Meister 1/5 scale P-47
#1126
My Feedback: (221)
RE: Meister 1/5 scale P-47
ORIGINAL: dvs1
Very nice indeed!
Very nice indeed!
We hope to get the engine started this Friday. It hasn't run in the plane since last October, at Monster Planes. Gerhard ran it though, after he went through it.
We checked the balance tonight for the first time since all the changes this winter. I need to add 7 oz to the cowl and we are perfect. A little more Steel Powder.
#1130
My Feedback: (221)
We got Zombie out today for the first time in 2011, to test run the newly gone through 3W 80. Gerhard did a very nice job on it. She started well, and ran great. Nice slow idle, smooth transition, steady mid range, and strong high end.
We also tested the cowl flap operation and observed the inner gear doors for stability under the prop blast. All looked good and functioned well. Immediately after shut down, we pulled the cowl and tightened the muffler again. I got about 1/4 turn out of each bolt. It will stay tight now.
www.youtube.com/watch?v=X2-TVPBlUsE
#1131
Any way to safety wire those muffler bolts. If the heads are exposed, simply drill them and wire tie them. Never ever a problem then. Me like that!
#1133
My Feedback: (221)
At least I'm getting one thing out of the way before Top Gun. I'm heading down to the hospital for the birth of my 4th grand boy. Hope he is a future RC builder and pilot.
Did I say I was getting this out of the way? I guess my daughter deserves the credit.
Sounds like it is going to be a long night.
#1134
Yeah Gary, you got way too much on your plate! Maybe you should let your daughter do the birthing.
Congrats to you and the family, "new" and old.
See you in a week or so.
Scott
Scott
#1135
My Feedback: (221)
ORIGINAL: Scott Prossen
Congrats to you and the family, ''new'' and old.
Scott
Scott
#1136
My Feedback: (158)
ORIGINAL: ram3500-RCU
Good idea. I'll look into it.
#1137
My Feedback: (221)
We looked at our muffler and the cap screws are buried in it. No way to do a safety wire. I got a quarter turn out of them after the run-up we did. This muffler has the additional brace on it as well. The original one did not. Hopefully, it will be easier to keep tight. Also, the engine is smoother now after Gerhard worked on it. Should be less vibration on the muffler. It is part of my procedure to check the muffler from the exhaust pipes before each start now.
When you get into heavy scale war birds, more maintenance is required. One thing a new guy to this type should be ready for. I can fly aerobatic stuff, even giant scale, and do very little on them all summer. Not so with these gentile giants.
I bet if we were to track the time spent it would be near a 1 to 1 average ratio, one hour of overall repair and general maintenance for every one hour of engine time. Now that is taking into account that even our scale stuff are flown regularly, and not just at Top Gun like events. Last year, I flew my scale war birds much more than my aerobatic stuff.
#1139
My Feedback: (221)
ORIGINAL: scale only 4 me
Worse case, you could get longer bolts and add washers or a wheel collar type spacer so the caps are exposed more,,, always options.
Can't wait to see it up close again, When is your first flying event of the year?? Top Gun?
Looks like Top Gun is it. I only wish we could get out sooner up here, but the fields are still so soft from all the rain, and none have been rolled yet. One good gopher hole could do a nice set of retracts in real quick. I haven't been out once yet this year. Flying my sim and indoor helis is all.[]
I found a giant scale P-51 on my sim to practice my demo routine with. At least I get my switching, turns, and the order of the maneuvers well in mind.
I'm not expecting to do very well against guys that fly all winter.
#1143
My Feedback: (73)
Hi Gary, congrats on the new family member. I use high temp RTV for the gasket and the bolts with great success. My Ziroli Corsair has been flying for 2 years now with no problems.
#1144
My Feedback: (221)
ORIGINAL: JSZ
Carson arrived at 2:02 AM last night. Everything went well. Got home around 4:00.
Glad that is out of then way. He was the last one in the hanger. That makes 4 newborns in the last 7 months. All boys. My shop is going to be a mad house I fear, starting in about 2 years.[]
#1149
My Feedback: (221)
You know I'm a Carpenter/Cabinetmaker too, Right? Keep them customers happy,, they are harder to find these days
I was in high end new home construction in the nineties when the kids were young, but not anymore. Strictly remodel and light commercial now. It has been me, two of my sons (accomplished carpenters in their own right) and my third son is the licensed electrician and also has his own electrical company. I also have a brother with a concrete business.
#1150
My Feedback: (221)
We decided to make another improvement I think.
I had a new 4800 2-cell lipo on hand, so we decided to use it for the gear. The Down & Locked control box has a port for an independent power supply. It fits nicely on the side of the interior, below the superfluous air tank, with some Velcro. This puts it right on the CG.
We will use an adjustable voltage regulator to set the voltage to the gear at 6.8V. This isolates the gear system from the RX batteries. You simply cut the red wire to the RX and let the signal come through.
D&L told me that, given the power usage of the system, the 4800 mah is good for about 1100 cycles. Seriously.
