Solo props????
Old 12-20-2006 | 06:48 PM
furloughed ual's Avatar
My Feedback: (31)
Default Solo props????
Has anyone used the Solo adjustable props? I am wondering about the efficiency of the actual blades (airfoil design).....I tend to like the Menz airfoil for my Warbirds......just wontering if the Solo blades work well or would be better suited for mixing paint....
Old 12-20-2006 | 07:08 PM
Default RE: Solo props????
Sure would like to know the answer to that....
Old 12-20-2006 | 07:27 PM
I bought one with the 16 & 18" blades. The variable pitch center section is poorly balances, so I have not been able to use it. So far I am not impressed after spending $$$! But it looks great.
R/C Foolish
Old 12-20-2006 | 07:44 PM
Hmmm... thanks a lot you saved me some money.
Old 12-20-2006 | 08:06 PM
I have had excellent results with Solo Props.
1. SkyShark R/C Giant P40 24 lbs. 22" 3 blade with SteveNeu Electric BAM Motor 4400 Watts! 105mph.
2. Top Flight Giant P51 23lbs 24" 4 blade with SteveNeu Elecrric BAM Motor 5300 Watts 115mph
Carl is great to work with and I used both props right out of the box.
Scott
Lake Havasu, AZ
Old 12-20-2006 | 08:39 PM
TLH101's Avatar
My Feedback: (90)
A freind used a 2 blade version, on a Hostettler Stinson with good results, and he is now using the 3 blade version on his Ziroli Stuka, with good results.
Old 12-20-2006 | 08:50 PM
My Feedback: (31)
Scott.....intereting....thanks......my current bird is a Yellow Aircraft P-47 with a ZDZ 80 thumping away up front......147mph on the radar gun....
Old 12-20-2006 | 09:03 PM
SJN
Seems to work great on this Yak-11 with moki 250
http://www.mnbigbirds.com/images/Vid...lips/yak11.wmv
Old 12-21-2006 | 06:44 PM
well here goes..
Old 12-23-2006 | 04:34 PM
tahustvedt's Avatar
I'm using a three blade 20" Soloprop on a 1:6 scale p-40 at low rpm with good results, but I don't have anything to compare with apart from APC 17x10 Pattern with at higher rpm power system on the same plane. Mine's well balanced as long as the hub halves are tightened perfectly evenly.
Old 12-23-2006 | 08:49 PM
My Feedback: (31)
ORIGINAL: tahustvedt
U using the round or square tip 3 blade Solo? An APC is a good efficient design, so glad to hear u are happy with the performance....
Old 12-23-2006 | 10:32 PM
My Feedback: (14)
We should try my soslo prop on your P-=47 Ryan
Brian
Old 12-24-2006 | 12:44 AM
My Feedback: (31)
ORIGINAL: thunderbolt-RCU
Brian
Would be a good test.....would have to order a new set of blades.....
Old 12-24-2006 | 09:21 AM
tahustvedt's Avatar
I'm using the round tip blades. They look very nice on the plane.
Old 12-24-2006 | 09:29 AM
My Feedback: (31)
Thanks.....I'm also looking at the round tips for a 3 blader on an FW190.......
Old 12-24-2006 | 11:42 AM
is there a way to put your own spinner over the prop hub
Old 12-24-2006 | 01:37 PM
tahustvedt's Avatar
The standard Soloprop adapter fits the bolt that comes with Dave Brown and TruTurn spinners (10-32 bolt or whatever it's called). I made a custom spinner for my plane where the spinner cone is secured with six bolts around the backplate like in the picture I attached.
Old 12-24-2006 | 02:58 PM
thats great to know thanks
Old 04-14-2007 | 11:18 AM
My Feedback: (108)
Scott Bahde please remind me what pitch setting you like best on your Solo prop 4 blader for the TF P-51 with the Neu Motor.
Old 04-17-2007 | 04:59 AM
Banned
anyone tried a 3 or 4 blader on a DA-50? Carl recommended 20 x 8
Old 06-12-2007 | 12:27 PM
G-Pete's Avatar
ORIGINAL: Peter_OZ
I'm plan to built a 80in. P-47 and my motor will be a DA 50 --- so i'm in the same boat......did someone try something like that??
Old 06-12-2007 | 01:16 PM
TLH101's Avatar
My Feedback: (90)
ORIGINAL: G-Pete
ORIGINAL: Peter_OZ
A 20" prop won't be anywhere near scale, on an 80" P-47. Besides, I don't think a DA-50 will turn a 20x8 4-blade with enough RPM to fly a model that size.
Old 06-13-2007 | 07:32 AM
G-Pete's Avatar
I thought you need less RPM with a 4 bladed propeller (!??).
You are right about the Prop size, the P-47D Razorback had an Curtis Electric C542S with 13 foot diameter – this would be on a 80 inch (1:6 scale) a 24 inch airscrew.
By searching about the hubs and 4 blades I came across of a interesting website…
[link=http://www.warbirdpropdrives.com/18422.html]here is the link[/link]
Happy landings[sm=thumbup.gif]
G-Pete
Old 06-13-2007 | 08:06 AM
TLH101's Avatar
My Feedback: (90)
ORIGINAL: G-Pete
G-Pete
YES, you do need less RPM, however, with less RPM you needs much more pitch. So if you get the pitch you need, the motor will still not turn it.
Actually, a 1/6 scale 4-blade would be 26". Below are some pics of my Byron 80"P-47 with a 26" scale "static" prop.
Warbird Prop Drives has been working on this system for several years. Seems to have several issues, not the least being weight. If he ever gets it working, it would be a nice option on a scale bird.
Do search on RCU and you may be able to bring the older threads on it. have not heard much lately.
ID:	703217   Click image for larger version
Old 06-13-2007 | 09:40 AM
corsaircrazy's Avatar
Remember the old Byro-drive belt reduction system? I wonder if something like that could still work [:-]
Too bad RCV engines are so small, the SP version is 2:1 ratio. Can you imagine a 50cc RCV motor?...... Big props, slow rpm.... its just natural!
CC
