the spinner plug after filling, sanding and a coat of blue spray. Ready for surface fiberglass.
Old 03-04-2020, 04:53 AM
  #290
mitchilito
My Feedback: (7)
Took a break from spinner work to install a bulkhead in back (the one on top). With the motor on and holding the plane in the cradle I could flex the tail more than I liked. Detlef said this would happen!! This aircraft with this engine is going to be FURIOUS at speed so it’s best not to take any chances.
This small bulkhead is made from the same material as the rest: carbon-sandwiched foam. Super light and amazingly strong when installed. (Actually, the tailwheel bulkhead is carbon sandwiched ply).
Old 03-04-2020, 05:00 AM
  #291
Detlef Kunkel
Nice work Mitch.
What a mess with the spinner...poor lathe
I was not too lazy with the main gear
After some calculating and testing I defined the 2 springs for the mains and made some test versions before I finally placed an order.
Today the ordered springs came, and so we can slowly reach the end of the Assembly stage.
I am going to paint mine all White- simply because I like the look very much
Name:	Bearcat Rohteile Alu (4).JPG
ID:	2266621   Click image for larger version
Name:	Bearcat Rohteile Alu (6).JPG
Old 03-04-2020, 05:12 AM
  #292
mitchilito
My Feedback: (7)
Those gear are gorgeous! So scale-like. That was a labor of love. As we can all guess, it’s anybody’s guess how my gear are going to work 😳 although I have a good feeling about them.
I’m definitely envious.
Old 03-23-2020, 07:35 AM
  #293
mitchilito
My Feedback: (7)
Made the spinner mold out of Kevlar just because I have a bunch on hand. I’d make the spinner out of Kevlar too but as I’ve said before it cannot be sanded - and I WILL be sanding this spinner.
Old 03-29-2020, 04:19 AM
  #294
mitchilito
My Feedback: (7)
I ordered 6 oz bias cut carbon cloth and cut in to 1/4 wedges. I then laid them in place dry and wet them out with a brush. There’s just no way I could do a vacuum layup on this component. An important final step on every layup is to repeatedly scrape the brush dry and blot the layup until no more resin will come out. Yields surprisingly good results. This whole process would not be possible without the supple bias cut cloth.
Old 04-03-2020, 04:32 AM
  #295
mitchilito
My Feedback: (7)
I’m pretty happy with the outcome. Took some wet sanding to get smooth and a bunch of pinhole work yet to do. It’s huge but only weighs 7 ounces. FYI- starting from outside in: 2 layers 3oz bias glass then 3 layers 6oz bias carbon. I think that’s just right, structurally. Around 2mm wall thickness.
Old 04-03-2020, 10:32 PM
  #296
Detlef Kunkel
Nice work Mitch.
Good to see other guys that also dont always go the easy way
Will be a very unique BC in the end :-)
Old 04-05-2020, 03:25 AM
  #297
mitchilito
My Feedback: (7)
Thanks Detlef. That’s quite a complement coming from you.
Heres a little teaser just for the fun of it:
Old 04-06-2020, 11:02 AM
  #298
mitchilito
My Feedback: (7)
Who knew when I started this project it would be less of a hobby and more of a lifetime pursuit!!
Old 04-07-2020, 10:35 PM
  #299
Detlef Kunkel
Smile U/C progress
I am not too lazy either.
Found the time to paint the U/C. One will stay all metal, the other guy will paint his one White, too.
Lots of sanding, shaping, rounding all edges, covering all functional surfaces, etch primer applied and then a little darker toned white coat.
I didnt count the parts, must be over 30 or so
This U/C is soo sexy in White
ID:	2266980   Click image for larger version
ID:	2266981   Click image for larger version
ID:	2266982   Click image for larger version
ID:	2266983   Click image for larger version
Old 04-08-2020, 05:07 AM
  #300
mitchilito
My Feedback: (7)
Those gear are going to be fantastic. Can’t wait to see them in a wing.
Hey Detlef, I would still love to hear more about your Moki 300 fuel induction mods. Can you tell us a little more about that?
