Reload this Page >
nitroplanes.com FW 190 Build
Old 04-25-2007, 01:28 AM
  #501
patzane
Default RE: nitroplanes.com FW 190 Build
A buddy of mine has this plane and had questions for me I could not answer.
He went with a Satio 125. According to him he needs to add about 2lbs to the nose. Does that sound correct.
Also what is the CG on this.
Old 04-25-2007, 04:40 PM
  #502
LDM
My Feedback: (15)
wow , 32oz in any book is scary , I am worried about 14oz on my seafury , I just made up 4 with a bigger battery , moved everything i could forward , 32oz is a concern
Old 04-25-2007, 09:47 PM
  #503
patzane
that is the samething I told him. That is alot of weight he has to add. I did refer him to his site to get info and ideals of what others has done to this plane.
Old 04-25-2007, 09:50 PM
  #504
rifraff
rifraff's Avatar
patzane the saito is pretty light, i have 1 1/2 pounds on mine with an OS 120 with pump and it weights in at 12 LBS, so 2 pounds with a saito is about right....
and i set the CG at 95mm from the leading edge of the wing and thats with everything as far forward as possible
good luck and happy flying
Old 04-25-2007, 09:52 PM
  #505
patzane
thanks for the info rifraff. Is this the same CG that is listed in the book
ORIGINAL: rifraff
Old 04-26-2007, 04:28 AM
  #506
LDM
My Feedback: (15)
Ok , so if the standard is 16 to 24 oz needed for proper cg , then i would still try to move anything you can forward ,
1)build a battery box on the firewall ,
2)use a 1500 battery =4.4oz up to a 4.8vt 2400 battery =8.4oz both will give you longer flight times and its much better then dead weight
3)go to Kalvin wheels or Dave Brown light wheels , the average weight of Robart scale wheels , and others is about 2.4oz for 3.5" wheels and higher ,
you can shave about 2.5 oz in total by going to Kalvin or Dave Brown ,
Hanger 9 wheels dont work , they weigh the same as robart
4)if you can move your servos forward in the fuse even if you have to build a new tray and cut out the old ,
again this is just my advice but I hate to add dead weight
Old 04-26-2007, 05:11 AM
  #507
ticketec
Hey, just out of interest, what gasser engines have people used on their Fw-190?
Has anyone run a 40cc gasser in one?
Old 04-26-2007, 09:05 AM
  #508
Sturtz
My Feedback: (20)
Sturtz's Avatar
I had to add 7oz in the form of a socket filled with fishing weight lead. Battery and onboard glow unit are mounted to firewall inside fuse.
Saito 150.
rx bat= 4.8 2700mah Nimh
Glow unit uses a 1.5volt 1500mah c type NiCd cell
Fuel tank is 20 oz for extended flight times although this makes the 190 slightly nose heavy for the first 10 mins of flight.
ID:	672564   Click image for larger version
Old 04-26-2007, 10:29 PM
  #509
proulxlaw
proulxlaw's Avatar
I've read that folks have used G26's. This is a great motor as weight would otherwise need to be added to the nose to balance her.
Old 04-26-2007, 10:45 PM
  #510
rifraff
rifraff's Avatar
patzane i think it was 110mm, i lost the manual so many years ago and ive had it at 95mm
Old 04-27-2007, 10:27 AM
  #511
Sturtz
My Feedback: (20)
Sturtz's Avatar
Anybody know where I can get a decent pilot bust that fits the 190 ? Mine is too large.
ID:	673254   Click image for larger version
Old 04-27-2007, 10:46 AM
  #512
NoFlaps
My Feedback: (131)
I used the Hangar 9 bust...I can't remember if it was 1/5or 1/6th scale...See earlier posts on this same thread to see how it looks.
Good luck!
Sean
Old 04-27-2007, 11:47 AM
  #513
proulxlaw
proulxlaw's Avatar
Looks great!
Old 04-27-2007, 02:51 PM
  #514
Sturtz
My Feedback: (20)
Sturtz's Avatar
You stated 1/5th in the post. Looks good Sean. You still painting these little guys for a nominal fee ?
Old 04-27-2007, 04:19 PM
  #515
NoFlaps
My Feedback: (131)
Yes, I do...I'd be happy to do one for you if you'd like. I'm unemployed at the moment, so I can do it in no time.
I thought my pilot looked a little oversized, but the 1/6th looked a bit small.
Lemme' know~
Sean
502.718.1614
Old 04-28-2007, 02:40 AM
  #516
ticketec
Hey Guy's
Without seeing them, i would go for the 1/6 scale one seeing as this Fw-190 is 1/6 scale! The real pilots looked kinda small in the Fw's office
Old 04-29-2007, 05:14 PM
  #517
rifraff
rifraff's Avatar
Sturtz i used a bust from nitromodels heres the link http://www.nitroplanes.com/rcmodelpilot5.html on sale for $7.50
Old 04-30-2007, 09:54 PM
  #518
k lupold
Hey, guys just wanted to let you know i lost my fw190 and total
heart breaker!!! sweet bird. well she had 2300 st i was running
15/18 wildcat then 20/20 she was much faster and 16/7 prop
before ran 16/10 had it in a dive pulled out down the runway
when a mean tail flutter!! had flite check all horns servo's
ect, I think i should had tail supports like me-109
enjoy that plane fly scale!!! thats what i get showing off!
ken
Old 04-30-2007, 10:03 PM
  #519
Sturtz
My Feedback: (20)
Sturtz's Avatar
Bummer,, hate to hear that. I won't comment on the St2300,,, makes some folks mad when you bash them. I do think I'll stick to 4 strokes and gassers on my warbirds though.
I haven't had a problem with the tail section so far (knock on wood.) I did use tri-stock at the fuse when building it. Cheap insurance.
What's your next bird gonna be Ken ?
Old 05-01-2007, 08:55 AM
  #520
k lupold
The sp 2300 has been a great motor! ran fast!! no dead sticks
I think it lost the elv,servo in that dive! standard JR dig,
I think I will build the jug! p-47 also just got YS 110 fz supercharged!!
fw- 190's still rock!
take care guys!
ken
Old 05-02-2007, 08:23 AM
  #521
k lupold
To who that dont already know!
I was told that you can get 3m
package tape and cover all hinged
areas to help from high speed flutter??
and its fuel proof.
thanks ken
Old 05-02-2007, 10:02 AM
  #522
proulxlaw
proulxlaw's Avatar
or you culd use clear MonoKote.
Old 05-06-2007, 11:07 AM
  #523
LDM
My Feedback: (15)
I use monocote , even on the tightest lines, learned when I lost my F14 prop jet to flutter
Old 05-06-2007, 12:39 PM
  #524
k lupold
did you fold in the areas so the surface can move up and down
free ??and all it does is to keep air from going threw
the alerions and elv,???
is this correct?????
ken
Old 05-06-2007, 12:48 PM
  #525
NoFlaps
My Feedback: (131)
I know you weren't asking me, but that is correct.
Crease the monocoat right at the hinge line, and apply to both the top and bottom sides if you wish.
Prevent air from passing through the hingeline.
I often use a thin strip of clear packing tape as it's concealed in the joint, but it's a bear to tangle with.
