 BVM Electra Build >
BVM Electra Build
BVM Electra Build
Old 06-29-2007 | 05:32 PM
k_sonn's Avatar
My Feedback: (32)
Default BVM Electra Build
The replacement for my Maverick (RIP) arrived ealier this week and the Yellow F-16 build is nearly completed so I thought I'd start a thread for the next project. Not shown in the photo is the wood for the wings, plans, thrust tube, and instruction booklet.
The planned power set up is:
Fan -- TF4000
Motor -- Neu 1527 1.5Y
ESC -- Not sure which one yet
Batteries -- TP Extremes 12S
This set up is currently installed in a Schriener F-18 and produces 4500+ watts and 15+ pounds of thrust with a bifurcated exhaust duct.
I will be using the retracts, struts, and wheels from the Mav.
Kirk
Old 06-30-2007 | 03:42 PM
banditarf robert's Avatar
Default RE: BVM Electra Build
any updates?
Old 07-09-2007 | 02:09 PM
k_sonn's Avatar
My Feedback: (32)
ORIGINAL: banditarf robert
any updates?
No updates at this time but I should have some by the end of the week.
Kirk
Old 07-09-2007 | 02:32 PM
mr_matt's Avatar
My Feedback: (10)
Hi Kirk,
Nice looking kit. I have been looking at one of these myself.
How are your planned fan, motor and ESC different from the BVM offering?
Old 07-10-2007 | 06:13 PM
k_sonn's Avatar
My Feedback: (32)
ORIGINAL: mr_matt
Hi Kirk,
Hi Matt,
The system I will be using takes about the same amount of input power as the EVF but should produce 2 to 3 pounds more thrust and is lighter. The fan is made from carbon fiber and weighs 4 ounces.
Kirk
Old 07-10-2007 | 08:44 PM
and lets not forget gobs of velocity! lol is the TF/Ork gonna land in there Kirk?
Barry
Old 07-11-2007 | 11:53 PM
k_sonn's Avatar
My Feedback: (32)
ORIGINAL: marm
Barry
Hi Barry,
I'm not using the Ork motor on this one. I'm using the exact same motor used on the EVF system, a Neu 1527 1.5Y.
Kirk
Old 07-11-2007 | 11:54 PM
k_sonn's Avatar
My Feedback: (32)
Started on the Electra wing. First one is built and ready for bottom sheeting. I used the flex plate and retact unit from the Maverick. I had to slightly modify ribs 1, 2, & 3.
Kirk
ID:	721211   Click image for larger version
Old 07-12-2007 | 07:08 PM
k_sonn's Avatar
My Feedback: (32)
The bottom of the left wing has been sheeted. The right wing has been framed and the top sheeting has been applied.
Kirk
ID:	721725   Click image for larger version
ID:	721726   Click image for larger version
Old 07-18-2007 | 02:32 AM
Hey Kirk,
I really like how that Electra is going along, sadly, there was a P-3 on our runway this past weekend, now my dads gona be out of town so i wont be able to fly this weekend and hopefully you will make the open house at the marsh on the 28th and 29th.
TJ
Old 07-18-2007 | 04:38 AM
TJ, with the speed at which Kirk builds, he may have it on display at the open house at the swamp!
Old 07-18-2007 | 05:19 AM
k_sonn's Avatar
My Feedback: (32)
Thanks TJ. It is going together fairly quickly.
Kirk
Old 07-18-2007 | 05:20 AM
k_sonn's Avatar
My Feedback: (32)
The flaps and ailerons are were built right onto the 1/32 ply sheeting. The photo shows one of the set framed and ready for top sheeting and the other set completed.
Kirk
Old 07-18-2007 | 05:22 AM
k_sonn's Avatar
My Feedback: (32)
Once the flap/aileron set is completed, they are cut apart and the leading edge is glued to the aileron and then shaped. The photos below show the flaps and ailerons hinged and fitted to the wings.
Kirk
ID:	725229   Click image for larger version
Old 07-18-2007 | 05:23 AM
k_sonn's Avatar
My Feedback: (32)
The horizontal stabs were framed and sheeted. The tips and elevators have been shaped and are ready for hinging.
Kirk
ID:	725231   Click image for larger version
Old 07-18-2007 | 08:04 AM
Soooo munch building for the price......
Old 07-18-2007 | 12:23 PM
ianober's Avatar
My Feedback: (12)
WOW, I just checked out the price of the kit and man, that is a lot of building for the price.[:'(]
Old 07-18-2007 | 10:11 PM
k_sonn's Avatar
My Feedback: (32)
All of the fuse cut outs have been completed. The intake ducting has been prep'd for installation. The fuse wood strutctures have been built and are ready to be glued into the fuse.
Kirk
ID:	725846   Click image for larger version
Old 07-18-2007 | 11:38 PM
ianober's Avatar
My Feedback: (12)
Great job Kirk, have you thought about your paint job yet? Any ideas?
Old 07-19-2007 | 02:05 AM
that setup should rock kirk! I know it'll be ok but might want to start with low timing then bump it up after you get an idea of loads through the BVM inlet. its short and twisty so it will raise the load a tad, but that motor is practically bullet proof so it'll do it.
Barry
Old 07-19-2007 | 01:10 PM
Are you using the tp 5000 mah?
Old 07-20-2007 | 03:15 AM
k_sonn's Avatar
My Feedback: (32)
ORIGINAL: ianober
Thanks Ian. I liked the Israeli scheme on the F-16 so much that I will most likely do the same on the Electra. I haven't put on the wing tips because if I do the Israeli scheme I will use the missle launchers and missles from the F-16 as wing tips. I also plan to do panel lines, rivets, and weathering.
Kirk
Old 07-20-2007 | 03:21 AM
k_sonn's Avatar
My Feedback: (32)
Hey Barry your right. With this setup, the Electra should be one of the fastest EDFs out there and faster than an EVF powered one. The only difference between my setup and the EVF will be the fan. The TF4000 is much lighter than the EVF (wieghs 4 ounces) and beings it is purpose built to utilize electric power, it should be more powerful using the same input power of 4500 watts.
Kirk
Old 07-20-2007 | 03:23 AM
k_sonn's Avatar
My Feedback: (32)
ORIGINAL: Pegasus
Hi CF,
I will be using either the TP 5000 mAh Extremes or the 7500 mAh Extremes sold by BVM.
Kirk
Old 07-20-2007 | 12:41 PM
ianober's Avatar
My Feedback: (12)
ORIGINAL: k_sonn
ORIGINAL: ianober
Kirk
Very cool Kirk, that should be attractive.
